09-25-2023, 07:40 PM | #23 |
Rep 3,700
45e owner here, my data keeping says these:
- sport mode with high HVB Soc: 27-28mpg on highway, 75-80mph - sport mode with almost depleted usable range: 24-25mpg on highway, same drive habib as bove - hybrid mode without charging HVB at all, so PHEV => HEV, combined city + highway, 22mpg across maybe 4-5 tanks of gas in 4 months
2022 G05 B58/PHEV
+ a few very old BMWs |
khailuan112.50 |
09-29-2023, 10:54 PM | #24 |
Rep 4,364
Drives: 2020 M850i Coupe
ICE equals smiles per gallon. I appreciate the info on the PHEV's but nuked that for my wife's LCI (got a 40i) and wouldn't ever touch it for my DD (M850i).
10-26-2023, 09:43 PM | #25 | |
Rep 132
A PHEV is both an EV and a strong hybrid, it has 2 modes of power. On a full charge (from the power grid), it operates as an EV for the first 40 miles until the battery reaches a lower threshold state of charge, then the engine comes on and it operates as a strong hybrid that is electrically assisted. When in Hybrid mode, the 50e will use regenerative braking and the engine to maintain the lower threshold state of charge in the battery...it will not "deplete the battery". So in this mode, it is operating just like your hybrid Rav4...the difference is your Hybrid Rav 4 does not have an EV mode combined with a large capacity battery where it uses power from the grid for first 40 miles. (the PHEV version of the Rav 4 does). A PHEV battery will remain at this lower threshold state of charge until it is plugged back into the grid and recharged. In theory, the 50e could use the engine to completely recharge the battery...but that would defeat the purpose of using grid power. Getting power from the grid is much more efficient than getting it from the engine, plus power from the grid is diversified (i.e., it is generated from hydro, nuclear, wind, solar, coal, gas turbine, etc.). In the PHEV, you're using power from those sources for the first 40 miles, vice getting the power strictly from petroleum. Another benefit of a PHEV is they help reduce demand for petroleum, which serves to reduce gas prices (supply & demand). In the US, 70% of the population drives 40 miles or less a day, so if everyone drove a vehicle like the X5 50e, US demand for petroleum would be reduced by 70% (in theory anyway). |
S P A C E M A N4.50 |
10-26-2023, 09:57 PM | #26 | |
Rep 8,763
Drives: eVeRyOnE mAD!
10-26-2023, 10:12 PM | #27 | |
Rep 132
nZtiZia4708.50 |
10-26-2023, 10:42 PM | #28 |
Rep 6,872
FWIW, an indicated '0' in range or '---' does not absolutely mean there's no usable battery capacity left...it's just that it can't drive at least a mile in EV mode. IOW, with regeneration and vehicle logic, it tries to always retain some power to augment the ICE and operate in hybrid mode. It won't be able to move very far on electricity alone. You may not get power to climb a mountain, but there's some there almost all of the time to augment the ICE capability.
10-26-2023, 11:06 PM | #29 |
Rep 572
Getting back to the OP question - I just finished approx. 400 miles trip from Northern California to SoCal. The battery was empty when I started the trip. I was charging the battery up to 8 miles with the hold function.
The mpg for this distance was around 30 mpg. I was really nicely surprised. This is mpg I am getting in my old X5 diesel (6 speed transmission). |
10-27-2023, 12:05 AM | #30 | |
Rep 905
Wow that is very high, much higher than the rated combined 22. Assuming you are taking I-5 which is mostly flat at 75~80mph with minimal traffic? |
10-27-2023, 12:12 AM | #31 |
Rep 572
Yes, I-5. This was smooth sailing. I left in early afternoon before the rush hour in the Bay Area and arrived to OC after rush hour. Most of the distance was in the driving assistance mode (which works really great).
10-27-2023, 12:18 AM | #32 |
Rep 3,700
30MPG on highway is nice. It is reasonable given 45e can do 27-28. 50e has better gear ratios and final drive ratio, highway MPG should be better than 45e
2022 G05 B58/PHEV
10-27-2023, 12:22 AM | #33 |
Rep 905
10-27-2023, 12:33 AM | #34 |
Rep 3,700
I think gear ratio and tuning matters as well.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 10-27-2023 at 12:44 AM.. |
10-27-2023, 12:38 AM | #35 |
Rep 905
10-27-2023, 12:49 AM | #37 | |
Rep 3,700
If you look at BWM EPA rating, G05 40i is rated at 27mpg. G01 M40i is rated at 26MPG. So even BMW think G05 is more efficient. Gear ratio appears to be the same, so maybe engine tuning play a major role for this.
2022 G05 B58/PHEV
10-27-2023, 09:24 PM | #38 | |
Rep 132
10-30-2023, 04:24 AM | #39 |
Rep 29
Just completed my first roadtrip in the 50e.
Distance traveled: 344.8 miles Gals of fuel used: 10.322 MPG: 33.4 (spot on with the car's calculation) Battery % at start: 100% Battery % at end: 8% Estimated kWh used: 18.4 Electric cost: $2.23 (assuming 10% charging efficiency loss and 11 cents/kWh) Driven entirely in the default Hybrid mode. Destination set in Nav so battery was sparingly used until remaining distance to go was within the electric-only range at which time the car used exclsuively electric and I arrived with an estimated 3 miles of remaining electric-only range. Mostly 65-75 mph just cruising. No aggressive overtakes/passing. 600 ft overall drop in elevation. Half of the drive was in light to moderate rain. First half temp in the 50s. Second half in the 70s. Headwinds/tailwinds pretty much cancelled out. I would imagine on longer drives where the electric-only portion is a smaller percentage of the total distance travelled, the MPG would be more reflective of a mostly B58 propulsion and settle-in somewhere around 29-30 mpg. 1,200 mile ICE break-in completed with this trip. So, looking forward to exceeding 4,500 rpm! Last edited by cat3dual; 10-30-2023 at 04:55 AM.. Reason: Provide additional information |
gadgetfreak2024220.00 gsquare70.00 |
10-30-2023, 06:21 AM | #40 | |
220
Rep 348
cat3dual33.00 |
10-30-2023, 07:49 AM | #41 | |
Rep 208
10-30-2023, 09:17 AM | #42 | |
Rep 572
I am not 100% sure, but I think hold will charge the battery to certain level (maybe 4 miles). I think I read somewhere here on this forum that if you turn on "hold" and after some time turn it off and on again, you will get additional miles of charge.
I did thin on this trip (on, off, on) and I got to 8 miles max. Quote:
10-30-2023, 09:37 AM | #43 |
Rep 8,763
Battery Hold does not charge up to any certain level; it will hold the current state of charge. if while driving the vehicle regenerates more battery capacity equating to increased electric mileage such as on a long downhill descent, folks would deactivate and reactivate BH so as to ‘reset’ the new held value. theoretically, one can do this a number of times to maintain a higher battery charge level than when BH was initially activated
10-30-2023, 10:27 AM | #44 | |
Rep 572
I started with 0% battery. If I didn't use hold function, the car would use whatever power it regenerated for a hybrid mode (I know this as I tested it). When I was using hold function, I think it was using ICE to get the battery to certain level (4%) and then it didn't go any further. When I deactivated and activated hold it was going above this 4%.
I didn't ready any technical documentation as it should work. This is base on my experience on ca. 400 miles trip, mostly flat, light traffic highway, so not that much regen happening. Quote:
