10-03-2019, 11:47 AM | #1 |
Rep 16
Recommendations for OBD2 Scanner?
Sorry if this has been posted before, but I did a search and couldn't find any info.
I would like to start coding my G05, but am having trouble finding recommendations for a good scanner. Anyone want to recommend one? TIA |
10-03-2019, 01:35 PM | #2 |
134
Rep 326
I bought
AntiBreak ENET Rj45 Cable ethernet Connector Tools to OBD Interface Cable Coding F-Series https://www.amazon.com/dp/B07D8RHBNB..._x8JLDb4Q8PKT9 Works fine on my G05 with esys so far |
10-03-2019, 02:46 PM | #4 | |
257
Rep 332
There is a ton of info on this forum about coding (don't limit your search to just the X5 forum), but basically you need to determine what you want to code (which option/feature), then determine what method/software you want to use (i.e. E-Sys, Carly, Bimmercode, etc) and then see what OBD adapter/cable will work best with that software. For example, E-Sys works best with an Ethernet adapter, while Bimmercode lists supported adapters on their website. I would suggest you do more research to understand what you're getting into and how deep you want to get into it. BMW releases i-step upgrades pretty regularly, and every time you will lose all coding and will need to be prepared to re-code. |
homerrr133.50 |
