      02-03-2019, 11:51 PM   #1
mbarrett635
Drives: 2019 X5 40i
Does your iPhone overheat in the charger?
My iPhone overheats whenever I have it charging for more than about 20 minutes. It also does it in my wife's 640i, so it's not just an X5 issue. I have an iPhone 5SE, which doesn't support wireless charging, but I've added an aftermarket charger adapter that allows it to charge wirelessly. As I said, I can only do it in the vehicle for up to 20 minutes. At home, it charges wirelessly on the the charging pad without any problem. I'm curious if upgrading to a newer iPhone would resolve this issue? I don't mind spending the money if it would, but I'm happy enough with my phone that I don't want to upgrade if doing so would make no difference.
So I'm interested in your experiences (iPhone only):
1. Does your iPhone overheat in the car?
2. Which model iPhone do you have?
Thanks.
      02-04-2019, 02:58 AM   #2
Ken6096
Ken6096's Avatar
108
Drives: BMW X5M F95 2022
Iphone XS heat from backside after 10mins, battery hardly increase.
Solution, use wireless charging from bestbuy which good enough
      02-04-2019, 04:43 AM   #3
Nick M.
Nick M.'s Avatar
Drives: his wife crazy with M cars
iPhone X here - It doesn't overheat in the sense that it goes into cool down mode but it does get extremely hot. It also barely adds any charge to the battery. If I'm using Waze at the same time it may actually still drain power.
      02-04-2019, 06:42 AM   #4
scottjays
Starfleet Command
scottjays's Avatar
306
Drives: 2020 X5 M50i
Is it possible to permanently disable the wireless charging? my wife’s brand new Honda minivan has wireless charging but you cannot disable it permanently you can go to settings and turn it off but each time you start the car it comes back on
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels,
      02-04-2019, 06:46 AM   #5
vinnymac
156
Drives: 2024 X5 50e
My iPhone X gets very hot in the wireless charger in my 40i.
      02-04-2019, 07:17 AM   #6
Xeno
Xeno's Avatar
313
Drives: 2019 X5 M Sport 5.0i
I do not remember my iPhone X in a Vaja case getting too hot in the G05 charger. This morning it was in the charger maybe 25 minutes.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      02-04-2019, 08:40 AM   #7
X5_CC
X5_CC's Avatar
289
Drives: X5 40i
I don't use the wireless charger anymore. My iPhone X overheats to the point of shutting down maybe once an hour on long road trips while using CarPlay. First it slows down majorly, and then it shuts itself off. I have to crank down AC and hold the phone in front of the vent to cool it off. Happens with or without the case.
I think it might just be placement of the charging pad in a location that gets no ventilation. My old Yukon had a charging tray on top of the center console which was much easier to access and also would charge the phone through the case and not overheat it.
      02-04-2019, 05:50 PM   #8
cygnusecks
cygnusecks's Avatar
Drives: X5 (G05)
Every time I use it, the wireless charge tray heats up my iPhone X .. I haven't seen it shut down but one time I took it off the tray, it was super hot, and behaved erratically for 10 mins (disconnecting and reconnecting to CarPlay, touch response not working or glitching heavily, etc). Pretty sure if I leave it on tray a long time it's gonna eventually shut down.
      02-04-2019, 06:02 PM   #9
AndroidRobot
AndroidRobot's Avatar
  [0.00]
Your phone shouldn't overheat via a 5W wireless charger.
Potential causes:
1. Very thick case => leads to lower efficiency ie more heat
2. using more power or equivalent power to what's going in so it gets hot
3. Ambient temperature is high or the device was already warm from outside or high usage
I've only had the issue when my phone was already hot but it never overheated. I've used wireless charging for 7 years now on my Android devices, most recently an S9+.
Appreciate 3
Xeno313.00
mnewnam268.00
      02-04-2019, 06:32 PM   #10
thomas_Rp
thomas_Rp's Avatar
126
Drives: X5 G05; 535 F10
I have an S9 and it was hot after a 20 minute test drive in the X5. I use wireless charging at home and have never experienced this.
      02-04-2019, 06:59 PM   #11
heinzena
Drives: 340xi M-Sport
Yes. Overheats and doesn’t really charge
      02-04-2019, 07:15 PM   #12
AndroidRobot
  [0.00]
interesting, my S9+ never overheats in the car, I have a Speck Presidio case which isn't overly thick
      02-04-2019, 08:01 PM   #13
mnewnam
268
Drives: '21 Mineral White X5MC
I don't use a case on my iPhone XS Max... haven't had an overheating issue and it has stayed on the wireless charger for hours... It's warm when I pick it up but no more than normal like when I put it on a Qi charger at the house. I do also swipe up to dismiss Apple Pay when I get it bc if the screen stays on it will get hot.
      02-04-2019, 08:14 PM   #14
cygnusecks
cygnusecks's Avatar
Drives: X5 (G05)
Potential causes:
That's probably my problem - thick case with 4 credit cards in it (which do not get de-magnetized in case you're wondering).
But I also have a wireless charger bedside for overnight charging and the phone isn't hot after all night on that!
      02-04-2019, 09:06 PM   #15
AndroidRobot
  [0.00]
Potential causes:
Depends on a variety of things, charger output (what it's actually sending to your phone) efficiency of the charger based on where it lines up with the coil or coils, how clean is the power going in each charger etc. I'm not an electrical engineer, more of a chemical one so I can't go too in depth here but there are a lot of factors to consider.
Wireless charging creates induced magnetic fields so it won't affect your credit cards
      02-04-2019, 11:21 PM   #16
PhatBoyG
Drives: 2019 X5 50i
Naked X and never have had it overheat.
      02-05-2019, 06:16 AM   #17
AndroidRobot
  [0.00]
naked you say? this OP just got hot!
      02-05-2019, 06:26 AM   #18
Xeno
Xeno's Avatar
313
More often than not, I will be running Waze when my iPX is in the charger. I clear Apple Pay one or more times and still no overheating in my thin Vaja case.
      02-05-2019, 08:45 AM   #19
X5_CC
X5_CC's Avatar
289
Drives: X5 40i
I noticed if you feel along the edge of the center console right behind/above the cup holders, it seems like there is a vent there. Not sure if this is connected to a duct with fan-driven air, but if so, there may be a software opportunity to divert more air to the charging tray area to prevent phone overheating. Mine has the heated/cooled cup holders so not sure if that is the same for all G05s.
      02-05-2019, 08:48 AM   #20
paul45
Drives: 2019 X5 40i
You can turn wireless charging off in settings.
      02-05-2019, 08:49 AM   #21
AndroidRobot
  [0.00]
Same, where are you seeing the vent? I'll have to look at mine and check
      02-05-2019, 08:55 AM   #22
X5_CC
X5_CC's Avatar
289
Drives: X5 40i
Just looked and my loaner doesn't have it. If I remember correctly, it's right behind the cool/heat buttons for the cup holders (like toward rear of vehicle). In that gap between the top of the cup holder and the wood trim.
