03-24-2024, 03:45 PM | #1 |
Rep 29
will 275-55-19 be ok?
if they are mounted on their own rims for 2019 xdrive40i? I believe the OEM size is 265-50-19
these are the #s I see but have no idea if they are acceptable :/ Size 1 265 /50R19 Size 2 275/50R19 Compare Size 1Size 2 Diameter 29.4" 29.8" +1.4% Width 10.4" 10.8" +3.8% Sidewall 5.2" 5.4" +3.8% Circum. 92.4" 93.7" +1.4% Revs/Mile 686 677 -9 |
03-24-2024, 03:53 PM | #2 |
Rep 8,700
Drives: eVeRyOnE mAD!
i foresee a number of issues from inaccurate speedometer and odometer to wheel well and steering components clearance
assuming you’re mounting them on all four corners, I don’t think it’ll hurt the transfer case, but say you have an issue down the road, it may not be covered under warranty due to them being non-OEM size FWIW, that’s a significant increase in size, but you’re listing two different sizes. which size are you considering? 275/50R19 or 275/55R19 (below calculations are based off the latter as that’s the title of your thread) |
03-25-2024, 10:57 AM | #3 | |
Rep 29
03-25-2024, 11:11 AM | #4 |
Rep 8,700
if you’ll be trekking in snow, narrower tires provide more traction than wider tires, but 275 is the standard width for 20” anyway. when comparing, it would appear 275/50R19 shouldn’t pose clearance issues, but your speedometer/odometer will still be slightly inaccurate
