02-07-2019, 04:39 PM | #47 |
Big Beaver Smile
2101
Rep 3,790
I wanted something different than the same ole same ole black BMW/Weathertech ones I've been using for the last 100 years. Since my X5 will be at the shore every weekend, I knew it had the beach-vibe I wanted when I saw it in Roundel from coco mars.com. I had to wait a while for them to get the pattern from BMW, and they gave me choices of cutouts for nets or not, but it fits like a glove, and no sand is getting under it! It's thick and really well made
06-01-2019, 08:15 AM | #48 | |
Rep 72
I am looking for a full liner as I haul dogs and am looking at the ultimate pet liner. Not a huge fan o& the shiny look, but it won’t hold dog fur and is water proof (no lip so don’t spill a lot of liquid). Each option has its pros and cons. https://www.cargoliner.com/collectio...mate-pet-liner |
wrickem2101.00 |
06-01-2019, 09:09 AM | #49 | ||
Big Beaver Smile
2101
Rep 3,790
Your link looks like a perfect liner for total coverage when you don't feel like vacuuming out dog hair from the side carpeting
06-01-2019, 09:24 AM | #50 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
orthopod49.00 |
08-17-2019, 11:28 AM | #52 |
Rep 7
Does the OEM one have a raised middle section or is that an optical illusion because of the design patterns? If it has a raised area, then that makes it a no-go for me to stack containers and boxes.
08-17-2019, 01:39 PM | #54 |
Rep 4,437
Drives: 2022 iX xDrive50, DGM
08-17-2019, 01:47 PM | #55 |
Rep 1,386
Drives: 2023 iX xDrive50 & 2020 M850i
Where did you get the rubber mat? It looks like what we had in our Land Rover and E53. The plastic WT one we have in our F15 just slides around and curls up by the tailgate and drives us nuts. I would much rather have the rubber style again in our G05.
08-17-2019, 03:21 PM | #56 | |
Rep 7,361
Click link below to get (or see) which 11 digit part number you need..then type BMW xx xx x xxx xxx (where x=the actual BMW part number) into a google search box to find vendors that sell the item...or call your local BMW dealership's parts department and have them order it.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-17-2019 at 03:49 PM.. |
08-18-2019, 05:04 AM | #59 |
Member
892
Rep 2,029
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [0.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
That's the one I bought at the time of delivery. I'm not overly impressed with the thickness unlike the mat from the F15.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
08-18-2019, 09:28 AM | #60 |
Rep 4,437
08-19-2019, 12:47 AM | #61 |
Rep 7
I am considering buying the X5 OEM cargo mat too but from the pictures posted here it seems not only the sides are raised but also the middle section is raised as compared to the wavy areas on the two sides. Or is that just an optical illusion because of the design patterns?
If the mat is not flat then how does it work with containers and boxes that would wobble if not on a flat surface? |
08-20-2019, 05:56 AM | #63 | |
Rep 85
The reason I ask is that I went to get my mat (similar one as yours) from the dealership and it wouldn't stay put. Just a touch of the hand it would move. There is a velcro thing under it but its not much use. Or did you use some other tricks to keep it from slipping and sliding inside. |
08-20-2019, 08:52 AM | #64 |
Rep 25
It couldn’t slip or slide if it wanted to as it is molded to fit the space like a glove. And it still wouldn’t slide because it’s a very soft grippy vinyl/rubber material that grips the carpet it sits on and things you put on it grip it. My only complaint is no cut outs for the cargo hooks in the corners.
08-20-2019, 09:20 AM | #65 |
Rep 978
Update - I've been using the OEM mat for a little over 8 months and would not recommend it to anyone who frequently access the storage space underneath. The side edges have a reverse lip that catches/hangs/scrapes on both sides as you lower the hatch (and mat) back down. Once closed, left as is, the edges stay bent up/distorted and looks like crap. If you leave it that way, the tray gets sort of a memory and does not return to its original shape. Yes, to avoid the memory problem, you can pull the mat out and slide it back in - every time.....
Pretty bad design that functions poorly when used in conjunction with the cargo storage. |
08-20-2019, 09:07 PM | #66 | |
Member
892
Rep 2,029
orthopod49.00 BMW FINALLY!169.50 |
