09-19-2023, 10:37 AM | #24 |
17488
Rep 25,115
Well let’s all bury our head in the sand then…. I mean it’s not like ice is melting and the planet is heating at a horrific rate.
RIP Grand kids and ‘normal’ weather.
My car made front page of Bimmerpost
09-19-2023, 10:40 AM | #25 | |
Rep 5,114
09-19-2023, 10:45 AM | #26 |
Rep 1,153
Track use seems to be the last thing people will do with EVs. Long distance is still way better with ICE cars. I have two kids, 7 & 8 and bettwen the multiple snack and bathrooms breaks, I just can't even imagine having a full EV right now. 4 road trips last years and they would all have been hell with an EV.
2020 M2C 24.04.2020 delivery - Sold 24.08.22
09-19-2023, 10:49 AM | #27 | |
Rep 98
For those of you that really, really can't take a 20 minutes break every 300 miles on a road trip, options are coming. |
09-19-2023, 10:49 AM | #28 | |
Rep 682
BMWFLYNN54.00 |
09-19-2023, 10:52 AM | #29 |
Rep 2,008
It's gonna be easy to break the so called record... look at the plaid, 7:25 vs 7:18 on the m4 csl (which was 7:20 until just recently) a heavy ev can still match most performance cars on a track like that. Take it to the GP track and you won't have brakes after the first few laps (heck I lost brakes after 2 in a non ccb m5 flying down the straight at 140 mph and realizing I had to pray turning the car 90 degrees was going to be enough to slow it down and it barely was) simply because it's a track that doesn't have high speed corners, they're all technical turns with fairly low entry speeds, brief acceleration back up to sometimes triple digits and back down to low doubles almost instantly which is taxing on both tires and brakes. But the nordshleife? Never gonna be an issue, there's like 2 slow turns, everything else is high speed 130 mph+ corners and as long as you have grip which Ding Ding Ding more weight = more grip on tires (think downforce) you're going to get fantastic times no matter what as long as the power is consistent over a large range of the battery and cooling can be properly implemented (I know for a fact the plaid cut power during its runs due to overheating). But if you think about it realistically you keep an ICE race car light for acceleration purposes then add globs of weight at speed for turning so if you can have a 6k lbs car that can accelerate the same way, then add even MORE weight at speed the grip will be astronomical for high speed turns, not so much slow speed technical turns like a chicane where weight transfer now becomes an issue or under heavy braking. Plus ev has low center of gravity meaning it doesn't pose a rollover risk at high Gs. You can compare the m4 csls 1.1g to the plaids 1.08 on the skidpad, and the plaid is only with pilot sport 4s vs the csls cup 2s... so... you see my point? Same cornering capability even at lower speeds.
F32Fleet3574.50 |
09-19-2023, 10:56 AM | #30 |
2716
Rep 1,664
They are giving them away. Can’t get rid of them. Check out leasehackr forum. Most of the deals are on EVs and between discounts and incentives take $30,000+ off the MSRP. $120,000 cars leasing for less than $800 a month
09-19-2023, 11:05 AM | #31 | |
Rep 2,008
MikeM6148.00 F32Fleet3574.50 SoCali E361000.00 BenF87M270.00 brava09767.00 LuckyBrand1317.00 Sedan_Clan25113.50 |
09-19-2023, 11:19 AM | #32 | |
Rep 3,410
I’m glad you brought that up because it seems like BMW M continues to chase tesla. It’s aggravating because Porsche doesn’t seem to care as much and continues to produce lightweight vehicles. Naturally they also have inferior EVs as well. |
09-19-2023, 11:22 AM | #33 | ||||
Rep 6,697
Tell me you haven't driven a performance EV without telling me you haven't driven a performance EV. Friend of mine regularly embarasses many ICE cars at Buttonwillow and Laguna in his Taycan Turbo. The reaction of drivers after they get passed by him is "wow, I didn't know EV's could drive like that". Quote:
09-19-2023, 11:25 AM | #34 |
Rep 280
TBH I'd consider an EV if they had manuals.
IDK how that would work but I strongly dislike 2 pedal cars. These are my terms lol
23 A91-MT CULG, 04 M3 Carbon Black/Cinnamon 6MT, 05 M3 Interlagos Blue/Black 6MT Dinan S3-R,
00 M5 Royal Red/Extended Caramel, 00 Z3M Coupe Cosmos Black/Dark Gray/Black, 04 X5 Toledo Blue/Sand Beige 6MT |
Bimmerfun827201.50 LuckyBrand1317.00 |
09-19-2023, 11:43 AM | #37 | |
Rep 6,697
I played with the settings, set the reference consumption at 350 Wh/mile at 65, which is high, and set the speed up to 125% of the limit and STILL it only shows two stops and a total trip time of 6.5 hours. It's only a 375 mile run. Did you have like a 50 MPH headwind? I'm not saying you're lying....but your situation is definitely not the norm. I've done 400 plus miles in one day in freezing weather with only 2 charging stops. And that was on a Model 3 performance with only a 75 kWh battery. |
09-19-2023, 11:44 AM | #38 |
Rep 6,697
Not sure what to say to this. Are you talking about the 'Ring specifically? Pretty sure that the recently released Ioniq N can do two full laps at 100% power. Also, it's not total charge, it's the thermal. I'm not sure if a Plaid can make two laps in a row without throttling, but you could easily do more than one lap on a charge.
If you're talking about a normal track, say from a Taycan Turbo, you can get 15-18 minutes of full lapping pace before you start to run into thermal limitation. |
09-19-2023, 11:46 AM | #39 |
Rep 598
Instead of just throwing mindless comment find online what range will Tesla get on the track using all of its performance. Than come back with an answer.
09-19-2023, 11:48 AM | #40 |
Rep 6,697
Buddy of mine can do two full lapping sessions at Lime Rock Park in his Model 3 Performance, no degredation due to thermals, before he has to leave to go to the Supercharger.
09-19-2023, 11:52 AM | #41 |
Rep 598
Exactly my point. I don’t deny ev’s usefulness in some instances. They work for some and don’t for others. But to think that any ev with available tech for masses is suitable for lapping Nurburgring better than ICE cars is pipe dream at least for now. Unless it’s one lap only.
brava09767.00 |
09-19-2023, 11:54 AM | #42 |
Rep 598
Let me put it this way. Just because you can lap any track in 7 series or S class doesn’t mean it’s the right tool for the job.
09-19-2023, 11:59 AM | #44 | |
Rep 942
Drives: 2016 BMW X5
TheMidnightNarwhal2657.00 |
