      10-04-2023, 11:54 AM   #67
VirtualGuitars
VirtualGuitars's Avatar
Drives: 2024 BMW XM Label
Interesting that I posted this within an hour of the article being published on the iX forum, but it got very little replies. Glad to see this getting some attention by actual BMW owners.
      10-04-2023, 12:03 PM   #68
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Originally Posted by OM3RTA View Post
Exactly! There is so much choice with Android 😉🤭
Hey man don’t be gross
      10-04-2023, 12:10 PM   #69
Ibiza
Ibiza's Avatar
Drives: 22 G83 comp & 2024 X5 M60
Apple just released 17.0.3 to fix the overheating issue. 🤞
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD
Appreciate 3
nype138.00
///M TOWN16566.50
M2siast5876.00
      10-04-2023, 12:11 PM   #70
StevenDS85
I ///M Fan
Belgium
336
Drives: BMW 330i M-Sport
Can a poll be added to this post. I have an iPhone 15 and charged the phone couple of times in my g20 2019. No issue so far. I’m reading here that people who got it all had an iPhone15 Pro Max …
      10-04-2023, 12:41 PM   #71
StevenDS85
I ///M Fan
Belgium
336
Please mention your iPhone type and your BMW model/year. Wonder if anybody has the issue in a g20 2019.
      10-04-2023, 01:21 PM   #72
scottc
scottc's Avatar
699
Drives: Mercedes E350 Cpe
Here are my details, my phone was a week old when it died.
iPhone 15 Pro Max
2023 G82 M4
C63 Coupe
///M TOWN16566.50
volodp198.00
      10-04-2023, 01:53 PM   #73
nype
nype's Avatar
138
Drives: BMW M240i / BMW X5 35d
My iPhone 14 Pro seems to bake less when I use a case that is truly Magsafe compatible. Have others found the same? How about without a case?
This might be a non-factor here, just curious...
      10-04-2023, 01:56 PM   #74
nype
nype's Avatar
138
Installing now...thanks for the heads up!
Ibiza3611.50
      10-04-2023, 01:57 PM   #75
NoMods
NoMods's Avatar
1108
Drives: 2022 M5
2022 M5  [10.00]
Sadly I don’t use the wireless charging because it doesn’t fit in my M5 even with a thin case.
nerdogray1301.50
      10-04-2023, 02:31 PM   #76
trad
Member
trad's Avatar
Drives: 1M AW, M4 MG, X3M40i DG
2018 X3M40i  [0.00]
2015 BMW M4  [0.00]
2011 1M coupe  [0.00]
Anybody fried their phone on a G82 2022?
      10-04-2023, 03:17 PM   #77
10"
10"'s Avatar
4975
Drives: orange BMW 1M.
Luckily my car has 0 of these capabilities! 🤣☠️
don't read this. too late...
Appreciate 4
///M TOWN16566.50
1230vani652.50
NoMods1108.00
      10-04-2023, 03:24 PM   #78
Chris_DUS
Drives: 2012 E92 M3
Can we just disable the wireless charging function in the car? Pulling a fuse or cable? I would like this very much and just use that spot to park my phone.
Used the wireless charging tray once but didnt kill my phone
      10-04-2023, 03:37 PM   #79
Joralemon st.
Joralemon st.'s Avatar
Drives: 2021 X3 xDrive30i M Sport
Get a piece of sheet metal and put it on top of the charger — should prevent it from charging your phone
      10-04-2023, 03:53 PM   #80
LogicalApex
Drives: 2020 BMW 530xe
2020 BMW 530xe  [0.00]
Originally Posted by scottc View Post
Apple replaced mine under the Apple care program, if I didn’t have that i believe they still would have replaced it as their diagnostic tool said that the hardware module had failed. However it won’t take long for Apple to put the connection with bmw chargers together, and at that point it will depend on who is blaming who for the issue. If you have Apple care it won’t matter as they are very good at covering accidental damage etc, just having the warranty might be another story
I was using the charger and apple car play
Apple would cover it under the standard warranty.
I doubt they’d be able to point fingers at BMW on this one. My car has had its wireless charger for 4 years and I’ve used it with my iPhone for that whole time.
If my 15 Pro has an issue that my 4 previous iPhones didn’t. Then Apple needs to sort it out.
I wonder if today’s overheating patch in iOS 17.0.3 for the iPhone 15 is that fix.
This update provides important bug fixes, security updates, and addresses an issue that may cause iPhone to run warmer than expected.
https://support.apple.com/en-us/HT213781
scottc699.00
      10-04-2023, 03:58 PM   #81
scottc
scottc's Avatar
699
I have just installed it but reluctant to try it simply because I don’t want to brick my phone again.
C63 Coupe
///M TOWN16566.50
      10-04-2023, 05:26 PM   #82
///M TOWN
///M TOWN's Avatar
Drives: M GmbH
2018 M2  [8.82]
Smart man
Wait for the blind sheep to continue
      10-04-2023, 06:37 PM   #83
Tejas1836
Tejas1836's Avatar
996
Drives: 2023 X5MC Workmaster 75
Facebook and instagram apps are notorious for running in the background with high battery usage
Two is One and One is None
      10-04-2023, 06:54 PM   #84
///M TOWN
///M TOWN's Avatar
Drives: M GmbH
2018 M2  [8.82]
Absolutely, same with Siri
I turn Siri off on my iPad for improved daily battery usability
      10-04-2023, 09:01 PM   #85
KiloCo
Drives: Toyota// 22 G82 M4 Comp
MY 2022 G82 was purchased at the end of covid and due to a "chips" shortage/ and shipping delays in 2022, my M4 came without "wireless charging."
      10-04-2023, 09:05 PM   #86
PresM850i
Drives: BMW M850i
One suggestion: I noticed how hot my Pixel 7 Pro and Pixel Fold got when charging in the M850i. I now keep the door open to vent heat. Its not perfect, but it seems much cooler. Loose the look of the Carbon fiber, but better than bricking the phone!
      10-04-2023, 11:10 PM   #87
a0krn
32
Drives: BMW X1 2023 x28i
Can we also add if people are using a case or not?
I’m on iPhone 14 pro with a wireless charge compatible case.
No problems for me. But I will not use it until someone from either bmw or Apple confirms something.
nype138.00
      10-04-2023, 11:26 PM   #88
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
New release of iPhone software said it was to correct phone overheating.
BMWCCA member Puget Sound Chapter
