08-09-2007, 10:00 AM | #1 |
Rep 187
Drives: 2008 328i coupe
PS3 1080p or 1080i advanced question
I have a sony 60 tv, model # KDSR60XBR1, which is advertised as 1080P, does any body know why my ps3 only wants to transmit at 1080i, if you do please let me know what I am doing wrong. I bought the $50 HDMI cables from sony.
here is a link the my TV specs http://www.sonystyle.com/webapp/wcs/...uctId=11038061 Thanks! |
08-09-2007, 10:35 AM | #2 |
Cunning Linguist
145
Rep 2,219
something must be up with the TV, as far as i know, Sony's do 1080p only thru HDMI, components are 1080i.
Bottles are for babies, Real men get blown.
08-09-2007, 11:08 AM | #4 |
Rep 187
thanks for the info, someone told me it depends on the native resolution, but the manual claims its 1080p
08-09-2007, 12:14 PM | #5 |
Rep 95
I've got a KDSR50XBR1 which uses the same display unit as your set and I've done a bit of research on this issue...
The XBR1 series sets do indeed use a 1080p display unit (it's a 1920x1080 LCoS), but only have 1080i inputs... There's an internal scaler that takes any input signal and scales it to 1080p - the native resolution of the display unit. In the case of 1080i, it takes the 1080i/60fps signal and converts it to 1080p/30fps... There's no loss in quality doing this - only a loss in framerate (which supposedly can't be seen). A number of people on avsforum have said that the scaler in the XBR1 series sets is about the best that's ever been put in a TV, and is better than the scaler used in the "true" 1080p XBR2 sets. Since most things aren't using 1080p (yet), having the better scaler is more important to me than having the 1080p capable inputs. Sony had talked about releasing an upgrade to allow the inputs to support 1080p, but they ended up scrapping that idea. So you do have a 1080p set, but it only has 1080i inputs. Actually, it has one 1080p input - the FireWire/iLink port on the front, but nothing uses it... That's the only one. Hope that makes sense...
2006 Corvette Z06
Black / Ebony - 459RWHP / 438RWTQ 2005 Subaru Legacy 2.5 GT Wagon Brilliant Silver / Tweed M5 - 229AWHP / 260AWTQ |
08-09-2007, 01:19 PM | #6 |
Rep 187
gtb75,
smart man. I just hate the fact that that my playstation 3 tells me that my TV max resolution is 1080i. |
08-09-2007, 01:41 PM | #7 |
Rep 5,623
i have this tv here also by sony. http://www.sonystyle.com/webapp/wcs/...uctId=11040753
i only got 1 hdmi port which is used for my hd cable box. so when i use the factory ps3 hd cables i am not gettint a true 1080p? |
08-09-2007, 02:31 PM | #9 | |
82
Rep 76
Drives: Crazy
I'd been using a couple of $15-$25 HDMI cables since 8mons and they work just fine. |
08-09-2007, 04:15 PM | #11 |
Rep 95
These guys have great prices on good cables: http://www.monoprice.com/home/index.asp
Lots of people on avsforum use / recommend them... Great service too!
2006 Corvette Z06
08-09-2007, 08:13 PM | #12 | |
Rep 2,984
"...I maybe drunk, but you're ugly, and I can sober up..." |
08-10-2007, 12:17 PM | #13 |
Rep 187
BeeEmDubU
I agree 720p is looks better than 1080i but evryone else says 1080i who knows??/ |
08-10-2007, 02:28 PM | #14 | |
Cunning Linguist
145
Rep 2,219
It's odd that my non-xbr (SXRD: supposedly lower line then XBR) has HDMI inputs that takes 1080p. My XBOX looks pretty darn good over HDMI and so does Blu Ray.
08-10-2007, 02:30 PM | #15 |
Cunning Linguist
145
Rep 2,219
also check http://www.firefold.com for cables. they are pretty good priced as well.
08-10-2007, 02:40 PM | #16 | |
Rep 4,021
Drives: 2008 335xi Coupe
Most of the new Sony TV's take native 1080p through HDMI, the OP unfortunately has an earlier model Sony that is a non-XBR
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
08-13-2007, 05:33 PM | #18 | |
Rep 4,021
Just a little off tangent for this thread but 3.91 and 4.1 gears are standard BMW Motorsports gears. The 3.91 is a good compromise that works on the street and track. The running gear for M5 / M6 are identical, stock rear end is 3.62.
08-13-2007, 05:45 PM | #19 |
Rep 5,623
isn't the general aspect of 4.10 gears on a n/a car true so you can accelerate a tab better and stay in gear longer, thus installing it on a s/c is no good b/c you have to shift too soon like in the m3 s/c which most members use 3.91.
08-13-2007, 05:51 PM | #20 | |
Rep 4,021
You cannot look at rear end gearing in isolation of the transmission gearing and the engine powerband. You cannot make generalizations such as 4.1 gearing is better on an N/A car.....
08-13-2007, 07:39 PM | #21 | |
Rep 95
But yes, I believe Sony started putting 1080p inputs on SXRD sets starting with the A2000 series (first non-XBR to offer SXRD) for their standard line and the XBR2 series for the XBR line. Those of us with the original SXRD XBR's are the only people with sets that use the SXRD image engine but don't have 1080p inputs.
2006 Corvette Z06
