      12-23-2021, 07:31 AM   #45
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
Originally Posted by emaniat View Post
Is there a size difference with calipers and rotor dimension between an X5 40i M Sport (with the upgraded brakes) and an X5 M or X5 M Competition? I want to use the cross drilled rotors from the comp on the 40i M Sport. I've always used cross drilled's. I have a tendency to warp solid rotors.
Ja, there are size differences.
X5M/C 6-pots versus 2NH M Sport 4-pot but they'll bolt on differently:
"G05 calipers bolt directly to the hub from the back...... F95 calipers bolt to a bracket from the top, which then bolts to the hub from the back.
BMW will not sell you those brackets by themselves.... they only come as part of the caliper."
Front rotors are 395 x 36 on both but rears are larger on X5M @ 385 versus 2NH 375 x 24
A forum member upgraded their 2NH M Sport brakes to X5M and documented the process starting with this post:
https://www.bimmerpost.com/forums/sh...php?p=26771351
      04-26-2022, 11:26 AM   #46
emaniat
Drives: 2022 X5
Thanks for the info. Sorry for the late reply. I pulled the trigger back in February and ordered MY22.
      03-15-2023, 03:49 PM   #47
S68 X5MC
DD214
S68 X5MC's Avatar
Drives: 2024 X5M Competition
I'm trying to verify that the below are the correct ceramic pads before I order. I have a 2023 X5 45e M Sport and nothing really computes when I put that year in, so I put 2022 X5 M50i and I get the right pads (same calipers if people didn't know). It shows that it's good for my vehicle with the M brake calipers and wanting to double check.
Power Stop Z23-1868. Front
Power Stop Z23-1850. Rear
      11-20-2023, 08:59 PM   #48
Kevin_The_Clean1
Kevin_The_Clean1's Avatar
Drives: 2020 X3 MC
Hello fellas. Sorry to dig this post up. Hoping that one of you gurus can quickly help me out. I'm selling the factory front brake calipers from my 2020 F97 X3 M to a gentleman with a 2020 X5 X-Drive 40i.
I know he has the non M-sport brakes up in front. Because I looked up the RealOEMParts digram with his Vin # & it says he has the 348x30mm rotors & not the 395x36mm rotors that my X3 M came with.
Other then larger rotors, is there anything else he may need for this to be plug & play... ? His dust shields looks to be exceptionally huge & real hoping he doesn't need some (impossible to find) adapter bracket. THANK YOU in advance... !
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten
2011 E90 335i M-Sport - Daily Driver
2017 F87 M2 - Sold & missed
2020 F97 X3 M Competition - Finally arrived ///
      11-21-2023, 12:49 PM   #49
gfeiner97
Drives: X540i
I haven't done the conversion myself so I can't speak from experience but judging by the contents of the official retrofit kit that BMW sells, part number 34112458883, he will need more parts than just rotors and calipers. Take a look here at what all is included with that kit: https://www.bmwpartspros.com/oem-par...ed-34112458883
      11-21-2023, 01:54 PM   #50
Kevin_The_Clean1
Drives: 2020 X3 MC
Thank you man. I've seen that kit before. But technically speaking, from the diagrams & part number look ups it appears there's a much simpler, easier & cheaper (to a certain extent) way to upgrade the front calipers. The ones I'm selling are also an option that's on the table. Can someone please verify no additional brackets are requires to make this work.
Do the F97 X3 M calipers work as a direct bolt on to a 2020 X5 X-drive 4.0 with thing more then the larger corresponding rotors... ?
https://www.realoem.com/bmw/enUS/par...-X5_40iX&mg=34
      11-27-2023, 04:04 PM   #51
Kevin_The_Clean1
Drives: 2020 X3 MC
Right now I have some serious buyers lined up & need to know if this (the F97 X3 M front calipers) is a direct bolt for the 2020 X5 X-drive 4.0 Any word yet on this guys... ?
      04-06-2024, 09:06 AM   #52
rjanota
Drives: 2024 BMW X5 M60i
Originally Posted by Abegweit View Post
There are actually 3 different brake setups available for the G05. 40i without 3rd row gets the basic spec, add 3rd row and/or 50i gets first upgrade, M Sport gets M upgrade. Full details are in the technical training documents pinned in this forum. No speculation required.
Where I can find those technical details pls? Where are documents pinned? Thank you
      04-06-2024, 12:14 PM   #53
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
search “Auricom what brakes are these?” he provides a great write up and explanation
