06-11-2020, 10:38 PM | #1 |
265
Rep 345
Drives: 2019 X5 40i M
Anti-Dazzle Help
So I removed 5AP and VO coded the appropriate modules but it is still not active. On my F15 there were additional steps necessary to code the European Spec. Does anyone have more information?
2019 X5 X40iM
06-12-2020, 07:26 AM | #2 |
Rep 2,609
No, nothing more should be required. Are your headlights on auto high-beam assist mode per pic below? Which ECUs did you code (not Code NCD) after removing 5AP? Does you car have the FLA option (high-beam assist)? How are you determining that they are "working" or "not working"?
06-12-2020, 07:56 AM | #3 |
265
Rep 345
BDC body3
Hu_mgu Both FLm DKombi And Kafas Yes I have the auto high beam on. When I saw it is not working, every time I approach a car or a car comes from the other direction, the high beams immediately shut off. There is no adjustment.
2019 X5 X40iM
06-12-2020, 08:12 AM | #4 |
1053
Rep 1,952
And you have the lazer lights? Nothing additional was needed when I decoded the anti-dazzle. Just have to make sure you have Auto-Highbeam on. I did notice that it will shut off the high beams when a car approaches if it determines it can't tunnel the beam effectively. This seemed to happen if the car was coming on a bend or if it wasn't dark enough outside.
06-12-2020, 08:23 AM | #5 |
265
Rep 345
They have shut off every time for me. No adjustments are being made on the high beams. I know how it is supposed to work because I had them on my F15.
2019 X5 X40iM
06-15-2020, 10:33 PM | #6 |
265
Rep 345
Have confirmed that removal if 5AP is not sufficient to truly activate anti-dazzle. Am working with Opasha to identify the true solution. Will post an update soon.
2019 X5 X40iM
06-15-2020, 11:18 PM | #7 |
Rep 63
I have a 2020 US X5 loaded, all I did was the 5AP VO removal and wrote to BDC, DKOMBI, KFASA and FLM2, but pretty sure all I needed was to write it to BDC only. Anyway mine work perfectly, just have to make sure auto button is used as Lexx pointed out.
06-15-2020, 11:38 PM | #8 | |
Rep 2,609
Also, I am sure "Turkey" is a typo, but I have no clue of what was actually supposed have been typed? And what or who is "Opasha"?
06-16-2020, 12:18 AM | #9 | |
Rep 63
06-16-2020, 04:37 AM | #10 | |
1197
Rep 1,587
In TL's case, it acts like the old fashioned HBA - binary on or off. TL has an old build - 11/18, not sure on i-step version. |
06-16-2020, 07:54 AM | #11 |
1053
Rep 1,952
Mine was working perfectly prior to the OTA update - Haven't had a chance to test it since.
I could tell it was working when driving behind a car on a back country road. The high beams were on, lighting up the shoulders on either side of the car in front of me, but wasn't shining on the car. I got a chuckle out of it b/c it was like I was helping the car in front of me navigate this dark road. Also on the same drive, cars would approach in the opposite direction, and you could see the high beams dance as the car approached and then turn off, if it deemed necessary. It was very cool to see. |
06-16-2020, 08:09 AM | #12 |
1197
Rep 1,587
Yep that's how they are supposed to work, so sounds like Trojanlaw has another issue considering you both have US spec cars.
Assuming the hardware is the same, and coding has been completed correctly, the main possibility is build/i-step version |
06-16-2020, 08:24 AM | #13 |
1053
Rep 1,952
Yep - my build prior to the OTA was 11/2019.41
06-16-2020, 09:21 AM | #14 |
265
Rep 345
My istep version is 03/2020.40
VTENGR - would you mind sending me your CAFD files so I can do a compare with mine. Thanks so much.
2019 X5 X40iM
06-16-2020, 09:30 AM | #15 |
1197
Rep 1,587
06-16-2020, 03:41 PM | #16 | |
Rep 113
I'll jump in
LexxM31698.50 |
06-17-2020, 05:07 PM | #17 |
265
Rep 345
Opasha is actually working with me on this. I was one of his main guinnea pigs for the F15.
2019 X5 X40iM
06-17-2020, 05:12 PM | #18 |
265
Rep 345
No we can't. Thanks for VTENGR, I have been able to identify several files in my BDC_Body ECUs that did not code to the same as a later build. I am coding those in tonight and hope that will do the trick.
I will report back after. Thanks again to ifr and VTENGR for all of the help.
2019 X5 X40iM
06-20-2020, 04:26 PM | #19 | |
Rep 113
Anti-Dazzle
06-22-2020, 09:50 PM | #20 |
265
Rep 345
Not yet. My files did have some differences from VTEGNRs after VO coding. Trying to work through them. Wondering if my 11/18 build has anything to do with it.
2019 X5 X40iM
1coolF15D201742.50 |
06-22-2020, 10:48 PM | #21 |
Rep 113
Thanks
06-24-2020, 10:16 PM | #22 |
265
Rep 345
No luck yet. Have even coded the FLMs to full ECE Spec.
2019 X5 X40iM
