03-10-2020, 04:44 PM | #23 | |
1197
Rep 1,587
The boolean for C_XV3D_COUNTRYVARIANT_NEXTMODE = USA (broken) is: XPath=boolean(//cat[@val<"128"][crit[@val=186]]) or (boolean(//cat[@val<"128"][crit[@val=469]]) and boolean(//cat[@val="255"][crit[@val>=1903]])) or (boolean(//cat[@val<"128"][crit[@val=117]]) and boolean(//cat[@val="255"][crit[@val>=1907]])) That explains why this code changed between build versions/i-step for USA/India vehicles. If the boolean doesnt get a match above, then allgemein is set. These are the codes that are different when comparing a similar spec USA vs ECE car type for 8081, but I only think the countryvariant is relevant: C_CM_CAM_LEFT_POS_AND_ORIENTATION: G005+RL+EGAL+EGAL, G005+RL+EGAL+EGAL, G005+RL+EGAL+EGAL [03 B7 FB D0 03 07 03 F1 FA 17 02 23 01 D0 FB 6E 03 48] C_CM_CAM_RIGHT_POS_AND_ORIENTATION: G007+RL+EGAL+EGAL, G007+RL+EGAL+EGAL, G007+RL+EGAL+EGAL [03 8E 04 44 03 07 03 6E 06 01 02 26 05 7E 04 48 02 C7] C_FLOW_GEOMETRIC_MASK_FRONT: G005+EGAL+MSP+REST, G005+EGAL+MSP+REST [02 2A 92 E7 A2 DE AB D4 B0 C9 B4 BF B7 B6 B9 AD BB A5 BC A1 BD 9C C0 99 C1 8F C2 86 C3 7F C2 75 C1 67 BF 58 BF 49 BD 35 42 34 42 41 41 4F 40 5E 3F 6A 3E 76 3E 7D 3E 8A 3F 93 40 99 43 9D 43 9F 45 A4 46 AD 48 B3 4A BA 4C C3 50 CB 54 D3 5A DC 63 E2 71 E7 81 E9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00] C_FLOW_GEOMETRIC_MASK_LEFT: G005+RL+EGAL+EGAL [33 25 6D DF 72 D5 74 D1 79 CF 7D C9 7D C0 7D B6 7D AD 7D A5 7C 9F 7B 97 7B 91 7A 8C 77 88 76 85 74 79 7F 66 86 4D 91 38 DE 43 E6 4E EB 58 F0 67 F3 72 F6 7C FA 85 FE 8F 03 96 03 A2 03 AA 04 AE 06 B4 0A C5 0F D6 1B E6 3E EF 5E E9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00] C_FLOW_GEOMETRIC_MASK_RIGHT: G005+RL+EGAL+EGAL [35 2E 82 62 81 5B 7F 53 7D 4D 7C 46 7A 3F 79 3B 0D 45 0B 4B 09 52 08 56 07 5B 06 62 04 69 03 6F 02 75 FF 79 FD 7D FC 81 FC 85 FD 8A FD 91 FD 99 FD A0 FC A6 FB A6 FA AD F8 B9 F6 C7 F2 D3 E7 E3 CD EE A4 E9 94 DD 8E D1 8B C8 89 C0 87 C1 85 C0 83 99 84 8F 86 8D 86 8B 88 89 86 7F 86 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00] C_TV3D_LOOK_AT_FRONT: F095+EGAL+EGAL+REST [0E 60 00 00 03 FC 11 E4 00 00 02 4E 01 A4 00 00 03 8E] C_TV3D_SHADOW_FRONT_INSIDE_MOVE: RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST, RR22+EGAL+EGAL+REST [01 F4] C_TV3D_SHADOW_FRONT_OUTSIDE_MOVE: RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS, RR22+EGAL+EGAL+JPNUS [00 AA] C_TYPE_KEY: 43 56 36 32 C_XV3D_COUNTRYVARIANT_NEXTMODE: allgemein [00] DG3000_26_28_25: UNK_PARAM_0 [06 03 01] |
03-11-2020, 03:15 AM | #25 | |
1197
Rep 1,587
Don't worry about it. Based on experience, if you've left it coded it'll probably just start working at some point for no obvious reason |
03-11-2020, 03:44 PM | #26 | ||
Rep 27
What do you know?! Got back in my car after tennis game this morning and it WORKS as it should. Started on AUTO. Soooo weird. Thank you guys for the help |
03-11-2020, 05:46 PM | #27 | |||
Rep 2,609
So for everyone other than @ifr's synthetic test, so far, it takes around 7-10 days for the coding fix to "take" and fully powering down every ECU with battery disconnect doesn't help ... Yes, weird to say the least.
06-17-2020, 03:41 PM | #30 |
2019 X5 40i
115
Rep 226
Lost the coding after s/w updated to 03/2020.58
Coded it again today, lets see after how many days the backup camera starts to automatically switch between front / back
2019 X5 40i (Mar-2019 Build)
iDrive ver -- 03/2022.30 |
LexxM31698.50 |
06-17-2020, 03:49 PM | #31 | |
Rep 2,609
06-18-2020, 08:21 AM | #32 |
2019 X5 40i
115
Rep 226
Correct - 03/2020.xx didn't fix it for US cars [based off my experience]
As long as the coding fix works, you can get the s/w update While 03/2020.xx allowed me to get the Drive Recorder, I am not sure if there is any noticeable difference than 07/2019
06-22-2020, 08:48 PM | #34 | |
Rep 2,609
07-02-2020, 11:23 AM | #36 | |
135
Rep 372
07-02-2020, 02:55 PM | #37 |
1053
Rep 1,952
I've done this coding - and noticed an interesting implementation. When I go in reverse the camera icon with the "A" in it isn't lit up, like it's not selected. However, when I shift into drive, the forward facing camera turns on anyway. So from day 1 of coding, it worked for me.
ifr1196.50 |
07-21-2020, 07:48 PM | #38 | |
X5 M50i
110
Rep 51
LI2002tii43.50 |
07-21-2020, 08:11 PM | #39 | ||
Rep 2,609
https://bimmercode.app/cars/g05/
09-27-2020, 02:34 PM | #40 |
Rep 7
Hi everyone im new to this thread i have a 2021 BMW X5 M50I , and when im parking in Reverse and i change to Drive the camera on the screen does not change to Front view. Is there a coding option for this with bimmer code or e sys ?
09-27-2020, 04:04 PM | #41 | |
Rep 2,609
The key nuance is that the coding change fix seems to take hour-to-days-to-weeks to start working and we don't know why.
09-27-2020, 06:34 PM | #42 | |
Rep 7
Hi thank you for the reply i have carefully read the thread and understand what needs to be done. Can you please guide me where i can download or buy ESys/ESysX . |
09-30-2020, 10:02 AM | #43 |
Rep 7
Hi thank you for the reply i have carefully read the thread and understand what needs to be done. Can you please guide me where i can download or buy ESys/ESysX ?
10-01-2020, 12:15 AM | #44 |
Rep 63
Not to be rude or mean (although I guess there is no kind way to say this), but if you seriously think you can figure out "what needs to be done", but can't Google EsysX and find where/how to purchase it... I have concerns about your chances for success.
