      04-08-2019, 09:00 PM   #45
gtank
Drives: 2019 BMW X5
Originally Posted by r33_RGSport View Post
@gtank , looks good.
From your pictures, here are my concerns.
- Front Spacer, it is installed backward. I hope it is corrected before the wheel is installed.
- Front Spacer, it doesn't seems to have enough hub lip left for the wheel to sit properly. I understand that you use the wheel hanger, but your wheel need to sit on the hub lip instead of just relying on the 5 lug bolts to transfer the load of the car to the wheel.
That picture was a mock-up, that being said, I'm gonna have to take the wheel off to know for sure. I'm assuming the divots are there to avoid seizing against the hub and little else.
The wheel hanger was just there to help with alignment, which can be a pain to line up single-handed. It seemed like it had enough lip, but I'll investigate when I take the wheels off.
      04-08-2019, 10:33 PM   #46
bizfiend
bizfiend's Avatar
146
Drives: Renting Corolla lol
I was told by a seller who has tried these that the 5mm spacer is not hubcentric and they suggest 15mm front and 20mm rear. Do you think this would be ok.
      04-09-2019, 08:51 AM   #47
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
I can't suggest anything yet until I personally see and install one.
I need to collect data from this car.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      04-20-2019, 02:19 AM   #48
bizfiend
bizfiend's Avatar
146
12mm front
15mm rear
Lowest air suspension height.
22" 742M
Appreciate 3
gtank117.50
X54TH899.00
MPoweRo428.00
      04-20-2019, 07:50 AM   #49
gtank
Drives: 2019 BMW X5
Looks great
      04-20-2019, 01:18 PM   #50
bizfiend
bizfiend's Avatar
146
Originally Posted by gtank View Post
Looks great
Thanks, trigger was finally pulled and I'm satisfied. Lucky the seller was legit with the fitting.
      04-20-2019, 03:57 PM   #51
Penguino
Penguino's Avatar
1605
Drives: A car.
12mm front
15mm rear
22" 742M
Any side profile pics?
"Beware of false knowledge; it is more dangerous than ignorance."
      04-21-2019, 06:43 AM   #52
frank19x5
frank19x5's Avatar
138
Drives: 2019 BMW X5 xDrive 40i
Yep, doing it myself at a garage where I can rent lifts on Saturday.
Called around and most shops wouldn't install for me.
I'll take pictures.
Why wouldn’t shops install for you?
      04-21-2019, 11:14 AM   #53
bichoo
bichoo's Avatar
281
Drives: BMW X5 40i M-Sport
12mm front
15mm rear
22" 742M
Looks great!
Which brand spacers did you buy? Notice any difference in ride and/or handling?
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold)
2012 BMW X3 28i (sold)
      04-21-2019, 12:21 PM   #54
bizfiend
bizfiend's Avatar
146
Originally Posted by bichoo View Post
Looks great!
I just got them from eBay.
You have to tell him what size to send you.
Ride and handling is the same so far.
https://www.ebay.ca/itm/4x-12mm-Long...72.m2749.l2649
bichoo280.50
      04-21-2019, 08:22 PM   #55
bizfiend
bizfiend's Avatar
146
More spacer porn.
12mm front 15mm rear.
Front/rear reflector delete.
Black exhaust tips.
Ceramic coat in May.
Scheduling appointment to install floating center caps
      05-06-2019, 06:31 PM   #56
Sauveur2019
Drives: BMW X5 G05
M sport badge
Just ordered m sport40.
Do they come with the m sport badge on sides ?
      05-06-2019, 06:33 PM   #57
X54TH
Member
X54TH's Avatar
899
Drives: 2019 X5 40i M Sport
Nope but I got these gloss black ones on eBay
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
bichoo280.50
      05-07-2019, 10:41 PM   #58
spike5150
Drives: 2020 X5 M50i
And lastly, here are the parts I used.
ECS 5mm Wheel Spacer Kit & ECS Conical Seat Bolt Kit, ES#: 3006221
https://www.ecstuning.com/b-ecs-part...002411ecskt21/
ECS 15mm Wheel Spacer Kit & ECS Conical Seat Bolt Kit, ES#: 3006111
https://www.ecstuning.com/b-ecs-part...002411ecskt17/
Steel Wheel Hanger Alignment Pin Guide Tool - 14x1.25 / M14x1.25
https://www.amazon.com/dp/B00MWAQLJK..._UlrQCb5CJ2H3P
Anti-Seize compound for use between the spacer and the wheel only:
http://www.amazon.com/dp/B008RMT9LO/..._BmrQCbW36RZNC
Anti seize should only go on hub to spacer interface, not on back face of spacer/brake rotor.
      05-10-2019, 11:53 PM   #59
Stinkyxy
Drives: X5
I've used a thin layer just to cover the back of the rim contact with the hub to prevent corrosion, especially in the winter.
I've found that this reduces vibration issues due to the hab not being balanced when it corrodes.
What's the reason for not using it? It's not on bolt threads.
      05-11-2019, 11:11 AM   #60
gtank
Drives: 2019 BMW X5
My point above was only to say don't use on the lugs. There are several instructions out there to put on the lugs as well, which is crazy.
I don't think it matters on the hubs or wheel side of the spacer. It's only there to help uninstall later.
      05-11-2019, 12:55 PM   #61
Stinkyxy
Drives: X5
Agree - no anti seize on bolts. On the hub you only need a very thin layer to prevent aluminum and steel from corroding.
      05-25-2019, 01:04 PM   #62
ayrton75
ayrton75's Avatar
Italy
Drives: BMW x5 (Go5)
Hello,
I'm seriously thinking about putting spacers on my g05, they look great!!!
I would like to know from you that you have installed them if you have noticed some changes in the car, for example increased noise, difference in behavior and handling or other things.
Thanks and congratulations, it's a god.
Ayrton...
      05-25-2019, 01:06 PM   #63
bizfiend
bizfiend's Avatar
146
Originally Posted by ayrton75 View Post
Hello,
Ayrton...
No difference
      05-26-2019, 02:59 AM   #64
ayrton75
ayrton75's Avatar
Italy
No difference
Thank you!!
      05-27-2019, 05:04 AM   #65
ayrton75
ayrton75's Avatar
Italy
No difference
Hi, I would also like to know if you have found the 4 related anti-theft bolts or if you have mounted the rims without anti-theft bolt ...
thank you
      05-27-2019, 10:30 AM   #66
bizfiend
bizfiend's Avatar
146
thank you
Without
