      04-22-2019, 05:13 AM   #45
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
Originally Posted by skalberti View Post
The. Blendmount just has a cleaner look to me. Plus I like the fact that I can have my BV and radar stacked neatly together. It's just a personal preference, plus I think you get a little more field of view with the camera not stuck against the windshield . The BM makes adjusting the camera easy too. You could always let your installer install and add the Blendmount later yourself. They're easy to install.
I finally decided late yesterday to take the path you described.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      04-22-2019, 11:35 AM   #46
Xeno
Xeno's Avatar
315
You can't attach two BM's to your mirror. I purchased the BV 2030 for the G05 and then bolted my radar mounting clip to the BV 2030. I didn't want anything stuck to the windshield. I've had to re stick the camera on the back window already.
I just heard from BM moments ago and they said based on a photo in a related thread here, that I should use BBV-2018. They do not official support the notion of adding a RD clip - like the V1 - to this but are aware 'it has been done'.
I am reviewing your photo in post #1 to better understand how this work.
BTW, have you encountered the problem described in this RDF thread? https://www.rdforum.org/index.php?threads/74874/
      04-22-2019, 03:16 PM   #47
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
Haven't had any problems with my BV setting my R3 off. I have read issues of the V1 falling in the G05 due to the gesture control.
Looks like they've added a new BV 2018 BM. That wasn't available when I ordered, but I know the BV 2030 fits perfect and worked for the way I wanted to bolt my radar detector clip to it. I've attached some detailed images. My radar detector clip is circled in red. In the other pic you can see the 2 screws I used to mount the radar clip the the BM.
It's good to be bad
Xeno315.00
      04-22-2019, 05:08 PM   #48
Xeno
Xeno's Avatar
315
Very helpful. Thank you.
I started a thread some months ago when I had to disable laser on my V1 due to the conflict with gestures that I use. By contrast, my R3 and now my R7 do not react since they are not as sensitive to laser.
skalberti614.00
      04-23-2019, 08:46 AM   #49
Xeno
Xeno's Avatar
315
It is stormy today and difficult to get good pictures, but here is my current install. I will test this and see if using the BM would be an advantage for me.
      04-23-2019, 08:56 AM   #50
skalberti
skalberti's Avatar
The BV would be about the same location in the center, but sitting about 2" away from the windshield and your V1 would be right below it.
It's good to be bad
      04-23-2019, 09:12 AM   #51
Xeno
Xeno's Avatar
315
My installer claims that since I have 80% tint on the windshield and with this placement that glare would be reduced to the point that I may not need to add a polarized lens. Do you use a polarized lens?
      04-23-2019, 09:17 AM   #52
skalberti
skalberti's Avatar
No, not at all. Still trying to decide if we need the 80% tint on our G05 like we had on our F15. Wondering just how much heat is reduced?
It's good to be bad
      04-23-2019, 10:47 AM   #53
Xeno
Xeno's Avatar
315
I had 80% in my F15 and now my G05. I think it makes a difference, but I did not do a thermometer check before the tint was done in December.
      04-28-2019, 09:26 PM   #54
kja2ja
Drives: 2015 BMW 428i
Question on the mount
Hi, you said " BBV 2030 dash cam mount and the BNR UC2 R3 clip and bolted them together". Can you show few more pictures on the how to join them? i have a Escort 9500 with BBV 2017 specialty version.
Thanks
      04-28-2019, 09:29 PM   #55
skalberti
skalberti's Avatar
Thanks
It won't work with the BV 2017. The BV 2017 doesn't work for the BlackVue by itself in the G05. I posted some close up pics a few posts ago.
It's good to be bad
      04-29-2019, 10:26 AM   #56
Xeno
Xeno's Avatar
315
I am not able to login to the BV cloud today. Is the server down or is this specific to me?
      05-29-2019, 12:25 AM   #57
OzJedi
Australia
107
Drives: X5 2019 40i MSport Carb Black
Power Magic EZ
Anyone installed PowerMagic EZ https://www.blackvue.com/power-magic-ez/ on G05?
I am planning to buy one but read online G05 doesn't support it?
I drive about an hour daily and rest of the time car is parked so will it be a good idea to enable parking mode? Will it drain the battery?
      05-29-2019, 09:01 PM   #58
Xeno
Xeno's Avatar
315
I have it and for the rest of the story see this thread:
https://g05.bimmerpost.com/forums/sh....php?t=1612639
      06-01-2019, 08:15 AM   #59
007bandido
Switzerland
Drives: 2019 G05 30D M
Hello,
I took the same path to install my 750 2CH + PMP into my new G05. I plugged BATT in fuse 20 and ACC in fuse 53. Thank you for the tips but... I have a problem.
When I connect the PMP, I have an error with Tires Pressure. The car can't measure the entire cycle and hangs with an error.
Maybe some interferences with my old PMP (2013)? Any ideas ?
Thanks and regards,
Miguel
      06-25-2019, 09:31 PM   #60
Xeno
Xeno's Avatar
315
Has anyone had overheating issues with their BV in their G05?
I have not, but I have 80% windshield tint and will put up shades when we start consistently going 90 and above.
Here is a thread about some of have overheating issues and experiments for resolutions: https://www.rdforum.org/index.php?threads/88944/
      06-25-2019, 10:06 PM   #61
Hchhuor
Drives: 2016 LX570
I saw dashcam over heat shut down then start back up while I did live view from my phone. Dashcam connect to my nighthawk mobile hotspot.
      06-26-2019, 09:57 AM   #62
BMW lifer
United Kingdom
29
Drives: G05 40i 2019
It's crucial that windscreen-mounted dashcams is only stuck to clear glass, not those small areas which are masked by a pattern to minimise sun glare. Those areas get much hotter than the rest of the windscreen
      06-26-2019, 04:22 PM   #63
skalberti
skalberti's Avatar
I've had no issues with ours here in Tx. We don't have windshield tint yet, but I'm looking in to it.
It's good to be bad
      07-01-2019, 08:13 AM   #64
Xeno
Xeno's Avatar
315
Is there a better way to position the sun shade to limit overheating the BV?
      07-01-2019, 08:29 AM   #65
natahoa
Retired soccer mom
natahoa's Avatar
Drives: x5 40i 2019
I bought an inexpensive crosstour dual dash cam and I love it. It takes amazing video quality front and back. But you have to remove the SD card to see the vids, no WiFi. Next one ... but I feel I have substantial protection for vandalism or a crash.
I didn’t fish wires through anything, but was able to hide and protect them under floor mats everywhere except on the dash.
Thanks for posting. Great info!
skalberti614.00
      07-05-2019, 06:53 PM   #66
skalberti
skalberti's Avatar
That's about the only way to put the sunscreen. Any other way would obstruct the camera in parking mode.
It's good to be bad
Xeno315.00
