06-28-2019, 05:37 AM | #23 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
Thank you to ALL who responded.
I got it to work, but only with the driver door closed. I most likely had the driver door open when it would not function for me. Mystery solved! |
06-28-2019, 05:39 AM | #24 | |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
So weird, it should close all the way. My highlander does that ... it doesn’t stop midstream if you release the button! |
orthopod52.00 |
06-28-2019, 05:41 AM | #25 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
06-28-2019, 05:42 AM | #26 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
No, I had to hold it, and when I released it stopped the closing process and left it partially closed. Sheesh.
06-28-2019, 05:44 AM | #27 | |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
06-28-2019, 05:47 AM | #28 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Lol genius showed me a lot of stuff, but I was focused on getting the primary settings set and checking that they worked.
Genius probably showed this to me, it just didn’t stick. I don’t mind figuring things out, but I always expect things to work similarly to my Highlander. In this case, it doesn’t. Thanks! |
wrickem2101.00 |
06-28-2019, 05:58 AM | #29 |
Big Beaver Smile
2101
Rep 3,791
Yeah, that's just weird. Mine works with the switch with the door opened or closed from the switch as long as it's in park and the key is inside the car.
06-29-2019, 01:40 PM | #33 |
Rep 684
It works fine with the door open or closed, just have to have the key detected by the car and PULL the gate open/close switch rather than press it.
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
06-29-2019, 04:26 PM | #34 |
123
Rep 333
Dumb question. Is Bimmercode a code that you enter into iDrive to activate certain functions?
I’m going to pick up mine in late July or early August so Im preparing a list of things to check at delivery. |
06-29-2019, 04:52 PM | #35 |
Rep 255
06-29-2019, 05:35 PM | #36 |
Rep 2,609
No, Bimmercode is an app that you use with a purchased OBDII interface plugged into your vehicle.
06-29-2019, 06:04 PM | #37 | |
Rep 684
06-29-2019, 06:54 PM | #38 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
06-29-2019, 10:19 PM | #39 |
77
Rep 245
06-30-2019, 06:01 AM | #40 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
06-30-2019, 11:21 AM | #41 | |
123
Rep 333
06-30-2019, 02:40 PM | #42 | |
Rep 684
BMW will NOT program any settings for you other than to update your ECU firmware when new revisions become available. There are, however, some coders on the forums that do this as a for-fee service. You may want to check out the "iDrive, Audio, Phone, Electronics, Software, Coding" forum.
06-30-2019, 03:00 PM | #43 |
Rep 684
I don't believe our key fobs will allow the closing of the rear gate. Before going through the iDrive menus this morning (to no avail), I pressed and held the rear gate button but no joy.
06-30-2019, 07:09 PM | #44 | |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
However, you can program the key fob with settings on iDrive. I haven’t looked to see what is available, but I know you can change some of them. Maybe that capability is one of them. |
