      07-29-2022, 09:33 AM   #89
Mr.Pringle
Mr.Pringle's Avatar
196
Drives: 2020 BMW X5 50d
2020 BMW X5  [0.00]
Thank you so much for this post! So much help! Just did mine!
One inch drop all round
      07-31-2022, 08:49 AM   #90
Afjeld
Drives: G81 M3 CT & G26 i4 M50
Originally Posted by lkruses View Post
Hi
Bought my links from baanVelgen and they suggested 6mm longer in front and 6mm shorter in rear, I did 7mm front and rear, the car ended ca 25mm lower.
Received chassi error, had to adjust the rear links 1 turn longer on the treads. So I think the rear is about 5mm, the car ended up perfect low and nice.
Looks great :-)
Feel free to join the G05 Group in Norway: https://www.facebook.com/groups/180704529828245
      09-02-2022, 08:34 AM   #91
lkruses
Drives: Bmw F10 M5,Bmw G05 2023
New front lip mounted, with lower links installed
      09-02-2022, 09:12 AM   #92
Afjeld
Looks great 🤩 And welcome to the Norwegian FB Group 😊
nZtiZia4656.00
      09-03-2022, 05:36 PM   #93
rennsportny
25
Drives: '23 x5 45e | '15 Audi Q5 TDI
Nice!! Which lip is that??
      09-29-2022, 09:50 AM   #94
mikekay
mikekay's Avatar
104
Drives: 2019 X5 M Sport
Any Canadian sources on where to get these parts? Do the links help with handing and body roll?
      09-29-2022, 10:56 AM   #95
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
to inquiry #2, I doubt they do. that's more the job of the air suspension
      10-06-2022, 06:30 AM   #96
lkruses
Hi
Maxton Designs😊
      02-09-2023, 01:12 AM   #97
kerim
Drives: BMW
Originally Posted by r33_RGSport View Post
Yes, you can. But don't go lower than my recommendation, because if you switch to sport, it will lower more and you'll rub.
Will it rub if its driven on the new loading height (if made sports height as new loading height)
      02-09-2023, 05:17 AM   #98
nZtiZia
nZtiZia's Avatar
you can't drive at loading height because the vehicle rises as soon as the driver or passenger door closes.
r33_RGSport12971.00
      02-09-2023, 11:54 PM   #99
kerim
Drives: BMW
I know. Im saying to make sports height the current “new” loading height. And loading will be lower
      02-10-2023, 04:56 AM   #100
nZtiZia
nZtiZia's Avatar
you mean to lower it so the current Loading height becomes the new Sport height? if you make the current Sport height the “new” Loading height, you’re raising it
still, I believe if you lower that much, you’ll get errors. check posts from Afjeld
      04-11-2023, 08:25 AM   #101
Smoothie
Drives: 2019 x5
I finally had time this past weekend to attempt this install with RGSport links.
A few questions...
I couldn't even get the sensor disconnected, they were pretty well stuck on with dirt etc. I can try to pry off the tabs a little, but there's not a lot of room to work with.
Is there a way to install the links and not disconnect these sensors? Looks like the error code goes away? I can also get bimmercode if that can clear it.
Second, I can easily get access to the front links, but the rears, not sure how you guys get access without removing the wheels. I can raise the car, then are you crawling on the ground to reach the links?
Lastly, are there any concerns of the nuts coming loose? I guess the links won't adjust in size. Also, do you put the links on the balls, then attach the retaining clip?
Thanks in advance!
      05-18-2023, 06:25 PM   #102
m-prsev
Drives: 2021 X5MC, 2021 X7M50i
Originally Posted by ausfahrt View Post
I bought the RGSport lowering links. The install was pretty easy. Before the install I went ahead and bought 4 new OEM BMW links incase I broke it. So the fronts are the same but they changed the back OEM control rods. The bottom part is not plastic anymore. It’s a metal square that slides into the original location and screws in. The other end has a screw type like the BBM links. It’s easier to remove now rathe than pushing the piece in with a socket to remove and you don’t have to worry about breaking the other end, you just use a 10mm socket to remove it. Also unlike the front piece’s that you pop off with the heat gun, it looks like it’s metal rather than plastic.
Would anyone have the part numbers for these replacement pieces?
      07-12-2023, 02:17 AM   #103
An2610
An2610's Avatar
30
Drives: Bmw g05 Bmw e66
So if lowering links are installed and you drop the car by lets say 1" down on the sport suspension setting that would mean mid position will roughly equal to previous stock factory and the highest suspension setting will be 1" lower due to installed links?
      07-20-2023, 06:33 AM   #104
dr-theo
Drives: Bmw x5g05 45e
Originally Posted by Gtz1wickedest View Post
Another note to add if you go super low it rides like a Honda on cut springs and you get a chasis malifuntion message when entering loading mode just putting it out there for future installers. Went with recommended adjustments and rides perfect.
First pic was super low and getting errors.
Second pic looks level and rides perfect.
Hi I have questions:in the second picture the car is in loading mode or note?Thx
      07-20-2023, 06:37 AM   #105
dr-theo
Hi
Hi, the car in those pictures it is in loading mode or electric individual?Thx
      11-21-2023, 01:06 PM   #106
cooper_rau
Drives: bmw x5
is using lowering links possible on a 2016 x5 35i s drive
is this possible on a 2016 x5 35i s drive. I have not heard of anyone doing it on the front suspension but I notice when looking under my car the front does have lowering links. if any one has any advice please let me know thanks.
      11-22-2023, 08:23 AM   #107
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
2016 F15 X5 doesn’t have front air.
The link on non air suspension is only for hedalight auto leveling.
While on air suspension is for ride height and headlight auto leveling.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      12-23-2023, 09:50 PM   #108
aug0211
aug0211's Avatar
Drives: 2024 X5 M60i
Does anyone have the install instructions from r33_RGSport’s lowering links? I somehow either did not get instructions with mine, or they were misplaced. Oops! Bought directly from Ben, but all I have now is links in bubble wrap 😅
r33_RGSport12971.00
      12-26-2023, 04:47 PM   #109
r33_RGSport
Installation instruction is in a form of QR code.
So hard to provide installation instruction these days, lol.
I have includes them fully printed out, guys still losing it.
I includes them in QR codes since they want digital version, still lost it.
I even includes a download link on the web order page, no one read it. lol.
Email me your order# and I'll email you a copy.
I don't share this publicly since some eastern company been stealing my installation instructions for their own benefit.
aug0211167.50
      12-26-2023, 04:51 PM   #110
aug0211
aug0211's Avatar
I was able to figure out without the instructions 👍 These links were definitely from you though! I probably just missed the QR code.
No issues during install. I did not remove any wheels. I did find that jacking up was 60 seconds of time well spent for each wheel.
Front tires just off the ground. Back tires ~4” off the ground was enough for me to slide under with ease.
First one (driver front) maybe an hour for me in total being slow, cautious, and not having exact instructions. That locking pin was toughest for me. Finally took the stuff off and made it way faster.
From there on, each was about 10 minutes. I found it way faster to remove the bolts and take the links out.
r33_RGSport12971.00
