      11-05-2019, 07:40 PM   #353
Yogujuhere
Drives: X5 M50i, M850i Coupe
Originally Posted by baca8302 View Post
I had my tires switched to Pirelli Sottozero 3. So far, seems to work great with little change in the ride and appearance. These tires are 10MM skinnier front and rear, but otherwise the same measurements. According to a tire size calculator, this makes less than a 2% diameter change which is minimal.
Hey Baca,
How is this working out for you??
      11-06-2019, 06:43 AM   #354
gimix
Drives: x5 g05
Does anyone know if 9x20 ET30 is fitting on x5 with M Brakes?
      11-06-2019, 08:49 AM   #355
bizfiend
bizfiend's Avatar
146
Drives: Renting Corolla lol
You might need at least ET35
      11-06-2019, 01:03 PM   #356
Kief
Kief's Avatar
4440
Drives: '24 iX50; '23 i4 M50
Originally Posted by martinf79 View Post
22" winters ready to go... 3 coats of ceramic coating ... now I just need my M50i...
Am I crazy to consider doing the same??
You probably get more snow than me being up in Canada, and you're not concerned about those 315 sliding on top of the snow like snow shoes? And what about your roads with the freeze/thaw cycle and craters?
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired
      11-06-2019, 09:33 PM   #357
Mikli
88
Drives: G05F36F16F82E90E86E46E36E30
Agree with at least et35 front. Unless you could test fit before buying.
      11-07-2019, 02:49 AM   #358
gimix
Drives: x5 g05
I think with 15mm spacers in front I should not have problems with the brakes.
But I dont know because the wheels has a certificate for the X5 but there is an annotation that for cars with brake disk diameter of 348mm and brake disk thickness of 36mm isnt allowed. But my x5 is at the dealer and I dont know how big the m-brakes are
      11-07-2019, 02:54 AM   #359
gimix
Drives: x5 g05
Here u see the certificate and annotation Y90 is my problem ^^
https://certificates.reifen.com/w05/...1n-8-3-001.pdf
      11-08-2019, 01:42 AM   #360
Mikli
88
Yes. With 15 mm spacers will fit the M brakes.
      11-09-2019, 04:31 PM   #361
gsanto
Drives: 2019 X5, 2011 550; 2004 X5
Originally Posted by DrKevM5 View Post
Finally mounted
What Wheels are these?
      11-10-2019, 11:07 AM   #362
129kevin
Drives: Bmw x3
Winter ready!!
      11-10-2019, 02:20 PM   #363
Kief
Kief's Avatar
4440
Originally Posted by 129kevin View Post
Winter ready!!
Are these knockoffs or genuine? You running 275/35; 315/30?
      11-10-2019, 02:35 PM   #364
129kevin
Drives: Bmw x3
Winter ready!!
these are 20" knock offs, so using 275/45r20 square set up
Kief4440.00
      11-10-2019, 02:36 PM   #365
X54TH
Member
X54TH's Avatar
899
Drives: 2019 X5 40i M Sport
This is a 20" set 275/305 on Michelin Pilot Alpines with air suspension set to level 2.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
      11-10-2019, 06:35 PM   #366
Highrev1
Drives: M5
Since 19's fit with the M-sport brakes, has anyone tried style 734? It could be a nice package if you select the right tires. Just a thought.
      11-12-2019, 09:02 AM   #367
gimix
Drives: x5 g05
without spacers????
      11-12-2019, 04:57 PM   #368
X54TH
Member
X54TH's Avatar
899
without spacers????
Yes, without spacers.
      11-15-2019, 09:36 AM   #369
ferrarif1
Drives: F85, G05, E46M3
If anyone is looking for a complete 20" winter set, I somehow ended up with two setups and am selling one here: https://g05.bimmerpost.com/forums/sh....php?t=1668982
      11-15-2019, 10:43 PM   #370
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
3 days of paint correction + 2 coats of ceramic coating... 22" winters now on... ready for the snow!
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
Thumbs27.50
      11-17-2019, 05:52 PM   #371
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Here is my setup, just finished quite an involved project with twists and turns to get these on — story for maybe another post but final summary:
- powder coated OZ Racing Canyon ST rims
- square setup, 20" x 9.5"
- tires are Blizzak DM-V2, 275/45R20
- 15mm spacers on front, 22.5mm spacers on rear; result is exact stock positions
- had lots of "fun" with missing hub adapter rings and every permutation of bolt lengths ...
So far so good.
More pics elsewhere and later, need non-existent time to clean all this up and coat them, but couple of quick pics now:
X54TH899.00
Thumbs27.50
      11-17-2019, 08:15 PM   #372
ManitouX5
ManitouX5's Avatar
45
Drives: BMW X5e 2024, X3 2018, SL 550
My Winter tire setup ! DAI Wheels 181 20’’
Thumbs27.50
      11-23-2019, 08:35 AM   #373
///Armin
91
Drives: AW E92 M3
Anyone with Avantgarde M510 wheels? please post pics.
      11-23-2019, 11:29 AM   #374
Kief
Kief's Avatar
4440
I can't see them, but maybe PM the OP
https://www.bimmerpost.com/forums/sh...php?p=24153517
