05-24-2021, 02:18 AM | #1 |
1198
Rep 1,587
How to FDL code Assisted Driving View - simple walkthrough
This guide demonstrates how to FDL code Assisted Driving View (ADV) using EsysX. It is an update of a guide I originally posted back in 2019.
The process can be repeated for any FDL coding, not just ADV, and the coding should work for any of the supported S18A models (Service Pack 2018) Pre-reqs
Coding Steps for Assisted Driving View
pavloPL54.50 eagle_bmw182.50 marcosg24.50 qocerhuang29.50 jmilner838.50 BigMofoFrog180.50 Shawzy44158.00 Bambazonke210.00 |
06-05-2021, 04:47 PM | #2 |
Rep 1,479
Drives: 2020 M340Xi (G20)
@IFR,
Sorry to go off topic. Pretty sure I recall reading a post of yours in which you provided a coding fix to the bug that has cropped up in OTA updates that causes tachometer not to be displayed in HUD, when in sport only mode. Perhaps it's senility, but I can't locate it Would you be kind enough to provide that coding fix BTW, your fix to the auto camera fix continues to work well through 03/2021 Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
06-05-2021, 05:23 PM | #3 | |
1198
Rep 1,587
I was starting to doubt myself on the tachometer coding, but finally found it: https://www.bimmerpost.com/forums/sh...php?p=27340727 |
06-06-2021, 04:26 AM | #5 | |
1198
Rep 1,587
It's critical you don't save the FA back to the car AND only VO code DKOMBI. You could change the build date to match your i-step e.g. 03/2021, and get the latest KOMBI configuration. Don't do this approach for any other ECU. Too much risk of hardware changes, but KOMBI is fairly safe, but still not without risk of unsupported hardware You would need to repeat the process after any i-step update (dealer/OTA) that programs DKOMBI |
11-05-2021, 05:16 PM | #6 | ||
Rep 451
Drives: 2017 X5 & 2020 X5
Update: Ok I can confirm in addition to ADV as discussed above an Australian spec X5 with a build level of 07/19 does get the "auto" option in Additional displays in the HUD if the FA is temporarily modified to build level to 03/21 after VO coding the Kombi4 ECU only with an iStep Level of 03/2021 or later This is a "free" alternative to those that don't have Bimmercode or ESysX software to FDL code the below that IFR kindly listed sometime ago CB_HUD_FAS: nicht_aktiv [00] CB_HUD_LIST_AUS: aktiv [01] CB_HUD_LIST_AUTOMATISCH: aktiv [01] CB_HUD_LIST_FAS_PERMANENT: aktiv [01] CB_HUD_LIST_SPORT_AUS: nicht_aktiv [00] CB_HUD_LIST_SPORT_FES: nicht_aktiv [00] I have Launcher Pro which IFR advised users to avoid as it is out of date and missing some of the parameters above to change to make it work anyway. EsysX as far as I am aware, is still not available for purchase
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 11-16-2021 at 06:34 PM.. |
