01-08-2019, 10:44 AM | #2 |
13262
Rep 19,783
It has front and rear emergency braking.
Bollywoodkid9.00 LarsFj1.50 |
01-08-2019, 11:07 AM | #4 |
Rep 99
I was asking since I am coming from a Lexus Rx350 and whenever in the parking lot if i got to a car to close it would brake for me avoiding the collision at lower speeds...so I was curious if the new X5 had that as well
01-08-2019, 11:13 AM | #5 |
Rep 5,324
My last vehicle had it as well. I honestly can’t believe the BMW X5 doesn’t offer this common feature. I did the test with my daughters pop-up Barbie tent in my drive way and the alarms go off when getting close but no brake intervention.
01-08-2019, 11:22 AM | #6 |
Rep 165
Did you test the Barbie tent both forwards and backwards?
amphiprion195.00 |
01-08-2019, 11:26 AM | #7 |
162
Rep 360
I was going to ask the same question. We have a q7 and it wont let you get into an accident. it has helped several times and will come up with a big triangle if its getting ready. I have seen no indicators on my x5 that there is anything there. Odd considering the cost.
01-08-2019, 11:31 AM | #8 | |
Rep 99
01-08-2019, 11:32 AM | #9 |
Rep 5,324
Yes. I also told this to my CA and he couldn’t believe it so we did test in the parking lot. He stood behind the x5 as I backed up and I tapped him. We tried this test several more times and I hit him every time. This means if you left your kids bicycle behind the vehicle or there’s a kid standing back there and you’re not paying attention to the screen or the warning beeps you’re going to hit them.?????
You might want to put a cardboard box with a towel over it and try this yourself at low speed. Backing out, your vehicle should/may apply auto braking. Since no one has actually seen this feature work I am skeptical. UPDATE: Just called genius vehicle should automatically stop in these situations. He recommends me taking my vehicle for service thing for this feature? So I would test your systems in a similar way perhaps this is a bug.. Genius says if you have “Automatoc PDC activated” it should brake automatically. The issue I see is this “Automatic PDC activation” shows on the menus as activating parking view when approaching an obstacle at low speed.. My vehicle does that but doesn’t mention anything about a auto brake activation, just a camera operation. Something isn’t adding up. Last edited by MystroX5; 01-08-2019 at 12:03 PM.. |
01-08-2019, 12:11 PM | #10 |
Rep 276
Drives: 2019 X5 50i
I know in Audi and VW, this "brake maneuvering features" must be disabled if you have a hitch-mounted bike rack, or the vehicle constantly brakes when trying to reverse. I for one am glad it doesn't brake on the X5, as I would have turned it off.
01-08-2019, 12:38 PM | #11 | |
Rep 165
01-08-2019, 01:11 PM | #12 |
Rep 5,324
No, just stand behind the X5 but neither direction stopped with the tent. I have used this size tent with other vehicles and it does trigger the braking system with those. I am asking my CA to test another X5 off the lot and see if it has emergency braking. I am not sure anyone actually knows if this feature is active. This is why I test this stuff out. Perhaps a few forum members need to test theirs. Its kinda important to know what it does in this situation.
01-08-2019, 01:24 PM | #13 | |
Rep 99
01-08-2019, 01:31 PM | #14 |
Rep 129
On the Q7 I have triggered this auto braking couple of times and both times it was a false alarm. Better be safe than sorry and I really appreciate this feature. I assumed the X5 should have it too. Does the user manual provide any details on this?
01-08-2019, 01:37 PM | #15 |
Rep 5,324
Nope. It's very cryptic on brake intervention.
01-08-2019, 02:03 PM | #18 |
Rep 5,324
Those test are at higher than parking lot speeds. We are using the low speed parking system that relies on the sonar proximity warning. This system was designed to reduce low speed bumps in parking lots. It is now used on a lot of lower mid range cars because the system only requires a sonar based system to detect an object obstruction.
Our significantly more sophisticated system uses a camera base that actually highlights each obstruction on screen and works in tandem with the sonar system with a series of beeps. What we are not seeing is our system actually applying an emergency brake if you get too close to a object while parking. Last edited by MystroX5; 01-08-2019 at 02:11 PM.. |
01-08-2019, 02:11 PM | #19 | |
179
Rep 301
01-08-2019, 02:16 PM | #20 |
Rep 5,324
Easiest identification is to take a cardboard box or couch cushion out behind your vehicle or in front of your vehicle at a distance of about 10 feet. Start your vehicle up and slowly proceed towards it as if it were a obstical. Don’t touch the brakes and see if the vehicle stops. Obviously use a towel or soft item so if your bumper touches it, it won’t cause any harm. I have always used a kids pop-up play tent.
01-08-2019, 02:27 PM | #22 |
Rep 1,073
Agree, that title makes me laugh. Some I spoke to did not even know some of the basics. I was aware of more things just by reading this forum. Perhaps part of their job should be to read this forum 1 hour a day
