04-20-2021, 12:17 PM | #23 | ||
311
Rep 332
As for the apps, yeah I completely follow that logic. I've had times where I've used Waze or Google maps without the wireless charger and my phone will still get hot as all hell. Plus no case to insulate the heat from my hand so you feel it within seconds
SSMXV
04-21-2021, 11:51 AM | #24 |
Generalissimo
651
Rep 1,402
Do you mean the lightning symbol on the charging indicator in Apple CarPlay?
04-21-2021, 12:32 PM | #26 |
Rep 8,719
Drives: eVeRyOnE mAD!
04-21-2021, 01:48 PM | #28 |
Rep 108
I got it to go red/orange once when I had my device in one of those cases with the large metal plate for the magnetic phone mount - worked fine upon removing the case, but I can attest to the LED on the tray going to a color other than blue!
Last edited by phillydilles; 04-21-2021 at 04:15 PM.. Reason: I know my colors, I promise! |
04-21-2021, 03:09 PM | #29 |
Generalissimo
651
Rep 1,402
Can you try to make it red again and see what the phone widget shows?
04-29-2021, 10:48 PM | #30 | |
85
Rep 318
Drives: MY19 X5 40i
*don't mind the music…….is for my little one
Brandan
What?s next ? BMW X5 40i Audi Q3 Toyota Corolla S Nissan Murano |
nZtiZia4674.00 phillydilles74.00 |
05-01-2021, 08:57 PM | #31 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Using iPhone X in a case with the NFC digital card sandwiched in between, here are a few observations:
When the phone charge is low and I start charging it on the tray it gets warm to somewhat hot, but if the phone is already charged to begin with then the phone is less warm - understandable, because it's not being charged much. My conclusion is wireless charging on X5 warms up the iPhone more than it needs to be. I had a few instances when the whole CarPlay was literally frozen, iDrive screen was flickering. I also notice that my music saved on iPhone (not Apple Music) cuts out randomly for a few milliseconds; it picks back up, but noticeable. I am not sure if it is my setup, but when CarPlay is being used with the vehicle Siri could not control our HomeKit devices. I'll test this more. Dealer couldn't find any issues. All in all, Apple CarPlay works most of the time, but not as smooth as I was hoping it would be. There is room for improvement. At least I don't need to connect cable every time.
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
SKBSY885.00 |
05-07-2021, 08:48 AM | #32 |
Rep 2
I was getting an orange LED light on the charging tray due to overheating, and the charging lightning bolt stopped on the display widget - the tray seemed to turn off charging after detecting overheat.
05-08-2021, 09:45 AM | #33 |
Rep 668
If you have an early G05, get the tray replaced. I have one of the first G05s built and I had issues with that tray not working and overheating. They replaced the tray under warranty and it worked better.
05-09-2021, 06:24 PM | #35 | |
85
Rep 318
Drives: MY19 X5 40i
How early is considered early tho ? Mine was built May 2019………….
Brandan
IftiBashir110.00 |
05-10-2021, 07:32 AM | #36 |
Rep 668
Mine was around October 2018, so.. early I think I just told them that it charged slowly and made my phone hot, so they replaced it really without question.
05-10-2021, 09:45 AM | #37 |
Rep 83
Yep. iPhone 12 Pro + CarPlay overheats in the charging tray. BMW always behind the mobile phone technology curve. Using USB-C.
2021 X3 M40i, 2021 X5 xDrive 4.0i
------------------------------------------------------------- 2016 X5 3.5i, 2017 X4 M40i, 2006 330i E90, 2004 X5 3.0i, 2000 528i MT, 1986 535is MT , 1985 528e MT, 1985 325e MT |
05-10-2021, 09:53 PM | #38 |
Happy M Driver
241
Rep 390
iPhone 12 Pro, with a Tech 21 clear case. July 2020 X5.
I have not had any heating problems when using the charging tray. When I pick up the iPhone when I'm leaving the car it does feel warm; however, never hot. Sounds like BMW is willing to swap out the charging tray. I'll probably request that to be done if I start experiencing problems.
2020 X5 40i M Sport - The "Unicorn" (B&W Sound, Touch Screen, Heated/Cooled Cup Holders, Soft Close Doors, Acoustic Glass, Full Alcantara & Glass Controls, Luggage Compartment Package, Heated/Ventilated Seats, Laser Lights, Fog Lights)
2016 M4 Coupe; 2008 Dinan S1 M5; 2006 530i; 1998 328i |
05-11-2021, 12:13 PM | #39 |
Rep 744
After two 5 hour trips from St. Louis to Chicago (and back) in my 2021 X5 M50i (November/December 2020 build) my iPhone 11 ProMax was just warm but not hot. I did not have any heat related shutdowns or warnings. I also use a wireless charging mat to charge my phone over night without difficulty.
Just another data point. |
05-11-2021, 12:57 PM | #40 |
Rep 6,828
Some of the heat problems will depend on what you are running on the phone. If you're using it as the navigation source and maybe music source, having the gps on and the fairly high processing power of the constantly moving map data will be drawing much more processing power, and stress the charging circuits keeping the phone warmer or maybe hot versus just sitting there charging and not running any applications on it. Any case will act somewhat like an insulator, making it harder for the phone to cool itself off.
08-14-2021, 11:55 AM | #41 |
Rep 8
In the last 2 months, my iPhone 12 turned off twice due to overheating, both times very inconveniently - while in traffic in new locations.
Noticed: both times it was on the charging pad and running Google Maps for about 1hr since I left with the temperature inside the car being ~80F or a little less. While I understand the point about heating due to intensive calculations while charging, well... this is a feature provided by the manufacturer.... |
08-14-2021, 12:46 PM | #42 | |
Rep 8,719
2) use the integrated nav system, not a third-party app (can't blame them) |
08-14-2021, 01:59 PM | #44 |
85
Rep 318
Drives: MY19 X5 40i
Yeah wireless charging tray and google map (or any gps apps) don't work well together. Now a day, if I know I need to use the google map, I will use the usb c to charge my phone. Other time, I will just use the charging tray of as phone storage and charging.
Bought something like this from Amazon planning to ditch the charging tray forever !!
Brandan
