08-26-2019, 08:56 AM | #1 |
Rep 27
Non-Heating Steering Wheel --> Heated Steering wheel?
How much would the dealer normally charge to do this swap, on a G05? Is it routine enough that I don't have to worry about airbag being negatively affected in any way? Thanks guys.
10-22-2019, 09:15 AM | #2 |
1053
Rep 1,952
I imagine you would just swap out the entire steering wheel, airbag and all - so whatever the cost of the steering wheel (guessing $700) plus an hours worth of labor.
10-30-2019, 07:52 AM | #3 |
Rep 1,241
I remember researching this on my F30.... and it was considerably more complicated than I'd initially thought.
Buying a heated steering wheel was easy..... but in an F30, the car wasn't wired for it, so it required the installation of a wiring harness through the steering column. Then, even after I did that... it required coding. I decided not to do it. Wasn't worth the effort. Not saying the G05 is the same.... I don't know, but I would be 100% certain before you go buying parts. The $700 steering wheel could turn into a $2000 job.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
01-08-2020, 12:49 PM | #4 | |
Rep 131
Hopefully they will make one soon |
