10-13-2019, 02:21 PM | #1 |
1053
Rep 1,951
Using Surface Pro For Coding
Sorry if this question has been asked (no search feature on mobile) but does it matter how you connect your laptop to the car for coding? All the walk throughs talk about a cat5 to OBD-II cable, but my surface pro does not have an ethernet plug. I've seen USB to OBD-II, but not sure if that would mess things up.
10-13-2019, 02:28 PM | #2 | |
Rep 4,551
You'll want an ethernet to OBD2 cable. Use an ethernet to usb adapter with your surface. Microsoft sells one, but I prefer this from Startech. StarTech.com USB 3.0 Hub with Gigabit Ethernet Adapter - 3 Port - NIC - USB Network / LAN Adapter - Windows & Mac Compatible (ST3300GU3B) https://www.amazon.com/dp/B00MN27LXW..._dR3ODbQZC0QNV
2023 840GC | 2021 740i | 2019 X3
VTENGR1052.50 |
10-13-2019, 02:32 PM | #3 | ||
1053
Rep 1,951
ScanTool OBDLink SX USB: Professional Grade OBD-II Automotive Scan Tool for Windows - DIY Car and Truck Data and Diagnostics https://www.amazon.com/dp/B005ZWM0R4..._IU3ODbV3YJXH4 |
10-13-2019, 02:36 PM | #4 |
Rep 2,609
I am using something very similar to this USB to Ethernet adapter: https://www.amazon.com/dp/B014ZOJX7W/
and this exact OBD Ethernet Adapter: https://www.ebay.com/itm/BMW-OBD-E-N...-/352749554768 both with great success. I suspect this setup would work on Surface. Check software requirements with ESys and your launcher of choice (ESysX or Launcher Pro), however. Unless you are eager and willing to be the tester, or unless there is explicit experience by multiple others, I wouldn't choose anything that doesn't explicitly list BMW G-series and ESys for a setup. Coding setups are chaotic enough, you don't need more variables in your interface hardware.
VTENGR1052.50 |
10-13-2019, 02:56 PM | #5 | |
1053
Rep 1,951
10-13-2019, 03:55 PM | #6 | ||
Rep 2,609
