06-12-2019, 05:28 PM | #1 |
Rep 106
Passenger Mirror Camera Misaligned - Strange Results from BMW Service
I took delivery of my X5 at the end of April. One of the things I quickly noticed was that the camera on the passenger side mirror was misaligned. This was noticeable whenever using parking assist mode as the overhead image was showing the right side image out of alignment, i.e. when parking in a normal parking spot the image on the screen would look like: | O \ instead of: | O | (hope that makes sense).
I finally brought my X5 into service on 5/29 to have this 1 issue addressed. Service had my car for the day and said the issue was fixed. The invoice said: "1576 cameras out of initialization manually folded in mirrors and utilized auto fold button to fold out. performed slow speed initialization drive. cameras showing proper picture." Before leaving the dealership I checked the parking image and saw that the issue was not fixed. I went back inside to let my SA know, and he called the shop foreman out to take a look. As soon as he saw the image he said "yeah that's not fixed". I ended up driving away that day due to issues arranging a loaner car. On 6/3 the dealership picked up my X5 and dropped off a loaner for me (thumbs up to them for this great point of customer service). On 6/6 I heard back from my SA that after consulting with BMW NA they were able to determine that a module needs to be replaced, which needs to be ordered from Germany and will take ~3 weeks). I picked up my X5 on 6/10 with the understanding I would have to bring it back once the part arrives. The invoice for this visit said: "1770 passenger mirror camera not straight while in a parking spot showed wrong angle on passenger side (angled excessively outward). hooked vehicle too battery charger and ran short test. found no faults for this. began re-calibration process of KAFAS camera and drove vehicle 10 miles to reset. found issue is still present. programmed and encoded vehicle including KAFAS system and recalibrated once more. drove again and found issue is still present. spoke with shop foreman who recommended opening a TSARA case (case number: 56285) performed as per advance info several times and the passenger side cameras will still do not lineup. programmed TSRVC to force calibration and issue still persists. (did this twice.) driving 8-10 mph parking lot with lines and tried curbs also. per TSARA case ordered replacement TSRVC module. (germany) - client will return when the part is here." So I left the dealership happy in the fact the issue had been identified with resolution to come in the next few weeks. But, the strange thing I noticed yesterday is that the overhead image now looks 100% correct (at least in the fact that the right parking line is parallel with the left line). Thinking I'll wait to hear from my SA that the part has arrived, then bring my X5 in but have them take a look at what I'm seeing to determine if the module replacement is really necessary. Anyways, the experience so far has been weird. |
06-12-2019, 06:02 PM | #2 |
13262
Rep 19,781
I would probably tell them to replace it when the part comes in since there is something wrong with it. It may continue to work or go bad again the day after deciding not to replace the part. Good luck and let us know how it turns out.
06-12-2019, 11:53 PM | #3 |
57
Rep 326
Drives: G05 X5 30d, Boxster GTS (981)
I had the same issue and the technicians told me that previous F15 X5 had a way to recaliberate the cameras, but for G05 the system automatically aligns itself.
So after taking part of the side mirror cameras, they reinstalled it and the system recaliberated by itself. Maybe that happened to you. |
06-13-2019, 08:18 AM | #4 |
Rep 214
I have the same problem on my driver's side camera. I am planning to take it in soon. Seems to be a common issue.
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
06-14-2019, 11:07 AM | #5 |
Rep 61
Same problem for me too. Interested in any tips to have this fixed. This seems to be a software issue.
06-15-2019, 11:06 AM | #6 |
Rep 61
Which software version do you have?
06-15-2019, 11:14 AM | #7 |
Rep 2,609
Curious what theory of operation is behind the thoughts that these misalignments are likely software issues?
06-15-2019, 11:24 AM | #8 |
Rep 106
FWIW, I was originally on 03/2019.35, but it appears they upgraded my software to 03/2019.48 now.
Based on my experience, hard to say if it's s/w issue or not. They definitely seem to have tried steps to realign the camera, and they also upgraded s/w it seems. Now they want to replace h/w module even though the issue seems to be fixed for me now. So, in my case between attempts to realign the camera and s/w update it appears 1 and/or both of those worked. Based on the advice above, I may just let them replace the h/w module also when the part arrives... |
06-15-2019, 11:35 AM | #9 | |
Rep 2,609
I say that because the various reports don't fit a s/w bug type of sense: different sides, different angles and amount of misalignments, consistent from cycle to cycle — not how s/w usually fails, but is how hardware does. Plus we definitely know that camera physical misalignment is a possible and trivially likely issue. For example, I mentioned alignment to the dealer before pickup and they said "Absolutely, that's definitely one of the items on the checklist, your cameras WILL BE aligned" (and they were/are, on 3/2019.45 if anyone cares).
06-15-2019, 01:07 PM | #10 |
13262
Rep 19,781
Some guy posted this on another BMW forum in regards to G05 camera alignment - "A video equalizer is used to flatten and compose the various camera views. There is no particular camera mechanical alignment of which I know."
Not sure whether he is speculating or actually knows. Seems to me though that the results of the process he mentions depends on the physical camera angle and that is where the alignment comes into play. |
06-15-2019, 02:39 PM | #11 | |
Rep 61
LexxM31698.50 |
06-15-2019, 03:52 PM | #12 |
13262
Rep 19,781
06-15-2019, 03:56 PM | #13 | |
Rep 61
06-15-2019, 06:21 PM | #14 |
13262
Rep 19,781
06-15-2019, 07:19 PM | #15 | |
Rep 4,553
HU-H3 - Media Graphics Unit - Also known as iDrive 7 TCB - Telematics Communications Box ATM-02 RSE - Rear Seat Entertainment (if so equipped) KOMBISP18 - Live Cockpit Pro (dash) 3D Surround view module is not upgraded by OTA. To upgrade would require an iStep upgrade via ISTA.
2023 840GC | 2021 740i | 2019 X3
06-15-2019, 07:31 PM | #16 | |
Rep 4,553
G series cars have no dealer level calibration because this system is calibrated digitally by the OEM (BMW or their ODM partner) to the specific vehicle. When in the digital domain, calibration is done using special targets (much like motion capture) so the DSP can learn the edges of the car, where camera points intersect, etc... to ultimately create correction factors based on the camera location in the specific vehicle. I suspect BMW is working with their ODM partner to get this corrected and improvement will be included in a future iStep upgrade.
06-15-2019, 07:34 PM | #17 | |
Rep 4,553
Yes, this is a software issue and it will be corrected once BMW and/or the ODM partner, get the calibration and corrections factors correct for the G05. And if its not calibration issues, maybe the ODM needs to correct their algorithms used to communicate with the ISP/DSP chip in the module. A fix will come in a future iStep upgrade for the G05.
06-15-2019, 07:40 PM | #18 | ||
Rep 2,609
Disagree? If so, I am still curious regarding the theory of operation of this alleged software defect that fits these observations.
06-15-2019, 07:57 PM | #19 | |
Rep 4,553
2. Some consumers don't realize/notice the issue 3. Some don't care 4. Some don't have a personality style to complain 5. Some don't visit forums 6. Maybe BMW/ODM software team has made changes to the camera module software and made it's worse/better in some iStep versions. So, maybe not everyone is impacted same. Keep in mind BMW may have made other car design changes they thought wouldn't impact the cameras, but maybe they did. Nevertheless, it's 99% a software issue. The module is what it is. It's a Renesas DSP with the associated glue logic and the rest is software implementation. If you want to better understand the theory of what causes this type of issue, I'd direct you to a course on digital ISP/DSP and implementation in a 3D environment.
Fuzzy Master256.50 |
06-15-2019, 08:04 PM | #20 | |
13262
Rep 19,781
06-15-2019, 08:08 PM | #21 | |
Rep 4,553
The cameras in your G05 are securely mounted using screw points and likely a guide rail. There's very little variation from car to car unless BMW has issues with other material OEMs. Keep in mind not every parking situation is interpreted the same by the DSP software. It may be only certain scenarios that cause the worst case visual outcomes you see on the forums.
06-15-2019, 08:09 PM | #22 | ||
Rep 2,609
The last part is not what I mean by "theory of operation of this issue". It is irrelevant what processor is used or who did it. What I mean by the question is that I can't visualize a software defect where the system still generally works, yet misaligns one or the other side by an angle and stays there for a specific car constantly from then onwards. I can certainly see how a physical misalignment does that, but not how software does that. Well, to be fair, I CAN see a way — if calibration image/data gets corrupted, this could definitely occur this way. But a dealer recal should just clear that calibration data and start over, fixing it. Yet in this specific report this was not effective. Anyway, I am not trying to argue about theoreticals, but it is interesting to speculate. What I really want is a) a decent software/UX/QA team at BMW, and b) BMW full transparency on what they change in each version, in digestible form of course.
