2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Fuel and AFR problems
      02-06-2024, 11:51 AM   #1
Chris-m240i
Drives: m240i
Hello everyone,
I introduce myself Chris, m240i owner, I am writing to you from France
I am currently having problems with my car.
I had an alert on the iDrive (powertrain) after pulling 2 and 3 gears.
It was running on 5 cylinders, I discovered that I had an open injector so I changed it.
But I still have a problem idling and I can't drive with it otherwise after a while it chatters and stalls...
Here's what's on the car:
DP
MHD Stg 2+
B58TU Pump
NGK iridium
I noticed that I no longer hear the low pressure pump when I unlock the car, yet when I activate it with ISTA I hear it...
I would like to point out that it is new (Bosch).
I tried the fuel pump control box behind the rear seat with a friend's 140i but no change...I'm dry!
Here is a log where we can clearly see that the AFR cannot be stable:
https://drive.google.com/file/d/1fS3...usp=drive_link
Many thanks for your help from France
Chris
      02-07-2024, 07:51 AM   #2
Dom147
Drives: 2014 BMW 228i, 2017 BMW M240i
2017 BMW M240i  [0.00]
have you tried going back to stock tune and seeing if it persists? It also could be a fuel quality issue.
For the logs, we need access to the file. It's not viewable for those who have the link.
      02-09-2024, 04:35 PM   #3
Chris-m240i
Drives: m240i
Thanks for the reply.
A New link :
https://uploadnow.io/f/QZz07f8
Yes i'm back to stock, no change
I added 20 liters 98 ron into fuel tank, not better...
Tomorrow i'll take the compressions to know if it's not a valves failure due to the cyl 3 opened injector...
I'll tell you the result
      02-10-2024, 11:06 AM   #4
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Upload your log to datazap.me and then post the link.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      02-10-2024, 02:27 PM   #5
Chris-m240i
Drives: m240i
https://datazap.me/u/chris-m240i/log-1707596798?log=0&data=24
      02-18-2024, 03:32 PM   #6
Aspen235
Drives: 2014 X3 35i, 2018 M240i 6mt
An open injector filling the piston with fuel can easily cause ring, piston, valve and rod damage. Try a bore scope to look for internal damage.
2addicts
