      08-21-2021, 01:42 PM   #1
Dzienkob73
Drives: 2022 BMW X5 XDrive45e
Fog Light Access?
Wondering if anyone has experience with accessing the fog lights on the G05 series X5s? Can the fog light be accessed from the outside? Taking delivery of my 2022 X5 45e in a few weeks and want to add factory fog lights since BMW deleted them post 2021. Like the look with fog lights aesthetically. SA suggested I do not hook them up due to warranty concerns on an electric vehicle.?
Thanks in advance!
      11-05-2021, 01:47 AM   #2
mlurker
146
Drives: BMW G05 X5 45e
Did you install it?
      11-05-2021, 04:20 PM   #3
TGTBTU
TGTBTU
TGTBTU's Avatar
Drives: 2022 X5 X-drive M40i
2022 X5 fog lights
Interested in your answer as well? Did you get them installed?
      11-08-2021, 09:48 AM   #4
Dzienkob73
I did end up installing fog lights I ordered from OEM seller. They can be installed by removing the front tires and respective wheel wells. Right fog went in relatively easy, however left side is really tight. No wiring harness was available for fog light connection that I could see. Will just be an aesthetic install until I find a kit for the harness and switch.
Appreciate 3
ladra17.50
TGTBTU84.00
kgelfen3602217.00
      12-17-2021, 08:56 AM   #5
TGTBTU
TGTBTU
TGTBTU's Avatar
Other than the fog lights and 6 bolts to hold them in place, were there any other parts needed for the installation?
      12-21-2021, 01:25 PM   #6
Dzienkob73
No. Not for just installing the fog lights.
      06-07-2022, 05:52 PM   #7
Jrc27
Drives: 2019 Audi A4
Any chance you still have the part numbers?
      10-11-2022, 11:27 AM   #8
GetSmart
Drives: 2022 X5
Any update on the installation with wiring harness and working lights with the correct interior light controller?
      10-11-2022, 05:02 PM   #9
TGTBTU
TGTBTU
TGTBTU's Avatar
Same here. Any updates on a fog light kit?
      10-23-2022, 07:26 PM   #10
Jhampel
Drives: 2023 X5 M50i
Fog light install
Same here as well. Any update on the wiring harness and switch installation?
      10-24-2022, 10:28 AM   #11
X5/40i
X5/40i's Avatar
89
Drives: BMW X5 M50i 2023
If anyone gets to retrofit the fog lights please share
      10-24-2022, 11:04 AM   #12
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
734
Drives: 2020 X5 M Competition
You should be able to find the parts in bimmercat or similar. BMW offers replacement "repair" wiring harnesses for much of the vehicle depending on factory options. Also check out this thread. https://g05.bimmerpost.com/forums/sh....php?t=1852810
      10-26-2022, 11:44 AM   #13
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
At this point, I'd be all about installing the fog lights even if they aren't functional. Looks a lot better than what's there now.
