05-19-2019, 09:56 PM | #4 |
Rep 32
This is interesting. I have the same issue. Cant pin point the location but seems as if its around the rear view mirror area. If anyone takes it into service please post update.
2019 BMW X5 G05 MSport xDrive 50i
2015 BMW M4 F82 2015 BMW X5 F15 xDrive 35i |
05-20-2019, 05:05 AM | #6 |
Rep 23
05-20-2019, 02:28 PM | #7 |
Rep 66
Have You got a sun roof? A few days ago I was at a dealership in a different case, but I also reported whistle issues above 200 km / h. They said that they had already met with this problem, the issue of some too high seal in the roof. They told me that they improved something, for now there is no whistling ...
05-20-2019, 03:00 PM | #8 | |
Rep 23
05-21-2019, 12:31 AM | #9 | |
Rep 13
05-21-2019, 06:44 PM | #10 |
Rep 4,553
I had a similar issue with my 2014 F30 when reaching certain RPMs or throttling on/off accelerator.
Here was the fix for that issue. At the time I never would have guessed it was a resonating hose. Hope this helps guide you to a fix. https://static.nhtsa.gov/odi/tsbs/20...47979-9999.pdf
2023 840GC | 2021 740i | 2019 X3
Usher938776.50 |
06-01-2019, 01:25 AM | #11 | |
Rep 66
Mine sounds like this: |
06-02-2019, 01:43 AM | #12 |
77
Rep 245
Holy cow, I thought I was the only one having this problem. I reported this to my dealer on the last march but they told me they can't reproduce it. At that time i was concerned about my KAFAS camera issue so i didn't take too seriously.I used to hear the noise above >140KM/hr
06-02-2019, 02:05 AM | #13 | ||
Rep 4,553
Try turning off the ventilation system and switch the vent box to floor vents and see if it changes the sound at all.
06-04-2019, 06:10 PM | #14 |
Rep 4
My dealer send a note to BMW and I'm waiting for the solution yet. I have the same problem in my G05 X40
06-12-2019, 03:10 AM | #15 |
Rep 66
Solution? Windshield defective pasting
Hello,
on the German forum there was an information that the cause is a defective pasting of the windshield - after the exchange and re-gluing, already at the dealer ("manually" and not by the "robot" in Spartanburg), the problem disappears. I forwarded the info to the dealer, I am waiting for a reply. Maybe you also can give it to Yours dealers - maybe the solution will be confirmed. links (user Manni512): https://www.motor-talk.de/forum/fest...4.html?page=15 - diagnosis https://www.motor-talk.de/forum/fest...4.html?page=20 - confirming a solution greetings |
06-25-2019, 12:07 AM | #18 |
Rep 272
Same problem
I also have same issue, whistling but at lower speed of more than 80 km/h but its random.
Tried closing all the windows but still no luck, mostly occurs on motorways where there are side walls. Haven't noticed on open motorway so far. |
06-25-2019, 07:22 AM | #19 |
77
Rep 245
As I mentioned earlier I do get whistling noise above 120K I reported to the dealer around March but they told me they can't replicate (obviously). Few weeks before I applied seal protectant on the door seal and I don't hear those whistle noise so far. Not sure that fixed it or not
OzJedi107.00 |
07-01-2019, 02:56 PM | #20 |
Rep 66
The problem seems to have been diagnosed and solved. The day before yesterday I picked up my car after visiting a dealer. The windshield was reinstalled. I drove until 205 km / h and so far everything was ok - silence ... So it was confirmed - the problem is the wrongly mounted (too high) windshield.
07-14-2019, 06:07 PM | #21 |
Rep 19
Hi everyone! This is my first post at Bimmers.
This thread has helped me solve the same exact issue I had with my brand new X5 30d (june 2019). The whistle noise heard in your videos on youtube sound exactly the same! Though it sounds like coming from the sunroof...it does not!!! As JacekPL mentioned, it comes from the windshield! But no need to replace it. The "issue" is the rubber/plastic in the transition from the bonet in the bottom part of the windshield that is not correctly adjusted to the windshield... On the side where I noticed the whistle coming from, the rubber was not properly mounted/fitted... looking as if in the production line the assembly was not properly done. So i just pressed a bit against the windshield from inside the bonet and it adjusted perfectly! No more noise at highspeed! Unfortunately, I only have a photo of it fixed... hope it helps other people with the same problem. Best regards!! |
07-14-2019, 09:36 PM | #22 | |
Rep 4,327
