      08-24-2019, 04:35 PM   #309
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
Just noticed bimmercode updated and says it supports ID7 headunit now - will take a look in a bit maybe some new options we can code for idrive now.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      08-24-2019, 04:44 PM   #310
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
Updated on iOS or Android? Don't see a recent update on iOS in Canada yet.
      08-24-2019, 05:16 PM   #311
hkleyman
hkleyman's Avatar
Drives: 2019 BMW X5 50i M-Sport
It does look like there's some new stuff. https://www.bimmercode.app/cars/g05/
      08-24-2019, 05:51 PM   #312
roadkillrob
Android was what I was using - loaded it up and changed some stuff, the standard stuff you can usually do in idrive, remove all the legal disclaimers at startup, startup animation you can switch to M, Mini, Rolls or BMW, turn on temp on pressure sensors and a few other things. Video in motion is an option, I turned it on and then it said there was a second step and you had to push the idrive controller up while it reset and then it should open a speedlock menu - tried a few times didn't seem to work, so will try video in motion at some point but seems it may not be fully unlocked on mine with the second step failing.
2008 E93 335i FBO
      08-24-2019, 08:19 PM   #313
X54TH
Member
X54TH's Avatar
893
Drives: 2019 X5 40i M Sport
I'm not seeing it in my app either but if you go into supported cars and go to the G05 I see a bunch of stuff.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
      08-24-2019, 09:38 PM   #314
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Any word on programming the trailer hitch?
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      08-25-2019, 08:15 AM   #315
X54TH
Member
X54TH's Avatar
893
Just got the App update in Canada and see a lot of stuff like starting the X5 in Eco Mode. Any chance to start this in Adaptive Mode? I saw someone having the ability to remove the startup warnings but I didn't see that in my App.
Correction: the Eco Mode was related to turning off the Start Stop feature.
We still can default to a drive mode.
      08-25-2019, 08:39 AM   #316
X54TH
Member
X54TH's Avatar
893
Sorry guys, I stand corrected. When I Connected the unit nothing has changed from the options we had in the original programming. Maybe it's a Canadian thing.
      08-25-2019, 09:07 AM   #317
roadkillrob
All the newer stuff I saw is under headunit, I am also n the beta program.
Did you have headunit before, the notes specifically say they added it on the 22nd.
WHAT'S NEW
- Coding of the new ID7 headunit
- Bug fixes
2008 E93 335i FBO
X54TH893.00
      08-25-2019, 09:42 AM   #318
X54TH
Member
X54TH's Avatar
893
WHAT'S NEW
- Bug fixes
Sorry, you are correct. I had trouble with the VIM as well. I couldn't bring up the speed lock.
      08-25-2019, 09:59 AM   #319
archivedaccount
Guest
n/a
Drives:
WHAT'S NEW
- Bug fixes
My guess is the dev forgot to code
SPEEDLOCK_FREISCHALTMENU to active.
      08-25-2019, 11:23 AM   #320
robby818
Drives: M2
What is Headunit HU_MGU? I am in the US and I have a different headunit so the new options are not available for me.
      08-25-2019, 12:22 PM   #321
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
I would say the new coding for HU_MGU are working, at least for me: Canada, 3/2019.45, coding on Android just now.
Love that I can now see the temperature. What was up with not including that by default BMW, how can that be detrimental to drivers or a liability issue ... so many stupid UX decisions ...
      08-25-2019, 01:09 PM   #322
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
WHAT'S NEW
- Bug fixes
No, I can see it set Aktiv in Expert Mode.
      08-25-2019, 01:38 PM   #323
archivedaccount
Guest
n/a
Drives:
Can you access the speedlock test menu?
iDrive controller held up, Media, Home, Media?
LexxM31697.50
      08-25-2019, 01:41 PM   #324
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Ha, yes! Was set to normal. Now changed to "deactivate Speedlock"
      08-25-2019, 01:43 PM   #325
archivedaccount
Guest
n/a
Drives:
Bingo! ViM should work OK now. Really good quality screen as well. Kids love it.
LexxM31697.50
      08-25-2019, 01:44 PM   #326
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Nice. Any other secret menus? :-)
      08-25-2019, 04:14 PM   #327
agzx517
Drives: MW G05
Head Unit
Hi guys, How do I know my head unit? I really need video in motion for my son. Im in the US. Also if anyone had done it, can you please tell me the adapter you used. Thanks
      08-25-2019, 04:33 PM   #328
roadkillrob
Nice thanks for this, when you code it, it tries to open that menu, tells you to hold the idrive controller in the up position and it restarts idrive but it doesn't work for some reason, that key sequence will do it!
2008 E93 335i FBO
      08-25-2019, 04:35 PM   #329
roadkillrob
All G05 X5's in the US should have MGU idrive 7 which you can code Video in motion now. any of the adapters on bimmercode's website should work, I use the OBDLink LX for android to do mine. https://bimmercode.app/adapters/
After you activate it in the coding you will have to follow the instructions eaglesrest posted above to remove the speedlock on it.
Rob
2008 E93 335i FBO
      08-25-2019, 04:44 PM   #330
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
+1
I'll add that:
- I am using OBDLink MX+ on both iOS and Android
- there has, in fact, been geography issues with Bimmercode in the recent past, even between US and Canada
- there can be issues dependent on iDrive version and/or ISTEP version
The last two are just cautions. Coding is complex and Bimmercode developer is obviously swamped with the massive fragmentation of systems from BMW: # of models x # of options x # of countries x # of software versions = a rather massive number of permutations that cannot be tested explicitly (impossible number of test environments). Send him some money, it is existentially motivating when faced with this kind of complexity.
