      04-02-2019, 11:24 PM   #23
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Originally Posted by gtank View Post
I just ordered some spacers...guess I'll be a guinea pig on this one.
Purchased 5mm front and 15mm rear from ECS. Should have them installed next weekend if I can find the time.
Nice!!! Can't wait for pictures.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      04-03-2019, 03:06 PM   #24
bizfiend
bizfiend's Avatar
146
Drives: Renting Corolla lol
Did you choose the ones for F90 cause I didn't see a category for G05.
      04-03-2019, 07:51 PM   #25
gtank
Drives: 2019 BMW X5
Yeah, I used G30 as my search, but the F90 is the same as well.
      04-04-2019, 08:02 PM   #26
jra0113
jra0113's Avatar
Drives: 2019 X5 xDrive 50i
You getting those spacers installed this weekend?
2019 BMW X5 xDrive50i
2017 F150 King Ranch
1967 Camaro Pro Touring
      04-04-2019, 08:52 PM   #27
gtank
Drives: 2019 BMW X5
Yep, doing it myself at a garage where I can rent lifts on Saturday.
Called around and most shops wouldn't install for me.
I'll take pictures.
      04-05-2019, 09:31 PM   #28
gtank
Drives: 2019 BMW X5
Parts check and a before photo.
X54TH899.00
      04-05-2019, 09:48 PM   #29
X54TH
Member
X54TH's Avatar
899
Drives: 2019 X5 40i M Sport
Well done. You got my attention!
      04-05-2019, 11:11 PM   #30
bichoo
bichoo's Avatar
281
Drives: BMW X5 40i M-Sport
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold)
2012 BMW X3 28i (sold)
      04-06-2019, 08:44 AM   #31
jra0113
jra0113's Avatar
      04-06-2019, 03:41 PM   #32
gtank
Drives: 2019 BMW X5
Action shot.
$6 wheel hanger from Amazon is a great idea if anyone else decides to do this mod DIY.
X54TH899.00
      04-06-2019, 03:46 PM   #33
gtank
Drives: 2019 BMW X5
Right side completed.
X54TH899.00
      04-06-2019, 03:48 PM   #34
gtank
Drives: 2019 BMW X5
Left side stock for comparison
X54TH899.00
      04-06-2019, 03:52 PM   #35
gtank
Drives: 2019 BMW X5
End result. Very hard to capture in photos with this car!
5mm is definitely the right size for the fronts with these wheels. You probably could do 20mm in the back, but I'm happy with 15mm.
Appreciate 3
X54TH899.00
MPoweRo428.00
      04-06-2019, 04:03 PM   #36
gtank
Drives: 2019 BMW X5
And lastly, here are the parts I used.
ECS 5mm Wheel Spacer Kit & ECS Conical Seat Bolt Kit, ES#: 3006221
https://www.ecstuning.com/b-ecs-part...002411ecskt21/
ECS 15mm Wheel Spacer Kit & ECS Conical Seat Bolt Kit, ES#: 3006111
https://www.ecstuning.com/b-ecs-part...002411ecskt17/
Steel Wheel Hanger Alignment Pin Guide Tool - 14x1.25 / M14x1.25
https://www.amazon.com/dp/B00MWAQLJK..._UlrQCb5CJ2H3P
Anti-Seize compound for use between the spacer and the wheel only:
http://www.amazon.com/dp/B008RMT9LO/..._BmrQCbW36RZNC
X54TH899.00
      04-06-2019, 07:39 PM   #37
X54TH
Member
X54TH's Avatar
899
Well done gtank. Appreciate taking the time to do this. I like the setup on the front and rear. If you could redo it would you 20mm?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
      04-06-2019, 08:01 PM   #38
gtank
Drives: 2019 BMW X5
I'm happy with the 15mm, which will work better with my Cooper tires, but if I was running the stock tires, I'd probably go for the 17.5mm set. It's pretty hard to gauge until I've driven it around and look at it more.
https://www.ecstuning.com/b-ecs-part...411ecs03a18kt/
Here's a quick comparison to stock (left is with spacers).
Appreciate 4
X54TH899.00
jimv0326.00
LexxM31698.50
jra0113427.00
      04-06-2019, 08:54 PM   #39
X54TH
Member
X54TH's Avatar
899
Perfect comparison. Big difference. Looks great!!
Now that I'm looking at it the 15mm are just right.
      04-07-2019, 04:53 PM   #40
Jrunr
Germany
188
Drives: 2019 BMW X5 M40i - G05
Looking forward to hear any driving impressions you have with these spacers installed.
      04-07-2019, 05:02 PM   #41
gtank
Drives: 2019 BMW X5
Really no difference from stock.
      04-07-2019, 05:14 PM   #42
bizfiend
bizfiend's Avatar
146
Do you think 12mm or 10mm would work in the front?
      04-07-2019, 07:01 PM   #43
gtank
Drives: 2019 BMW X5
Depends on the wheels you are running.
I think it would be too much with the 740Ms.
      04-08-2019, 05:15 PM   #44
r33_RGSport
@gtank , looks good.
From your pictures, here are my concerns.
- Front Spacer, it is installed backward. I hope it is corrected before the wheel is installed.
- Front Spacer, it doesn't seems to have enough hub lip left for the wheel to sit properly. I understand that you use the wheel hanger, but your wheel need to sit on the hub lip instead of just relying on the 5 lug bolts to transfer the load of the car to the wheel.
