08-11-2021, 12:53 AM | #67 | |
Generalissimo
651
Rep 1,402
08-11-2021, 04:48 AM | #68 |
Rep 8,720
Drives: eVeRyOnE mAD!
08-11-2021, 10:56 AM | #69 |
Generalissimo
651
Rep 1,402
Has anyone been able to code a Rolls Royce chime in their G05? I know it’s not offered as part of basic mode in BimmerCode but I found the following expert mode coding from an X3 G01 forum. Will it work on G05?
For the chimes: HEADUNIT -----3002 AUDIO_TUNER_TRAFFIC ----------SOUND_SIGNAL_SET ---------------ROLLS_ROYCE For the ringtone: HEADUNIT -----3003 TELEFON_TELEMATIK_ONLINE ----------RINGTONE ---------------RR |
08-11-2021, 12:41 PM | #70 |
Rep 8,720
i was hoping the warning chime was added for G05 with this latest update, but alas, no...
try it and let us know! |
08-11-2021, 12:52 PM | #71 | |
Generalissimo
651
Rep 1,402
Warning chime The warning chime that sounds when a warning is displayed in the car. Values: BMW i warning chime BMW warning chime Mini warning chime Rolls Royce warning chime |
08-11-2021, 01:53 PM | #72 |
Rep 8,720
yeah, it's not codable via the modules...yet ;P but i was saying for you to go ahead and expert code it and see if it works. personally, i prefer the 'i' chime
08-11-2021, 03:00 PM | #73 | |
Generalissimo
651
Rep 1,402
Follow the following thread in the coding sub-forum where I will try to get to the bottom of how to code warning chime sounds: https://g05.bimmerpost.com/forums/sh....php?t=1849364 |
08-14-2021, 01:18 PM | #75 | |
Generalissimo
651
Rep 1,402
“It does not work for cars with MGU headunit and RAM.” By “does not work” they elaborated that they tried to code the warning chime which indeed changed some sounds but some, like the PDC ones, stopped working altogether. So, anyone knows how G01 (which BummerCode seems to support warning chime coding for) is different from G05 in relation to having MGU headunit and RAM? |
08-14-2021, 01:39 PM | #76 | |
Generalissimo
651
Rep 1,402
nZtiZia4674.00 |
08-14-2021, 04:07 PM | #77 |
Rep 8,720
you mean I have to downgrade to be able to code the warning chime?! hehehe first world problems are funny, eh?
08-14-2021, 06:33 PM | #78 |
Generalissimo
651
Rep 1,402
08-15-2021, 08:42 AM | #79 |
Rep 103
Does anyone know how to disable Easy Access for Steering wheel (steering wheel self-adjusting when starting the engine)? I disabled it on F15 but it seems to be a different code for G05.
08-16-2021, 12:13 PM | #80 | |
Rep 274
08-16-2021, 12:26 PM | #81 |
Rep 8,720
Car > Settings > General Settings > Sound
08-18-2021, 07:19 PM | #82 |
Rep 181
Question of coding, I had anti-dazzle coded by RG Sport and when it was completed, it had reset all previous coding I had done using my Bimmercode. MY question is, if is code again with my Bimmercode will it clear out the anti-dazzle??
08-19-2021, 01:48 PM | #83 |
Rep 274
09-26-2021, 06:09 PM | #84 |
Rep 794
Video in motion
Does anyone know what might have gone wrong? I think I followed the steps correctly but it didn’t work. I thought it didn’t get coded in so I was going to try again. But it shows “Active”. Any idea? I’m using wireless CX adapter. No error was noticed during the process. I haven’t coded anything else. Thanks.
09-26-2021, 07:36 PM | #85 |
Rep 6,832
Coding via Bimmercode does not reset other things...it essentially takes a snapshot of what's there, applies any changes you make, and writes that back to the module.
There are some functions that the program cannot toggle back and forth, so you need to retain the backup (and maybe rename it so you remember which one) so you can use the restore function if you want it back to default. THere is (or was) a difference in backup operation between iOS and ANdroid...Android only keeps the last backup...iOS, I've been told (but not looked for them) all backups. WIthout a key as to which one is which, not all that helpful, so maybe keep a log on what date you made the change. There are hardware differences between the Euro and US laser headlight assemblies (and different ones yet for LHD and RHD and other markets elsewhere). The US FDA got involved with the lasers on vehicles and required a safety switch to disable the laser beam if the housing was damaged. Since the laser beams are not visible (but point backwards), if the housing was damaged, it is theoretically possible, but probably really hard to actually occur, that they could point out, and being invisible, could blind someone. The US laser headlight assembly has a yellow sidelight in it, and to limit the maximum lumens, they lowered the voltage, along with the DOT label. The voltage level bit MIGHT be programmable, but I've not heard of people achieving that change, so probably not. |
09-27-2021, 06:00 AM | #86 | |
Rep 2,609
Do this: hold control knob up and while holding press Media, then Home, then Media. Speedlock Mode menu should come up: select Deactivate Speedlock and go back.
10101X5465.00 |
09-27-2021, 10:05 AM | #88 | |
Rep 7,502
Most of my daily driving is in an urban setting I'm driving on side streets as I navigate to get to main streets and secondary corridors...and there are stops signs, yield signs, and round-abouts. If I have ASS activated, the engine shuts off when I come up to a stop or yield sign or round-about...when the engine cuts off...then has to immediately restart...that is annoying as h3ll...and sometime the shut off/start up in those situation causes me to miss a chance to jump into the round-about or pull out into the intersection. I also hate it when I pull up to my mailbox and the car cuts off...and if I'm pulling into the garage. So yes...I gladly disabled it!
