12-03-2023, 04:18 PM | #1 |
Rep 4
Drives: Bmw M240i Lci
How can I determine the type of differential fitted to my 2017 m240i Lci which no longer has the label with the code above?
I attach photos of the differential |
12-04-2023, 09:47 AM | #2 |
Rep 239
Drives: '17 M240i 6MT
From what I remember, the M Performance LSD is visually identical to a stock open diff. Your best bet is probably the good old fashioned, put both wheels in the air and see which way they spin.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
12-04-2023, 09:53 AM | #3 |
Rep 4
sorry, I wasn't clear, my differential is open, I already know that, I would like to understand if it is a 188LW or a 215LW...
12-05-2023, 12:13 PM | #4 |
Rep 249
Drives: 2014 BMW 228i, 2017 BMW M240i
unfortunately you'd have to lower the diff and check the part number located on the top.
12-05-2023, 12:17 PM | #5 |
Rep 4
I looked at the top of the diff with a mirror but unfortunately the white label with the BMW OEM code is no longer there…
12-05-2023, 01:19 PM | #6 |
Rep 249
hmm. perhaps there is a way to calculate the final drive using the rolling diameter of the rear wheels and inputting them into a calculator to find out what RPM's produce what speeds? This may be the only way outside of that. Unless there is a way to check in ISTA. I have heard of some people mentioning a "relearn final gear ratio" button somewhere on there.
12-06-2023, 04:20 PM | #8 |
Rep 239
If xDrive it's the 188, if RWD it's the 215. Should be simple as that, unless it's been changed at some point in the past.
n55david1295.50 |
