      05-20-2020, 11:31 AM   #1
Mjbmw1
Mjbmw1's Avatar
Drives: X5 M50i
2020 X5 M50I AutoBahn with Drive Recorder
This is a 2020 BMW X5 M50i all packages except DHP. I went with the Air and Acoustic Glass. You can barely hear the wind noise at 260!
If yall like the video let me know. I had an issue with the SD card and lost some footage.
The 4 camera view is with Drive Recorder
      05-22-2020, 07:45 PM   #2
mattchew 2020
Drives: 2020 BMW X5 M50I
That awesome!!
      05-23-2020, 11:01 AM   #3
DBV
DBV's Avatar
779
Drives: G87 M2, G20 330d, Brabus Smart
2023 BMW M2  [8.75]
2018 Brabus Smart  [0.00]
2021 BMW 330d  [0.00]
Nice!
I've been trying to get an answer for this forever:
Does the Drive Recorder automatically record and then record over old footage if it isn't downloaded? Is it automatically always recording?
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart
Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp)
      05-23-2020, 12:45 PM   #4
UltraDave
UltraDave's Avatar
127
Drives: 2020 BMW X5 M50i
That’s cool! Did you have to refill your gas tank after? lol
      05-23-2020, 01:55 PM   #5
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Originally Posted by DBV View Post
Nice!
DR is always recording while the engine is running. It is not recording at all with engine off. This is the facility that allows up to 20s pre-trigger recording to be saved. You do not have access to the entire recording, however, only to pre- and post-trigger event clips. Trigger events are only one of a) manual trigger to record, or b) whatever the car sensor set detects as a collision. With all 4 cameras and 20s pre-trigger recordings, you have 10 triggered clips that are stored. I believe there is a setting where it will delete oldest one when you hit number 11, but I am not completely sure. On the other hand, since practically it only records accidents, how many accidents do you anticipate having before downloading or clearing the clips? :-)
      05-23-2020, 02:00 PM   #6
DBV
DBV's Avatar
779
2023 BMW M2  [8.75]
Nice!
Thanks for clarifying. Sounds like one should, theoretically, be able to hit record and get whatever happened in the 20 seconds before hitting record and the 20 seconds after. I'm thinking along the lines of some idiot moves happening and wanting it to be recorded. Guess you could save the Drive Recorder Start Button as a hot Key on the dash and then use it that way.
@DBV_
      05-23-2020, 02:03 PM   #7
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Nice!
Yes, when configured as such (which I suspect is by far the most common configuration), you do get 20 seconds of idiocy before and 20 seconds after manual trigger. Unfortunately you can't assign one of the 8 buttons to START recording (but you can assign one to access the DR app, which is a wasted assignment). You can, however, choose DR app as one of the tiles on your home screen and tapping that DOES START recording.
      05-23-2020, 03:27 PM   #8
DBV
DBV's Avatar
779
2023 BMW M2  [8.75]
Nice!
Good to know! Thanks
@DBV_
      05-23-2020, 05:48 PM   #9
JoseSportM
JoseSportM
JoseSportM's Avatar
414
Drives: BMW G42
In switzerland is not available.
What this need to work? Connect Drive?
Is not possible to configure to a country like Germany and activate this?
Does this need coding?
Sorry but don't know nothing about this as this is not available.
Thanks in advance
      05-29-2020, 10:19 AM   #10
VTENGR
1053
Drives: 2020 X5 M50i
You can long press the panorama camera button to start recording. I don't know if it's setup that way by default, but there's an option for it in the DR menu. That's how I have mine setup. You also have to change the record setting for 20s before and 20s after - I don't think it's setup that way by default.
DBV778.50
      05-29-2020, 11:07 AM   #11
DBV
DBV's Avatar
779
2023 BMW M2  [8.75]
THERE we go!! Thank you Sir!
@DBV_
VTENGR1052.50
      06-07-2020, 06:14 PM   #12
Mjbmw1
Mjbmw1's Avatar
Drives: X5 M50i
Nice!
Drive recorder automatically record during a collision but you can also trigger it to record for 40 seconds. If the space fills up it doesn't let you record anymore. Not sure if collision overwrites the old data.
      06-07-2020, 06:15 PM   #13
Mjbmw1
Mjbmw1's Avatar
Drives: X5 M50i
Thanks in advance
I am in Germany and have it activated.. but I have US Spec.
      06-07-2020, 06:20 PM   #14
Mjbmw1
Mjbmw1's Avatar
Drives: X5 M50i
lol ya but I mainly drive around 200 to 230 daily on Autobahn. I did have a fun race with a Porsche GT2R to 260 but then he passed me.. car was only in 6th gear at 260 and still had 2 more to go but the speed lock stops it.
      06-08-2020, 01:49 AM   #15
JoseSportM
JoseSportM
JoseSportM's Avatar
414
Drives: BMW G42
Thanks in advance
But then the connect drive is from USA right not Germany.
      06-10-2020, 04:08 PM   #16
Mjbmw1
Mjbmw1's Avatar
Drives: X5 M50i
Yes I have connected drive from the US site but its working in Germany.
Tags
autobahn, m50i
