      12-26-2018, 04:33 PM   #1
AutoSalvageMan
Drives: 2018 X3 M40i
X5,Iphone 8s and Amazon Music
Just purchased on Monday and can't get it to show artist,albums or songs. I do not have Apple Carplay. Any help or is that just the way it is? Worked perfectly in the X3 M40i I traded in.
      12-26-2018, 04:54 PM   #2
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
Go to Media, select your iP then click on "Search".
More than one thread on this topic, but threads in this forum are not uniformly labelled.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      12-26-2018, 05:54 PM   #3
AutoSalvageMan
I go there and nothing shows, I can stream music fine if I have it running when get in car but none of my music is listed under artist, albums etc
      12-26-2018, 05:56 PM   #4
AutoSalvageMan
BMW "genius" said that's just the way it is. I told him BS! All of my music always showed up in the X3. The album artwork, artist and title shows up on screen and plays fine as long as it's on your phone when you get in
      12-26-2018, 06:28 PM   #5
Xeno
Xeno's Avatar
315
https://g05.bimmerpost.com/forums/sh...ight=playlists
This and like threads are about Apple Music, not sure if there are posts about Amazon music.
      12-27-2018, 12:25 AM   #6
MatchboxM1
MatchboxM1's Avatar
59
Drives: 2022 X5 M50i
Has anyone been using an Android phone and or Google Play Music? I use a Google Pixel 2 - the first phone I've ever had that has lasted over a year or hasn't been destroyed. Picking up a new X5 friday and wondering how this will work....or if I'll have to get an iphone.
      12-27-2018, 07:23 AM   #7
lumpydog
lumpydog's Avatar
691
Drives: 2019 X5
This should work - you need to enable Apple CarPlay - which supports Amazon Music.
There are a few settings that need to be turned on. Check the owners manual and it describes the preconditions to enabling Apple CarPlay
From memory, you need to accept all of the data privacy check boxes, enable WiFi, the. Go to your mobile device settings and select/enable Apple CarPlay. Again, just from memory - but poke around the settings and you should be able to get it to work.
      12-27-2018, 08:19 AM   #8
lumpydog
lumpydog's Avatar
691
Drives: 2019 X5
Watch this video that explains how to setup your iPhone as a new device enabled for Apple CarPlay:
Then, check these settings:
Com > Two bumps to right to Settings > Enable Wi-Fi and Apple CarPlay. (Note - leave Internet Connection unselected unless you’ve setup your vehicle as a hotspot)
Then....
Com > select [your phone name] and click down > Connection Mode > select Apple CarPlay
      12-27-2018, 10:33 AM   #9
AutoSalvageMan
I don't have Apple Carplay-- so I take it that that is the answer. Didnt really want to have to get it after having it in my M40I and finding it very buggy.
      12-27-2018, 11:52 AM   #10
screamace
screamace's Avatar
304
Drives: 2020 BMW X5M Competition
Amazon Music (or streaming from Apple Music, Spotify, etc) will not show under normal Bluetooth connection because the music is not stored in the music library. You should be able to play it by navigating from your iPhone. And basic control (play/pause, prev, next) should work. However there's no guarantee that album art or list of upcoming songs would work.
2019 Porsche Panamera 4 E-Hybrid
Past BMW: 2018 M550i, 2016 X5 40e, 2014 335xi, 2011 X5 50i, 2010 550i
      12-27-2018, 02:03 PM   #11
AutoSalvageMan
That sucks. Everything was seamless in the "18 X3. You could search by artist,album etc. So is this an idrive 7 issue???
      12-27-2018, 05:03 PM   #12
lumpydog
lumpydog's Avatar
691
Drives: 2019 X5
You sure? I thought all 2019 X5s came with Apple CarPlay... See my prior post and run through those steps.
      12-28-2018, 05:41 AM   #13
MatchboxM1
MatchboxM1's Avatar
59
Thanks screamace.
      12-28-2018, 09:59 AM   #14
AutoSalvageMan
lumpydog, you are correct. After diving into it, yes I do have Carplay as will all 2019 BMW's. I then paired everything and all of my music is in Carplay under the Amazon icon. Still havent figured out the texting part of it but I'm sure I will.
I was amazed at the volume difference in Carplay compared to just streaming music via bluetooth, night and day!
      12-28-2018, 10:03 AM   #15
lumpydog
lumpydog's Avatar
691
Drives: 2019 X5
That's awesome! PhatBoyG pointed out that Apple CarPlayuses WiFi to stream - vs BlueTooth. It does seem to make a difference.
Glad you are up/running!
1230vani652.50
      01-01-2019, 05:13 PM   #16
thomas_Rp
thomas_Rp's Avatar
126
Drives: X5 G05; 535 F10
Not sure if this applies..
https://discussions.apple.com/thread/8562181
      01-01-2019, 06:34 PM   #17
Doc5513
Drives: X5
Originally Posted by thomas_Rp View Post
I'm a little confused by what's being discussed there. If you are in the car using your iPhone, you are using cellular data all the time for the internet? Correct?
