12-16-2020, 08:35 PM | #177 |
Rep 104
I wish someone posts pics with spacers without their air suspension slammed. I am not sure how 12/15 or 15/20 looks at normal height. Not everyone has AS, I fear the “skateboard” look.
r33_RGSport12971.00 cubanbimmer3310.00 |
12-17-2020, 08:24 AM | #178 | |
12971
Rep 18,717
I don't think I have the 3/4 or side shot.
12-21-2020, 01:25 PM | #179 |
Rep 704
Requesting a quote for the 12/15 kit (with extended lugs) shipped to zip 11101.
r33_RGSport12971.00 |
12-21-2020, 02:12 PM | #180 |
12971
Rep 18,717
PM'ed.
12-28-2020, 09:50 PM | #181 |
Rep 704
9 pages, and there's been no discussion about what to torque the extended lugs to with spacers... is it the same 103 ft-lbs?
12-29-2020, 09:33 AM | #182 | |
12971
Rep 18,717
With conventional designed wheel spacer (non adapter style), I do 110ft-lbs. I'll put that info on first post. So others can easily find it.
01-04-2021, 02:27 AM | #183 |
Rep 9
Requesting a quote for the 12/15 kit (with extended lugs) shipped to 91910
01-04-2021, 10:50 AM | #184 |
Rep 104
Will H&R 11mm spacer fit on the fronts? Are they hubcentric? I prefer a 11/12 set up
01-04-2021, 11:27 AM | #185 | |
12971
Rep 18,717
I have replied to your PM.
01-24-2021, 02:57 PM | #186 |
Rep 1
Requesting a quote for the 12/15 kit (with extended lugs) shipped to UK please
01-24-2021, 06:04 PM | #187 |
Rep 8,700
Drives: eVeRyOnE mAD!
hi. my first time looking at spacers. at what point do they have a negative effect on suspension components, ie bearings and such? when wanting to bring out the wheels, should i first look at wheels with lower offset numbers over spacers or the other way around?
I have Rohana 20x9 ET27 wheels both front and rear and looking to bring them out more. a photo link back in March 2020 showed 20" 741M rims but those front wheels have ET35 while the rears have ET40, and the owner used a 18/25mm setup. what would you recommend with my square 20x9 setup given the offset is different from that reference photo? i have a '21 45e M Sport w/air suspension. thanks! Last edited by nZtiZia; 01-24-2021 at 06:53 PM.. |
01-24-2021, 06:11 PM | #188 |
Rep 121
Hello,
Could you send me a quote for a 12/15 setup and the new lugs if you carry those to 11963 Thanks ! |
01-25-2021, 01:52 PM | #189 | |||
12971
Rep 18,717
If bearing on this car can't accommodate wheel spacer, then BMW shouldn't even put them in the SUV where it weight a lot to begin with. For your 20x9 +27, I would do 11mm front and 22.5mm rear for aggressive setup and will look better if you are lowered.
01-28-2021, 09:49 AM | #190 | |
Rep 8,700
with my Rohana 20x9 +27, the fronts ended up 10mm further out than OEM 21" 741M, and i'm ok with that. i think adding 2-5mm more would be splitting hairs. the rears ended up 4mm further IN compared to OEM, so i definitely want to push those out. i'm looking between 15-18mm. do u offer those? here's where i'm lacking in knowledge: will i need new wheel studs or anything else extra to ensure proper/safe boltage? please send PM with pricing/info so i can proceed with purchase. thanks for your help! Last edited by nZtiZia; 01-28-2021 at 10:03 AM.. |
01-28-2021, 01:33 PM | #191 | |
12971
Rep 18,717
So much a number can do since that is just based on the wheels itself. Tire design and shape will come to a factor. Longer lug bolts is always required. So, go ahead to the measurement and let me know what are the sizes that you need and I'll give you a quote.
01-29-2021, 01:51 PM | #192 |
Rep 8,700
02-02-2021, 02:20 PM | #193 |
Rep 136
Just want to say did the 12/15 and they are perfect. Should have come from factory with this stance. Easy install too. 15/20 might be nice too and wouldn't be overboard. I'm happy. Thx RG.
02-02-2021, 02:41 PM | #194 |
12971
Rep 18,717
Thank you for your business.
02-13-2021, 03:26 PM | #195 | |
Rep 246
Just sent you a PM for a quote. Thank you! |
02-14-2021, 09:10 AM | #196 |
Rep 246
^ I second this. I don't have Air Suspension, but ideally I want an aggressive stance (15/20). Not planning on lowering in the future though, so may have to play it safe with 12/15.
02-16-2021, 11:46 AM | #197 |
Rep 246
I found this thread showing the 15/20 set up before and after lowering with Eibach Springs. Found it really helpful considering I don't have air suspension. Love the look of the final product, so will probably wait til I'm ready to throw the springs on and go with the 15/20.
https://g05.bimmerpost.com/forums/sh....php?t=1771926 |
r33_RGSport12971.00 G8rRob3.00 |
02-16-2021, 12:21 PM | #198 | |
12971
Rep 18,717
