      03-04-2020, 10:04 AM   #111
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Originally Posted by jose260gti View Post
So if the Original bolts are M14x1.25x27mm
for 12mm Spacers in the front the correct bolts are M14x1.25x39mm
for 16mm (other brand, because there is no approvel in Switzerland for H&R in 15mm) Spacers in the rear the correct bolts are M14x1.25x43mm
Ben is really H&R delivering the 12mm and 15mm spacers with 43mm bolts?
Do we need an wheel alignment after applying the spacers?
Did you guys know about this recall????
https://bmw.oemdtc.com/368/wheel-bolts-safety-recall-19v-541-2019-bmw-x5-x7
For 11-15mm, H&R recommended 43mm shank.
H&R lug bolts sold separately.
No alignment needed after wheel spacer.
Asked because of this pdf from HR
Yea, US only offers 35, 43, and 50 shank.
And that's what listed on the US catalog.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      03-04-2020, 10:08 AM   #112
JoseSportM
JoseSportM
JoseSportM's Avatar
414
Drives: BMW G42
This country regulations.........
but thanks Ben.
I will go for this 39 and 43, for some reason they have different thinks here in europe, and in switzerland are even worse, they check every mm before the approval.
r33_RGSport12971.00
      03-21-2020, 07:18 PM   #113
kmarei
kmarei's Avatar
Egypt
687
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
Originally Posted by samvora View Post
+1 - I am also wanting to order the 15mm/20mm (if possible at 20mm for the rears - I like them sticking out just a tad bit from the fender) or maybe a 15mm/15mm square setup but I want to see if someone has them installed on 20" 740 OEM wheels.
Here you go
18mm front and 25mm rear
https://g05.bimmerpost.com/forums/sh...33&postcount=6
      03-31-2020, 11:48 AM   #114
ninekrpm
ninekrpm's Avatar
539
Drives: F80M3 (Track) / E92M3 (Street)
r33_RGSport
just picked up an M50i with the 22" wheels, looking to add spacers all around; can you PM me price for full setup shipped locally to 92705.
      03-31-2020, 12:51 PM   #115
r33_RGSport
Originally Posted by ninekrpm View Post
r33_RGSport
PM'ed.
      04-01-2020, 10:42 AM   #116
Habsone
Drives: The Ultimate Driving Machine
Hello,
Ben or anyone.
I want to lower my SAV 2019 Msport 50i. It does not have 2- axle air suspension. what are my options? Do i need Links or Lowering springs? Last 7 vin LN66396. As always any help is greatly appreciated.
      04-01-2020, 11:38 AM   #117
r33_RGSport
Originally Posted by Habsone View Post
Hello,
Ben or anyone.
Hey. You will need lowering spring.
So far I only seen Eibach that have it, but not available in the US yet.
Knowing how Eibach NA operates, it will take at least 1 year before they'll have it in the US.
Habsone73.50
      04-01-2020, 12:34 PM   #118
Habsone
Thank you.
r33_RGSport12971.00
      04-02-2020, 12:01 AM   #119
ted920
Drives: 2019 BMW X5 40i, Lexus GS 300
Im looking for feedback from those who have installed spacers on their G05 X5.
I am very strongly considering getting these spacers with 12mm front and 15mm rear. I will have 22s 742 wheels with stock height.
Interested if with the 12 and 15mm spacers, if its really noticeable or is it barely visible / noticeable.
If its barely visible then might not be worth it, if its obviously noticebale but not extreme then thats what Im looking for.
Ive seen pics on this thread but more interested in direct feedback from thoise who have installed these.
Thanks.
      04-07-2020, 05:46 AM   #120
mobilejo
mobilejo's Avatar
United Kingdom
1115
Drives: G06 X6 40i
When looking for spacers for my X6, I only had X5 pictures to work from. In the end I've gone 15mm F, 20mm R with my 21" wheels.
Before & after pics:
Appreciate 4
      04-07-2020, 02:40 PM   #121
atl_1M
Drives: '11 1M, '20 X5 40i
Good choice. Seems as if the X6 needs bigger spacers than the X5 to get the same look.
      04-08-2020, 06:02 AM   #122
chriscross
240
Drives: BMW X6M 2024, Mustang MACH 1
I was also considering to get 12/15 mm combo on my X6, but I'm still not sure what the regulations in Austria are (waiting for their email back).
If it's true that 15/20mm option would be needed on the X6 to make it look good, it would be great to know that before I actually install them. Do you have any more before/after pics you could share?
Also, which spacers did you use, do they come with the longer bolts?
      04-08-2020, 06:42 AM   #123
mobilejo
mobilejo's Avatar
United Kingdom
1115
Drives: G06 X6 40i
I had the spacers from my G30 since 2017, so I can't recall the brands. And ALWAYS use longer bolts with spacers - that is extremely important.
I did have the 15mm on the back and nothing on the front for a while, it looked better than stock, but there was room for more so I ended up moving the 15mm to the front and putting the 20mm on the back.
This is 15mm rear, no spacer up front:
      04-08-2020, 06:49 AM   #124
mobilejo
mobilejo's Avatar
United Kingdom
1115
Drives: G06 X6 40i
I agree - the rear could take 25mm or maybe 30mm if one wanted to go further. Personally, I didn't want to go wider than 20mm.
      04-08-2020, 08:58 AM   #125
mobilejo
mobilejo's Avatar
United Kingdom
1115
Drives: G06 X6 40i
Perhaps not actually - from the back, it is close to the limit:
      04-08-2020, 10:18 AM   #126
chriscross
240
Thinking out loud here...would 20mm rear be too much with my 315/30 R22s?
      04-08-2020, 01:53 PM   #127
mobilejo
mobilejo's Avatar
United Kingdom
1115
Drives: G06 X6 40i
The wheel width, tyre width and offset of the stock 21" wheel & tyre (which I have) and the stock 22" wheel & tyre is exactly the same, meaning either wheel sits in the exact same position within the wheel arch. So my results are exactly what you would end up with if they were 22".
      04-08-2020, 02:41 PM   #128
chriscross
240
Cool, thanks!
      04-18-2020, 06:57 AM   #129
jancca
Finland
28
Drives: G05 X5 45e '20&E89 Z4 35is '11
Considering 12mm front and 15mm rear for my 45e with 22" M747 wheels.
Is it a no go for using for example 15mm both front and rear, i.e. a square setup?
      04-18-2020, 07:00 AM   #130
mobilejo
mobilejo's Avatar
United Kingdom
1115
Drives: G06 X6 40i
Not for any reason other than aesthetics. The rears are visibly more pushed in than the fronts - having square spacers will just mean that the visual discrepancy is still there. If you don't mind that, then square spacers is fine.
      04-18-2020, 07:03 AM   #131
jancca
Finland
28
OK, thanks, need to take a closer look, most probably better to stick with the initial 12/15 idea.
      05-02-2020, 11:01 AM   #132
mattchew 2020
Drives: 2020 BMW X5 M50I
PM'ed
Can you please give me a quote for 15/20 with lugs and lowering links to 77042?
Thanks
