10-21-2019, 10:39 AM | #1 |
Rep 402
Thoughts and Feedback Requested: Winter Tire / Wheel Set-Up
I currently have the 21" wheels w/ Pirelli RFT tires (275/40/21 and 315/35/21).
My plan is to take off my current summer tires and replace them with the same size tires in the All Season category (Pirelli Scorpion). These new tires will run me a total of $1,700 w/ tax mount & balance etc. These tires are Non RFT. As a result, I am planning on buying a "Space Saver Spare" from BMW. I live in CT - New England and will be driving in the cold and sometimes in the snow (albeit mostly when roads are plowed). I have been told that All season is good enough in the winter. I would have gone with Winter tires but they don't make winter tires in my size 21". I am then planning on putting my current summer tires on a Black color set of new 21" wheels that I will buy in the Spring. I have a Black Saphire X5 and want the "Black Out / Murdered Out" look. My main question is do you think that this will work as far as the All Season Tires and the Space Saver Spare (in an emergency). I don't want to buy a 3rd set of wheels and tires for winter as I really want a set of black wheels for my preferred look and would ideally want to utilize the existing 21" wheels for winter. I welcome, appreciate and look forward to all feedback. Thanks. |
10-21-2019, 11:07 AM | #2 |
Rep 402
I think your plan sounds fine. I had an F15 X5 with all-seasons for the last 5-6 winters here in MN. I had absolutely no problems getting around. Would dedicated winter tires have better grip? Sure. But if you drive reasonably you will be just fine with all-season tires.
I liked the look of the 21 and 22 inch wheel choices for the G05, but ended going with the 20s because I didn't want the hassle of swapping out wheels and tires twice a year, and there are many more choices for tires of all kinds in the 20 inch size. Once my OE tires wear out, I'll probably switch to the non-runflat Continental DWS. I have the factory spare tire option. |
10-21-2019, 12:43 PM | #4 | |
2447
Rep 1,949
From your post, your main issue seems to be getting them to fit your OEM wheels. You can maybe get some 21" winter tires if you look for narrower (than oem) winter tires. A good tire shop can help you out with this to be sure that they fit correctly. You can also consider selling your OEM 21" wheels if you can't find winters to fit them. |
1230vani652.50 |
10-21-2019, 01:20 PM | #5 |
Rep 1,075
All depends on how you drive. Agressive driving in x5 50 on all season tires is bad in winter and in summer. For 90k car get the best tires you can get for summer and winter. Michelin pilot alpine 5 suv is great high performance winter tire. An order from tire rack on black rims. 20s will be lighter and cheaper for winter
10-21-2019, 04:18 PM | #6 |
Rep 84
Can anyone explain to me what this is?
https://www.shopbmwusa.com/Product/8...EEL---TIRE-SET Does this rear tire exist? Why does it say 21" and then also 19" ??? |
10-21-2019, 11:22 PM | #7 |
Rep 950
Yes it does exist. Dealers are starting to get the tires now. I haven't found anybody other than BMW dealers who have the rear 21s. I've been quoted about $650/each rear tire and $350/each for the fronts.
2020 X5 M50i Phytonic Blue/Black - PCD 10/21/2019
2015 i3 Rex Caparis White/Tera - Retired 2016 550i M-Sport Alpine White/Ivory - Retired 2011 X5 35i BSM/Black - Retired 2011 335i Coupe Alpine White/Saddle - Retired (ED) |
10-22-2019, 10:52 AM | #8 | |
Rep 199
10-22-2019, 01:12 PM | #9 | |
Rep 402
I have been quoted these exact tires but in the ALL SEASON variety. |
10-22-2019, 01:14 PM | #10 |
Rep 402
Additional question:
I have found the 275 front tires available in a WINTER variety from one manufacturer. What are your thoughts on getting the 275/40/21 from one company in WINTER category for the Front and then getting the 315/35/21 rears in ALL SEASON from another maker? Is it OK to have WINTER tires in front and ALL SEASON in rear? Thank You. |
10-22-2019, 02:12 PM | #11 | ||
Rep 7,475
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-24-2019 at 12:39 PM.. |
10-22-2019, 02:15 PM | #12 | |
1053
Rep 1,952
10-22-2019, 05:00 PM | #15 |
Rep 84
10-22-2019, 06:49 PM | #16 |
Rep 148
I will go with these two if I ran 21inch.
https://m.tirerack.com/tires/tires.j...omCompare1=yes https://m.tirerack.com/tires/tires.j...omCompare1=yes |
10-22-2019, 07:39 PM | #17 | |
Rep 402
Just to confirm: Is it OK to run a 305/35/21 instead of the current factory 315/35/21? If so, this would likely be the way to go for me as it would provide a full WINTER Set-Up instead of ALL SEASON. confirmation would be appreciated. |
10-23-2019, 12:59 AM | #18 |
Rep 148
There is a 1% difference in diameter so it should be ok, way more stance than the square setup IMHO.
10-23-2019, 01:04 PM | #19 |
9
Rep 46
If you drive a lot on icy roads then get studded tires. Otherwise get M+S winter tires because they are better on wet and snowy roads.
If you only use M+S winter tires in winter then get northern europe tires which are softer in cold temperatures. |
10-24-2019, 10:41 AM | #20 |
2447
Rep 1,949
10-24-2019, 01:30 PM | #21 |
Rep 402
