08-25-2023, 11:12 AM | #2 |
Rep 6,946
Yes...power=volts*amps. The FFS device is setup to only produce a maximum of 10A when plugged into a 120vac circuit. While you can preset the iDrive menu to the maximum of 32A, because the FFS is telling the X5 it can only provide 10A, that's the maximum it will then pull from the device.
So, at 10A*120vac=1200W. If the vehicle is set to a lower amperage, that would easily force the charging level to be lower. Then, keep in mind that the conversion from ACV to DCV needed to charge the batteries (it needs about 380vdc), you won't be able to put those full 1200W into the vehicle, especially if it's warm out, and some of the power will go towards cooling. It will take a very long time to fully recharge a 50e with the FFS unless you update it to level 2 with a new cord and provide the needed new 240vac circuit to make it work...then, you can hit the maximum charging rate of 7.4Kw. US electrical code requires you pull no more than 80% of the rated maximum for the electrical circuit, so for a typical 15A circuit, that would be 12A. If you have a 20A circuit, you could pull 16A, but keep in mind that if the circuit is shared with say a garage door opener, or lights, or whatever, using the EVSE's maximum value could easily trip the breaker. It's best if the circuit is dedicated to the charging, and much faster if you can provide a 50A circuit that would be legal to plug the FFS in with the new cable. Personally, I prefer to hardwire my larger EVSE, and instead of wiring in a receptacle and buy the new cord for your FFS, I'd consider buying a hardwired, dedicated level 2 box. There's nothing wrong with the FFS, but the receptacles really aren't designed for frequent insertions and removals, and note, a quality receptacle that will last awhile, is over $100 all by itself, not counting the installation. The cord needed for the FFS is over $200 retail. Personally, I'd rather apply that $300+ to a dedicated, hard-wired EVSE, and use the FFS as your emergency backup or when charging at a friend's, or on a trip if you can't find some other place to plug in. |
jpw17258.00 |
08-25-2023, 01:22 PM | #3 | |
Rep 187
Jzomom9.00 |
08-25-2023, 01:30 PM | #4 | |
281
Rep 300
Drives: 2023 iX x50 Stormbay Metalic
jpw17258.00 |
08-25-2023, 01:33 PM | #5 | |
Rep 187
08-25-2023, 02:12 PM | #6 |
Rep 6,946
If you're lucky, one of those receptacles is a dedicated line AND is being fed by a 20A circuit. In that case, to max out that circuit, you could have the receptacle changed and the circuit breaker changed for a 16A/240vac circuit. Compared to your existing situation, instead of a max of 1200W (10A*120vac), you could get 16*240=3840 or over 3x more power...but, you'd need to buy a 16A/240vac EVSE to accomplish that.
If you're willing to run a new line, then it makes sense to probably go for a 50A circuit. With the proper cord, the FFS EVSE you have could max out the 50e's charging rate, and let it reach its 7400W maximum input, or about 6x more than what you're getting. Right now, in the USA, the version 2 FFS only has two different adapter cords...the one that came with it provides 10A, and with the optional cord, up to 40A (which requires a 50A supply to meet up with code for the 80% rule). There may be other adapter cords available (eventually), but they have not been announced that I've seen. I still would prefer to hard wire an EVSE in versus using a plug. If the plug ever gets easy to insert into the receptacle, the receptacle is worn out and should be replaced. |
08-25-2023, 04:28 PM | #7 | |
Rep 3,750
2022 G05 B58/PHEV
+ a few very old BMWs |
08-25-2023, 05:02 PM | #8 |
Rep 6,946
FWIW, there are circuit tracers that make it fairly easy to see where a line runs, but I agree, it is better to run a new, dedicated line to support both this, and your next, likely higher capacity EV or PHEV where more power is going to be useful.
But, consider, if your daily use pattern is a typical commute (about 30-miles roundtrip), it's easy to refill your batteries with just the level one EVSE that comes with the 50e. Yes, after a longer trip, it probably won't get full overnight, but you'll still probably have enough to get to work and back the next day, and gradually refill it prior to the next weekend, when you might use more. |
