06-26-2020, 04:20 PM | #1 |
Rep 98
Why do these setting constantly reset?
After a recent trip to the dealership to have some extensive work done, my iStep was updated to 03/2020. That wiped the LCA I had coded before.
I then tried to get LCA coded again but it failed. Now each time I wake the car (been locked for about 20mins) the following settings have unticked themselves, the ambient light has changed to orange and my steering wheel will not extend. Any one else had/having similar issues? |
06-27-2020, 05:27 AM | #3 |
Rep 98
06-28-2020, 08:28 AM | #4 |
PANIC!
481
Rep 823
My hatch height position also resets. If I leave it defaulted to fully open, it will hit the open garage door above the car. The second lowest setting will prevent that and yet every time I set it to that height in iDrive, it won’t stick the next time. It’s weird and frustrating.
06-28-2020, 08:32 AM | #5 |
Rep 98
So I did do a vehicle reset and it appeared to solve the problem. I have done some coding but that seems to be ok now. Car, general settings, scroll to the bottom and reset everything. Log back in with your details and all should be well.
I had coded the head until and I suspected that was the issue. Nothing reported in any forums but it seems to have severed the link between ConnectedDrive and the car. The reset looks as though it's resolved it. |
SWBOS48.00 |
06-28-2020, 07:36 PM | #6 |
Rep 106
I've recently seen the exact same thing. I've even gone so far as checking the boxes again then rebooting iDrive, !BOOM! gone again.
No coding changes or software updates since January 2020 so I know it's not something I messed up. The car doesn't get driven anywhere near as often right now though so I suspected battery. Main reason that I suspected this was that comfort access seems to not work if I don't drive every day. Will try the reset option when I'm next in the car (and if it hasn't remembered the last settings). Thank you. |
07-03-2020, 06:23 PM | #7 | |
Rep 106
