05-11-2023, 11:36 AM | #156 | |
Rep 11
"I did some deeper research and as it turns out, currently the Flexible Fast Charger comes in two variants, 1.0 and 2.0. Currently the 2.0 is what is being provided in the X5 50e PHEV however the NEMA 14-50 adapter that I told you about before is only available and compatible with the 1.0 version. There is not currently a NEMA 14-50 adapter offered for the 2.0 version. Do not cancel your inbound home charger as it will be your fastest solution available to you every day and the flexible charger that comes with the car will be best for your travels. " Given that, I've just completed my install of a hardwired EVSE made by Emporia capable of full 48Amp charging on a 60Amp circuit. $399. Easy install, seems to be a good unit, but does not handle two vehicles. emporiaenergydotcom or on Amazon. No affiliation whatsoever. |
KT_OH43.00 |
05-11-2023, 12:13 PM | #157 | |
Rep 8,789
Drives: eVeRyOnE mAD!
I liked my Emporía EVSE when I had it. I changed to JuiceBox due to incentives from my utility company and its ability to load share |
05-11-2023, 12:14 PM | #158 | |
Rep 118
05-11-2023, 12:15 PM | #159 |
Rep 8,789
05-11-2023, 01:01 PM | #160 | |
182
Rep 335
nZtiZia4719.00 |
05-12-2023, 10:32 AM | #161 | |
21
Rep 49
I have reached out to my dealer as well, but this just seems unbelievable. BMW does not have a level 2 charging adaptor for the 2.0 Fast Charger? Are there any aftermarket options? So right now the only option is to buy an EVSE we want level 2 charging at home with our 50e? |
05-12-2023, 12:37 PM | #162 |
31
Rep 48
So I did install the 14-50 outlet and tried the level 2 adapter with the flex fast charger and it does not charge. It gives an error message. I'm assuming the dealer should refund the cost for the incompatible adapter. Will there be a compatible charger ? Is my only option to buy a level 2 EVSE at this time. This will make the flex fast charger redundant. Why would BMW do thi ? Im sure there will be some correction at some point.
05-12-2023, 07:07 PM | #163 |
Rep 108
I just picked up my x5 50e. I want to charge my car during off peak hours, but in order to do that, they system requires that you set a daily departure time and conditioning. I'm retired and don't have a regular departure schedule. Every day is different. Some days I don't go anywhere. Any suggestions on how to set my system would be appreciated.
05-12-2023, 07:52 PM | #164 | |
Rep 118
05-12-2023, 07:56 PM | #165 |
Rep 6,881
It likes a departure time so that it can override the off-peak charge window to ensure that it can fully charge the vehicle when you want to use it. If there's no departure time, it should just utilize that off-peak window.
If you have a smart EVSE, you could use its timer for that purpose, or if you have some home automation, put the EVSE on a timer. |
KT_OH43.00 |
05-12-2023, 09:38 PM | #166 |
13549
Rep 20,193
iTomH is reporting that the 240v adapter he got from his dealer fits fine and charges his vehicle. I have asked him to post the part# in this thread.
https://g05.bimmerpost.com/forums/sh...&postcount=182
rexus300155.00 |
05-12-2023, 10:11 PM | #168 |
Rep 6,881
It appears that the adapter for V1 is not the same as the one for V2...so, be careful. The same is probably true for the 16A adapter. In Europe (and the rest of the world) there appears to be as many as 15 or so different ones to accommodate different plugs and charging rates. My guess is that some of the extra configuration pins are what tell the main EVSE what pilot signal to develop so it doesn't overload the circuit it's plugged into. There's a bunch more pins than needed for just power in the adapter.
05-12-2023, 10:42 PM | #169 | |
21
Rep 49
05-13-2023, 06:38 AM | #170 | |
13549
Rep 20,193
05-13-2023, 06:42 AM | #171 | |
Rep 118
https://www.bmwdirectparts.com/oem-p...81-61448490525 |
05-13-2023, 08:11 AM | #172 | |
Rep 118
https://www.getbmwparts.com/oem-part...81-61448490525 |
05-13-2023, 09:28 AM | #173 |
21
Rep 49
Just heard back from the parts manager at my dealership. He found the part number but said there are currently none in the US. They are just arriving to Germany so he is ordering some from there. Like TurtleBoy said this may indicate it is a new part and should be arriving in US soon.
05-13-2023, 09:36 AM | #174 | |
Rep 118
05-13-2023, 12:08 PM | #175 | |
21
Rep 49
05-13-2023, 12:43 PM | #176 | ||
Rep 8,789
there’s also Brit from a California-based parts dealership (forget the name here) who offers forum members discounts |
KT_OH43.00 |
