      02-17-2021, 03:25 PM   #1
Xccelerate
Back in a BMW
Xccelerate's Avatar
285
Drives: 21 X5M Comp
OEM Plate Frame Caps
So pet peeve of mine is not being able to use The supplied tabs from the OEM BMW.
Seems the screws are getting smaller and smaller on BMWs.
I have been trying to locate a longer coarse threaded screw to fit the attached caps. Has anyone had success finding or figuring a solution to this first world problem.
21' Donington on Black X5M | Comp | Exec
11' 1M Coupe Valencia 6MT OEM+ 289 of 740
      02-17-2021, 06:42 PM   #2
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
I mounted a BMW slimline frame on the rear of my car and the screws are holding the black covers and plate on securely
      02-18-2021, 12:59 PM   #3
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
i usually go to Ace Hardware.. you should easily be able to find what you need.. if not and you can figure out what exact thread size that is and what size you need there are lots of vendors online where you can buy hardware.. another one of my favorites is https://www.mcmaster.com/
Retired: '02 E46 M3, '02 E46 M3 Vert, '11 E90 335d, '15 F10 M5, '17 F85, '18 F90, '02 E46 M3, '21 F96 Comp
      02-18-2021, 01:05 PM   #4
irpirate
Drives: 21 x5mc
The license plate base mount that came with the car (my car at least) sucked. Screws into soft plastic not to mention the screws that were provided were too long and would have damaged the paint if I had used them.
use this
Plate Mount
      02-19-2021, 09:22 AM   #5
Mo2002
Mo2002's Avatar
224
Drives: 2021 X5M
I had to get new longer screws to fit in my IND painted plate frame with caps.
      02-25-2021, 01:19 PM   #6
21x6m
21x6m's Avatar
Drives: BMW x6m
mind blowing the dealer cannot have the correct parts on hand...
      02-27-2021, 09:33 PM   #7
Xccelerate
Back in a BMW
Xccelerate's Avatar
285
Drives: 21 X5M Comp
use this
Plate Mount
I used the one mentioned above worked perfectly
