      02-27-2019, 08:42 PM   #23
Tlon
173
Drives: 2019 X5
Originally Posted by rmorin1249 View Post
I did the same thing with my F10. I've checked and my dealer will not code the ASS on my X5. I've checked and so far there seem to be very few coding changes available on the G05. Not willing to pay close to $200 for just a couple items and not brave or savvy enough to do it myself.
FWIW, I was pretty nervous about doing it myself too -- last thing I wanted to do was brick my car -- but bimmercode is pretty easy to use and because there are only a couple options available right now for the G05 -- the last ASS setting being one of them, thankfully -- there is not much you can do to select the wrong setting. With a $30 bluetooth adapter and $26 for the bimmercode license, you can do it pretty easily. It takes about 5-10 minutes, and it's just like using any iPhone app. One note, I did get a chassis error during the coding, which freaked me out, but that's normal and it goes away right away.
      04-19-2019, 02:34 PM   #24
rmorin1249
rmorin1249's Avatar
817
Drives: 2019 X5 MSport 40i
I have never coded a car before so I need some reassurance. I ordered the OBD adapter and as soon as it arrives I will purchase Bimmercode. I have an Android phone. Can someone walk me through the procedure? Do I need to disconnect the Bluetooth on my phone and then reconnect after selecting the Bimmercode app on my phone? What is the next step? Thanks in advance. If you want to contact me through a PM that is fine as well but others on the forum may be Newbie like me and would also like some assistance.
Just looked at the Bimmercode website. Looks like A.S.S. coding is the only one available for the G05 at this time. Do I change the setting to Active or Not Active?
Android version now costs $34.99.
COL(Ret), US Army Hagerstown MD
2019 X5 40i MSport Alpine White/Coffee (my 13th BMW)
2015 Mercedes SL400; 2009 Lexus RX350
      04-21-2019, 03:35 PM   #25
rmorin1249
rmorin1249's Avatar
817
Success! Once I figured out that the vehicle doesn't tell you it's in Diagnostic mode all went smoothly. Now, I'm just waiting for Bimmercode to make more coding options available.
      04-22-2019, 01:13 AM   #26
lights
Drives: 2019 BMW X5 40i
Weird, my G05 displays ‘DIAGNOSTIC MODE’ on the instrument cluster screen when I triple tap the start stop button.
      04-22-2019, 08:15 AM   #27
jimv03
Drives: 2019 BMW X5
Yes mine showed to be in Diagnostic Mode as well?
      04-22-2019, 01:16 PM   #28
rmorin1249
rmorin1249's Avatar
817
I probably didn't see it because the coding worked. I was looking at the middle screen. Also I was pretty nervous.
      04-22-2019, 02:51 PM   #29
jimv03
Drives: 2019 BMW X5
Yeah it's a little scary the first time you do it for sure. I was nervous too!
      04-24-2019, 12:47 AM   #30
lights
When you bring your X5 in for service, do you reset the auto start/stop to factory settings (memory off)? Any risk this might trigger a warranty issue?
      04-24-2019, 05:58 AM   #31
rmorin1249
rmorin1249's Avatar
817
I had lots of things coded on my 2016 F10. Was serviced multiple times at the dealer with no issues without changing the coding. I do not think it's a warranty issue.
      05-04-2019, 08:11 PM   #32
behardt
Drives: 2022 M4 Convertible
I tried the BimmerCode app and it said "preparing coding" for 20 minutes, so I stopped it. Figured something was wrong. For those that have used this app to code the ASS function on a G05, how long did it take after you pressed "Code"? Using OBDlink MS+. Thanks in advance
      10-16-2019, 03:06 PM   #33
spike5150
Drives: 2020 X5 M50i
Either I am stupid or Bimmercode doesn't support the 1907.xx istep yet?
Bought a compatible dongle (initially I was using my old one which was not compatible with G-series per their website). Put car in diagnostic mode, but DME shows no coding available, so can't code ASS.
Anyone have any ideas? I am on 1907.40 FWIW.
Thanks.
      10-16-2019, 05:43 PM   #34
homerrr
homerrr's Avatar
Drives: BMW G05
Thanks.
BimmerCode had more options on /03 but with /07 it went to very few. I'm expecting it'll be a while until they update it...it was good for me because it pushed me over the edge and I love coding with esys now!
      10-16-2019, 06:54 PM   #35
spike5150
Are you using Esysx or launcher pro?
      10-16-2019, 08:54 PM   #36
homerrr
homerrr's Avatar
Drives: BMW G05
Launcher pro. Took little less than 2 weeks to get token and that was mid September.
spike5150421.50
      10-16-2019, 10:12 PM   #37
spike5150
I’ll try again with Esys. Were you able to code ASS memory on 1907.xx I step? Someone mentioned it locked out DME ECU.
      10-17-2019, 03:26 AM   #38
homerrr
homerrr's Avatar
Drives: BMW G05
I'll try again with Esys. Were you able to code ASS memory on 1907.xx I step? Someone mentioned it locked out DME ECU.
With the latest PSdZData I was able to get into all ECU's, including DME for ASS
      10-17-2019, 08:41 AM   #39
archivedaccount
Guest
n/a
Drives:
Be careful with DME. Don't code it with the engine running.
Esysx is a better product than Launcher Pro, but more expensive.
With esysx you can set coding that Launcher Pro users don't even know exist.
      10-17-2019, 09:10 AM   #40
rmorin1249
rmorin1249's Avatar
817
I was able to code ASS after my software update but many coding options that were previously available are now missing.
      10-17-2019, 01:57 PM   #41
spike5150
Thanks all. I'll give it a shot with Esys. I may get EsysX - cost is not a big deal, but how often do you have to buy an update? Every other major I-Step change? Like 1903 to 1907(free) to 1911 pay again?
      01-14-2020, 11:35 AM   #42
Darth Vader
Darth Vader's Avatar
Hi anuj452,
Please could you post the cheat codes you used with Esys to make those coding?
Originally Posted by anuj452 View Post
I guess folks can ask the dealership and see if they can disable it.
I recall this feature came with F series model in late 2011, after few months BMW dealer started to disable this ... so ASS would be switched off by default and you can enable it if you like..
It was so annoying on my F10, i had it coded to disable by default...
I coded many other features in my F10. (some of which are now being offered through iDrive in G05). Here are some that I coded on my F10 using Esys
Auto Start-Stop function to start as last used
Auto Start-Stop OFF by default
Turn off power (radio and iDrive) when opening door
Unlock doors when engine is stopped (doors unlock linked to doors automatically locked by iDrive)
Enable key fob and driver side door handle to fold mirrors* and close windows and moon roof
Code the angle of the passenger side mirror when the car is put into reverse
Opening doors will not interrupt window roll up
Increasing sensitivity of the wipers, but not the speed
Transfer telephone ringtone to the car
Increase CIC stored addresses/messages from 25 to 50
Enable key fob and driver side door handle to close the trunk
Enable Pressure and Temperature Readings to the TPMS Screen
Disable iDrive legal disclaimer
Disable Rear and Side view camera legal disclaimer
A/C to remeber to stay off when you powered it off last time you turn off the car key
Enable Adaptive Brake Lights
      01-14-2020, 02:48 PM   #43
anuj452
2019 X5 40i
anuj452's Avatar
115
Drives: 2019 X5 40i
You need the cheat codes for F10 ?
Originally Posted by Darth Vader View Post
Hi anuj452,
2019 X5 40i (Mar-2019 Build)
iDrive ver -- 03/2022.30
      01-14-2020, 04:36 PM   #44
Darth Vader
No, it's for a G05 X5 2019
