01-06-2021, 03:48 PM | #1541 | |
13500
Rep 20,108
01-07-2021, 04:08 AM | #1542 | ||
Rep 128
Past - E60 535i, F07 535i, G05 X5 xDrive40i
Current - I20 iX xDrive40 |
cruzer6661237.00 |
01-07-2021, 06:34 AM | #1543 |
Rep 2
Hi,
Just got my BMW G12 740Li July 2017 built and did some coding already with bimmercode by using OBDLink MX+, I would say it is very easy to code with bimmercode app. I tried to code the Assisted Driving View but couldn't find the four files mentioned in this forum earlier in Instrument Cluster, even tried expert mode but couldn't find them, any idea from experienced members? Please advise. |
01-09-2021, 12:36 PM | #1544 |
821
Rep 1,793
I need to reload the Bimmercode app on my phone. Will I have to pay again or will it remember my credentials?
Also, I bought the new OBDLink CX adapter and I can't get it to pair with my OnePlus phone. Can anyone help? I have submitted an inquiry to Bimmercode. Thanks. Update: It does work but you have to change the settings in Bimmercode to the right adapter. I failed to do that. My error.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 Last edited by rmorin1249; 01-11-2021 at 09:23 AM.. |
01-09-2021, 12:48 PM | #1545 | |
Rep 2,610
01-09-2021, 01:26 PM | #1546 | |
Rep 2,610
What's your exact model of OnePlus? Maybe the really older ones don't support modern Bluetooth versions and perhaps CX is limited to modern BT — CX is spec'd explicitly as BT 5.1 which is in the "ultra modern" category, but I would be surprised by lack of backward compatibility. On the other hand, CX is a relatively new product as well and it seems the OEM is tweaking the firmware regularly still. This thread may give more ideas: https://www.scantool.net/forum/index...;topic=16554.0 Another thought: BT 4.0 onward (aka BLE) modes do not statically "pair" in the pre-BLE sense. Rather, the connections are typically made dynamically. It may well be that you only connect to the CX in the app using it, rather than "pair" in phone settings. Considering its stated BT 5.1 support, this is actually pretty likely. .
01-09-2021, 04:31 PM | #1547 | |
Rep 2,610
01-09-2021, 06:21 PM | #1548 |
Rep 2,610
07/2020.80 then. That should be supported in latest release Bimmercode. Did you have the engine running or in Diagnostic Mode? I believe ASS is in DME and DME cannot be coded with a running engine and can only be coded in Diagnostic Mode.
01-10-2021, 07:27 AM | #1549 |
///M SubDriver
1840
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
IIRC, in the vehicle compatibility section, BimmerCode lists those adapters that allow full access to G-Series cars. Some adapters are only partially compatible with G-series cars. Have you checked to see if your adapter falls into this partial compatibility category?
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
01-11-2021, 08:43 AM | #1550 |
821
Rep 1,793
Update on previous post: After a discussion with Bimmercode I was able to code the Auto Start Stop function with the CX adapter. Lessons I learned:
1. Make sure the Settings in Bimmercode are set to the adapter you are using. 2. Do not start the engine. Put the vehicle in Diagonostic Mode by pressing the start button rapidly 3 times with your foot OFF the brake. I sent an apology to Bimmercode and OBD Link. The CX adapter does work with the G05 vehicles as advertised.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
01-11-2021, 08:49 AM | #1551 | |
Rep 2,610
You should update your other postings with same issue update.
01-11-2021, 09:21 AM | #1552 |
821
Rep 1,793
I believe I have updated/deleted all my previous postings as well as apologizing to Bimmercode and OBD Link.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 Last edited by rmorin1249; 01-11-2021 at 09:28 AM.. |
01-13-2021, 08:39 PM | #1553 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Anyone knows how to insert the ///M logo on the top center of the factory instrument cluster?
02-01-2021, 04:24 PM | #1554 |
Rep 1
Hi all,
I'm quite new to coding, so far I have coded the following with Bimmercode (iOS) on my X5 M50d (03.2019): - Comfort Plus Driving Mode (works quite well, I at least think I notice quite a difference with Adaptive M Suspension Professional) - Additional Speed Adjustment up to 60kmh (was not activated even with SW update) - Video in Motion Does anyone know how to code the number of flashing when locking / unlocking with Bimmercode? I think the following codes might be the ones, but I can't find them in the Bimmercode app. It seems I can't access the FEM_BODY module. FEM_BODY 3060 QUITTBLK_ENTSCHAERFEN_ANZAHL FEM_BODY 3060 QUITTBLK_SICHERN_ANZAHL Any advice would be highly appreciated! |
02-03-2021, 06:24 PM | #1555 |
Rep 12
That's an option to choose for your whole Instrument cluster display style when you're in Bimmercode (under Instrument cluster). I think I chose M-sport and I got the ///M logo. There's another thread with full pictures of this
02-03-2021, 11:39 PM | #1556 | |
Rep 810
Go to >> 3001 KI_Parameter >> LOGO_SCHRIFTZUG >> select M_Spt. That's how I enabled it. Last edited by James_G0540i; 02-03-2021 at 11:48 PM.. |
02-07-2021, 07:26 PM | #1557 | |
Rep 1,042
I could not code the ASS last position memory on my 2020 X5 40i today after upgrading to the new software version 11.2020.40 I will try it with the engine off in diagnostic mode tomorrow.
2024 M2, 2024 CGT4RS, 2020 M2 CS, 2021 Macan GTS, 2017 Cayenne S, 2002 M Coupe |
02-07-2021, 07:51 PM | #1558 | |
Rep 25
Drives: 2021 BMW G07 40d
02-09-2021, 08:14 PM | #1559 |
821
Rep 1,793
I am tech challenged. How does one update adapter software?
02-09-2021, 08:49 PM | #1560 |
Rep 2,610
Based on reported issues with OBDLink MX+ after firmware updates about a year ago, I would propose to skip updating adapter firmware ... PARTICULARLY if you're tech challenged. Because most software engineering groups either forgot about or never learned about engineering reliability, it's generally best to only ever update if you explicitly know of a good reason to do so, like a known fix to a known security issue or a known bug that actually affects you.
02-10-2021, 07:11 PM | #1561 |
401
Rep 338
Has anybody cracked how to get the //M tach in HUD? @jimmmyzhou from the G01 forum provided instructions for coding in bimmercode, I performed all the necessary steps, but with no luck. Thx!
02-11-2021, 02:51 PM | #1562 |
Rep 2
Hey guys,
I just got my 2020 x5 40i and I have the mod bug. I actually work at an auto body shop where we do lots of custom cars. We do all auto body and got into partners with a vinyl wrap shop. They do bmw coding and I will be going today to get my truck coded. Looking to do the exhaust flap, netflix/youtube video in motion, adding the M entrance screen and playing with the ambient light colors. Once im there I will see what else I can get done and I will come back with an update. Can't wait! see you guys later |
