06-03-2018, 10:32 PM | #1 |
Rep 94
Why does my heater or A/C turn on every time I start my car?
I have to turn it off every time I drive. It was off when I exited the vehicle but turns on automatically. Is there anyway to stop this?
06-03-2018, 10:46 PM | #2 |
Rep 4,456
You might be able to save it to be turned off under your profile? I was just messing around with mine and there was 3 profiles and a guess you can save setting to. Probably have to do some reading in your manual to figure it out.
06-03-2018, 11:22 PM | #3 |
Rep 6,920
Drives: 2018 M2 AW DCT
If I have ac and heating off, next time I start the car it is still off.
06-04-2018, 12:08 AM | #4 |
Rep 5,577
thought the hvac automatically coming on was a luxury car style feature,
It was a way to assure the windshield was clear of fog or condensation. And it circulated oils in the a/c compressor for maintenance - and maybe even keep the ducts from accumulating odor. Just guessing. |
06-05-2018, 07:33 AM | #5 |
Rep 116
Mine does the same thing. No idea why and how to disable it. Going to subscribe to this thread to see if someone has a fix. Mine is a 2015 Z4 35i.
06-05-2018, 09:49 AM | #6 | |
Rep 598
I get it is personal preference but a luxury car should be providing temperature + humidity controlled air filtered by activated charcoal filters all day every day. But to answer OP, you can code it off to stay off each time you start your car. |
06-05-2018, 09:53 AM | #8 | |
4995
Rep 4,139
06-05-2018, 09:56 AM | #9 | |
Rep 598
Wet sock smell = time for new cabin filters |
06-05-2018, 10:05 AM | #10 |
Rep 94
No, I mean it literally comes on automatically. Every time I get in the car it starts blowing and I have to turn it off. It's off when I get out of the car (because I turned it off when I originally got in), but when I get back in to drive again, it starts blowing again, even though I had shut it off last time I drove. For me it's annoying, but not the end of the world...lol. I just was asking to see if it was a setting I could easily adjust.
06-05-2018, 05:42 PM | #12 |
Rep 5,457
Drives: F30
Mine used to do this. Coded it off with BimmerCode. I like to decide when the HVAC system is on and off.
06-06-2018, 06:55 AM | #14 |
Rep 116
06-06-2018, 10:55 AM | #15 |
Rep 7,452
If you have the IHKA (automatic climate control) you can go into iDrive and change the settings to keep the system OFF.
As others mentioned...the design of an auto climate system is to be on...if nothing else to run the cain air through the microfilters to help with pollen/dust/etc. If you don't have allergies (yet)...this feature is MUCH appreciated when spores/tree pollen etc season rolls around. In many BMW models with IHKA...the system will maintain whatever setting for around 16 minutes. So if you had the system OFF...then stopped at the drug store or bank etc...and you came back to the car within the consumer cut-off interval (which is usually 15-16 minutes)...the IHKA will remain OFF. If you return after a longer period like 30 minutes or an hour...then the IHKA will turn itself back on (usually at the lowest setting). If you still want the system OFF...then all it takes is usually a single press of the fan speed button (on the older gen BMWs...it was a single press of the "-" fan speed button). The FUNKY smell from the vents can be avoided by drying things out prior to putting the car away wet. The "smell" is created when you park the car in a dark & wet/humid enviroment (like pulling into a dark garage when you come home for the day). Bacteria & mold grow rapidly in a dark/humid environment. So if you are parking (especially indoors) in the dark after running the AC...depending on what part of the country you're in or how hot it is...you can either shut down the AC (snowflake button) and just allow fresh air to blow across the condenser (you may have to roll the window down if tolerable). If the ambient temperture is too hot or humid and there's no way you're turning off the AC before parking in the garage...then use the "park ventilation" feature that allows the IHKA to run the blower for up to 30 minutes after turning the engine off and removing the key. This will have the same affect of drying the condenser and preventing mold and bacteria from having a perfect scenario for "getting it on"...which is going to end with you having that FUNKY odor every time you turn the blower on. |
shadowfax1289.00 |
06-06-2018, 04:28 PM | #18 | |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
have to code your ac module IHKA IHKA memory code to aktiv - that way it will remember your setting from before you turned the car off... I have it coded because my AC did the same thing and I hated it! It would always be on and with open to air and I like to always have it with recirculating air... try that coding!
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
06-06-2018, 07:36 PM | #19 |
Rep 209
on my 2014 335 it did the same you'd have to code that off. however in my new 2018 340 it starts with however i turn the car off. so if its off, turns on off. If its left on, it turns back on, ON.
06-07-2018, 12:46 AM | #20 |
i'm just saying
5725
Rep 2,634
i guess there are 2 options..
1. i dont know if there is a setting in iDrive you selected to put the AC after some temperature automatically.. F90 5 series have something like this for heated seats donno about your car you better check your iDrive.. 2. if you using the ventilation system in auto it engages AC most of the time starting from spring.. take it out from auto and direct the flow somewhere and you can check again.. |
06-13-2018, 12:18 PM | #22 | ||
18659
Rep 14,107
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
