08-23-2019, 06:28 AM | #1 |
Rep 124
Please Vote - should I open my windows??
A month ago I was at the snow (yes - australia) in sub 0C conditions and opened 2 windows, which would not subsequently close. We had to drive down the mountain with open windows.
The dealer replaced both window mechanisms and raised a Puma case. There are also other reports on this forum of similar window issues. BMW won't tell me if there is a systemic manufacturing fault or the root cause, and will not replace the other 2 windows (until they fail). Should I try opening the other 2 windows while I'm on the mountain again this weekend and it is below Zero? If they also fail, it will establish there is a manufacturing fault, but I'll be driving 5 hours with the windows unable to close. Not happy to have a car with windows I can't trust. What would you do? |
08-23-2019, 06:34 AM | #2 |
20
Rep 47
Did they replace the mechanisms with the same type or a different type? If the same type then what do you expect the new ones to do differently? Did they indicate why they failed, or what to do to avoid failure?
08-23-2019, 06:55 AM | #3 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
The temperature shouldn’t really matter unless moisture was in the mechanism and somehow froze. Try opening them when you are in a normal climate and see if they close. You might want to do that a few times before you try the mountain experiment again.
08-23-2019, 09:59 AM | #4 |
Rep 602
Regardless of moisture present, if parts aren’t designed to account for the contraction and change in rigidity and flexion tolerance that occurs with drops in temperature, then temperature could absolutely be a factor. Definitely better to find out while under warranty. I would open them. It’s not like the manual says do not operate while on mountains.
08-23-2019, 10:11 AM | #5 |
13178
Rep 19,667
Just do what you would normally need to do and don't worry about it. If something goes wrong then it will be a pain but you can then get it fixed so it isn't on your mind very time you make a similar trip.
08-23-2019, 12:28 PM | #6 |
1053
Rep 1,951
Definitely open them - better for them to break while under warranty. I would wait until the end of your trip though so you're not potentially driving with your window down is freezing weather. I would also open the windows that broke before. I can't imagine BMW wouldn't account for freezing temps in the R&D phase. This isn't their first ever car....
08-23-2019, 02:52 PM | #8 |
Rep 506
At least open one window. If there is a problem the only way you are going to get it fixed it to make it fail again.
I'd try driving with my window open to see if it fails for you but I live in Florida |
08-24-2019, 02:03 AM | #9 |
Rep 124
Thanks for all the responses - most of you are suggesting I try the windows but will need to be with sub zero temps. 5 hour drive with window down if they fail again
BMW advised the nylon gearing in the mechanism broke - but no explanation if replaced with identical part. |
08-24-2019, 06:41 AM | #10 |
Rep 506
It seems like the gear itself would not be the source of the problem, it would be the result of something else freezing which resulted in putting enough stress on the gear to break it.
Maybe enough moisture from melting snow got into the window tracks to jam up the pane. When we lived in New England sometimes doors and windows would freeze up in cold weather if the temperature was just right and the snow (or rain) melted then froze on the car. Hopefully, you just hit exactly the right, unlikely, conditions for this to happen and it will never happen again. |
08-24-2019, 09:21 AM | #11 |
Rep 3,506
Ford had a big issue last year with their F150 models where the drain tube in the control mechanism was blocked by sealant over squeezed out into it. It was a quick easy fix but was a swap of the whole unit if you take it to the dealer. Maybe something along those lines might be happening?
Moisture is inside the door because the metal parts sweat from the warmth inside the car after driving, that is why the car door has holes and will drain. The insulation is on the inner door side not the outer which is where the parts are located between. Just thought I'd add this part.
2022 M8 Comp Convertible
08-24-2019, 10:04 AM | #12 | |
Rep 4,318
08-24-2019, 02:53 PM | #13 | |
Rep 7,452
If you forced the windows opened when they were frozen and you had an indication at first press of the button that the windows were "stuck"...then I wouldn't worry that there's an issue with the windows that didn't have their "mechanisms" replaced. I'd just be cognizant that if their buttons are pressed to open and they don't start to go down...STOP the process immediately because forcing them to open when they are indicating in the 1st few seconds that they're stuck ...is not a good idea. Ive had my windows not open during sub zero conditions when due to precipitation and sub zero conditions...the windows are frozen shut...and either need a longer period with a heated interior to thaw out...or to be parked in a warmer location to thaw out. But I NEVER try to force them open in this condition knowing that damage can occur to the regulators or motors. I just wait until I can get the vehicle in warmer condition to allow things to thaw.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-24-2019 at 06:43 PM.. |
08-25-2019, 09:14 AM | #14 |
Rep 124
Returned from the ski trip today and (un)fortunately temperatures were above zero. So was not able to test the windows in sub zero conditions.
All windows worked fine. Unfortunately I will not get to try this again for another year now I think the theory that moisture got into the internal mechanism then froze, is the most likely cause - although BMW has not provided any useful insight at all. If this is true, then all G05 would be susceptible in the right set of conditions - unless BMW has changed something. Qsilver7 - when the windows failed, they were not iced up and they opened without any trouble. A 'crunching' sound was heard in the mechanism as soon as I tried closing them. I am now left driving a car for another year without knowing if the windows will fail again. I am tired of getting stonewalled by BMW with no root cause or explanation - honestly they seem to treat their customers like !@#$ |
08-26-2019, 02:36 PM | #15 |
Rep 7,452
Thanks for the additional info...it does paint a broader picture of the issue.
