      05-09-2020, 12:31 PM   #331
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Originally Posted by FCobra94 View Post
Well, it's because you're recommending that people blindly "upgrade" to higher MP cams and skip the 4MP versions, but can't reference anything relevant to provide an actual comparison.
As mentioned, most value-oriented 6MP cams are built using the same exact hardware, chipsets, sensors, lenses, etc. as 4MP cams...only difference is that they pump more resolution through 'em via firmware hacks. It's the equivalent of stating that a 335 w/ no muffler and an M badge is vastly to superior to those that are stock...laughable, at best.
I'm hoping this eases your worries...
zx10guy5149.50
      05-09-2020, 02:42 PM   #332
FCobra94
Guest
n/a
Drives:
So you replaced a poorly configured/defective camera with one that actually works as intended?
Congrats!
      05-09-2020, 02:44 PM   #333
P1
P1's Avatar
11572
Congrats!
Not sure what you’re so frustrated about, chief. Maybe go for a walk around the block and get some fresh air.
      05-09-2020, 02:58 PM   #334
FCobra94
Guest
n/a
Drives:
Originally Posted by P1et View Post
Not sure what you're so frustrated about, chief. Maybe go for a walk around the block and get some fresh air.
https://www.bimmerpost.com/forums/sh...php?p=26154748
      05-09-2020, 03:14 PM   #335
P1
P1's Avatar
11572
Not sure that’s worth getting all heated about, is it now? Going forward, I’ll clearly state that these are my personal observations, having had a variety of different security cameras at my house. Would that help?
      05-09-2020, 03:17 PM   #336
Torgus
Slow.
Torgus's Avatar
Drives: Single Turbo N54 on Meth!
2007 BMW E92  [10.00]
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
What do you guys think of this: https://www.lorextechnology.com/hd-s...WF2080B-62-1-p
I need it for a cabin. I don't want to spend money on a subscription. I don't want to hard wire anything, I'll just change the batteries 2x a year.
Only thing is I don't think it will send alerts to the app on my phone, I could be wrong.
This is much more of a want than a need. If it was a need I would just buy a home security system like I have at home.
      05-09-2020, 03:58 PM   #337
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
Well unless something has changed. Blink cameras don't require a subscription, are wireless, batteries claim to last 2 years, mine are already going on 1 year and will alert your phone if they sense motion.
Torgus3781.50
      06-10-2020, 07:49 AM   #338
Torgus
Slow.
Torgus's Avatar
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
I forgot all about Blink.
Just picked up 2 for the lake house a few weeks ago. Work great. Thank you again for your recommendation/reminder.
      06-10-2020, 04:45 PM   #339
JasonCSU
Drives: '08 135i, '88 325is
1988 BMW 325is  [0.00]
2008 BMW 135i  [0.00]
Originally Posted by Kolyan2k View Post
Anyone uses these, Ring Floodlight camera or Eufy one? I was going to give Eufy a try, 1 flood at garage, 1 at backyard, and the doorbell camera. After reading a bit, seems like Eufy offers internal storage with no subscription, better app, and support.
With floodlight combo install is super easy and no need to buy floodlights for house separately
Did you give the Eufy cameras a try? I like the thought of this system using its own storage rather than a cloud subscription service. It looks like Eufy also allows RTSP to record the video to NAS systems as well, which would be useful.
Delivered in Munich, broken in on the Nurburgring.
      06-10-2020, 05:20 PM   #340
BMWGUYinCO
BMWGUYinCO's Avatar
4123
Drives: 22 M850 Convertible '23 X3 M40
I'll chime in on the Ring system since we have 6 devices installed, including the Ring doorbell, Floodlight Cam, and wireless indoor Stick Up cams.
The Ring interface is nice, as is the tie-in with the neighborhood watch program. But I have one gripe, and I would caution you to research it: when you get an alert for motion, or the doorbell rings, it takes a long time to "activate" the camera into a live view. So by the time you get the live stream going, the person or thing that set off the event is long gone from view. This is a unique issue - and does not apply to capturing motion recordings. I'll explain.
The system does an excellent job of capturing motion and sending HD recordings of that event to the cloud, where you can later retrieve that recording for viewing, so it's not like the camera takes too long to begin recording - it's only when you want to instantly go live to a particular camera that is delayed and frustrating.
For other reasons, I recently upgraded my home WiFi to the Orbi mesh network (using 3 satellites), but I had the Ring system in place using my old Linksys unit. Same issue in both scenarios. My signal strength on all cameras, indoor and out as measured by the Ring app is very good...it seems to be a common and persistent issue among many Ring users regardless of signal strength. I've tried viewing over my WiFi as well as cellular networks, and also downloaded and tried the "Ring Lite" app.
The app receives frequent updates and tech support is generally really good too. YMMV....
      06-11-2020, 11:17 AM   #341
Kolyan2k
Drives: 2006 S2000
I bought Eufy but I haven't installed yet. Will start house renovation on 16th and will have them installed by 25th
      07-02-2020, 09:52 PM   #342
hl0m4n
hl0m4n's Avatar
Drives: BMW
Arrow
cut the cord, now looking at out door security systems. all these systems have their pros/cons but where they all get you is in their subscription costs.
some are are inclusive meaning no limits on cameras connected while others charge per camera which can add up quickly depending how many your using.
sharing info on the 4 solutions i narrowed it down to below.
i am leaning towards the unifi setup... direct ethernet cable supplies data and power providing a direct secure connection to local storage. $0 subscription costs, everything is local and secure.
Setup Criteria: x2 Outdoor Highest Spec Available Cameras
Nest
Nest Cam IQ Outdoor $1,000 ($500/each)
Connection: WiFi
Storage: Cloud
Audio: Speaker + Microphone
Camera: 8 MP
Video: 1080P
FOV: 130 Degrees
Night Vision: 850nm Infared LED
Subscription: $80/year (30 Day History)
First Year Startup Costs: $1,080
5 Year Costs: $1,400
Benefits:
Google ease
IP rating
Negatives:
Subscription costs high
1080P
Wired
Google owned…data privacy and security
Ring
Spotlight Cam Solar $460 ($230/each)
Connection: WiFi
Storage: Cloud
Camera: Specs Unknown
Video: 1080P
FOV: 130 Degrees
Night Vision: Yes (Specs unknown)
Power: Solar
Subscription: $0/year ($30/year for 30 Day History)
First Year Startup Costs: $460 ($490 w/ subscription)
5 Year Costs: $460 ($610 w/ subscription)
Benefits:
Least expensive start up costs
Solar – no cables or recharging batteries
Least expensive subscription costs
Negatives:
No IP rating
Amazon owned…data privacy and security
1080P
Arlo
Ultra $600 ($300/each)
Solar Panels $160 ($80/each)
Connection: WiFi
Storage: Local/Cloud
Camera: 8 MP
Video: 4K
FOV: 130 Degrees
Subscription: $0/year ($120/year for 30 Day History)
First Year Startup Costs: $760 ($880 w/ subscription)
5 Year Costs: $760 ($1,360 w/ subscription)
Benefits:
Local storage microSD no subscription needed
Medium start up costs
Solar – no cables or recharging batteries (extra – standard is chargeable battery with wired setup as option)
Expensive subscription costs
4K
Negatives:
No IP rating
MicroSD not included
Netgear owned…data privacy and security
Unifi
G4 Pro $900 ($450/each)
Cloud Key Gen2 (Includes 1TB HDD ~65 days recording) $200
Switch 8 60W $110
Solar Panels N/A
Connection: Wired/WiFi
Audio: Mic (No Speaker)
Video: 4K
FOV: 130 Degrees
First Year Startup Costs: $1,210
5 Year Costs: $1,210
Benefits:
IP Rated
100% local storage - private
Power over ethernet – everything direct secure connections
4K
Negatives:
No speaker
High startup costs
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      07-02-2020, 10:30 PM   #343
Smgs1992
Drives: 2007 bmw 335i
What are you looking for out of it? Just in general security? Deterrent? Ability to see whos at your door when someone is knocking? Ect...
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
      07-02-2020, 11:08 PM   #344
BMW F22
BMW F22's Avatar
Drives: ///M235i
There’s a whole thread on this. Let me save you some time and research though. It boils down to:
1. Wired cameras are terrible with motion detection because it’s pixel detection, not motion. The most recommended one is Reolink.
2. Wireless cameras are not as great because it only records when there’s motion. If on battery you’ll change it every now and then. Eufy cams are really good and cost effective. Their batteries last a year on a single a charge.
3. Best way, IMO, is a combination of the two. Get a 5-6 cams wired Reolink set and combine it with Ring floodlights (if you already have Ring subscription it’s a good way to go, especially with refurbished units) or Eufy cams. If you really want to can even get a doorbell cam. Then you’ll have best of both worlds: 24/7 recording and motion and light motion detection. This is what I ended up with.
I went with a 2K resolution Reolink set with 5 cameras that record 24/7. I can check on it anytime I want. Then I have Ring floodlight for driveway and spotlights for the back along with non camera floodlights (already had them). Already have Ring alarm service so monitoring fee for those cameras are included. Also, lifetime warranty on cameras for as long as I have the service. All for $100 a year.
      07-03-2020, 11:51 AM   #345
P1
P1's Avatar
11572
I think your first point is overly generalized, plus it wouldn't depend on whether your camera is wired or wireless. I don't rely on the camera itself, but rather the 3rd party software that analyzes the video feed to make out not only movement, but whether that movement is a leaf (not relevant) vs. a human being (relevant), a car (relevant), etc. All my cameras are hardwired for both power and data and my object detection is excellent.
Also note not that wireless/wired can mean different things. For me, wired means power and data via category cable or AC power. Wireless means power via category cable or AC, but data via WiFi. When you say wireless, you mean power via battery and data via WiFi.
Appreciate 3
zx10guy5149.50
spencers199.00
      07-03-2020, 01:18 PM   #346
EvaaWilli
Drives: BMW M3 e39
Took a good home. I have been using it for a long time.
      07-03-2020, 01:21 PM   #347
FCobra94
Guest
n/a
Drives:
This makes absolutely no sense whatsoever...
Appreciate 3
P111572.00
spencers199.00
      07-03-2020, 05:04 PM   #348
BMW F22
BMW F22's Avatar
Drives: ///M235i
Way too many false alerts with wired. They sense any changes to pixels so even shades would cause alerts.
      07-03-2020, 08:14 PM   #349
FCobra94
Guest
n/a
Drives:
You have absolutely no idea what you are talking about.
This is the equivalent of saying "don't buy a BMW...every time I drive mine, there's a gauge on the dashboard that gets closer and closer to the letter E"
P111572.00
spencers199.00
      07-03-2020, 08:27 PM   #350
P1
P1's Avatar
11572
This 100% absolutely false. You are saying that the world’s most sophisticated video monitoring solutions, which are all hard wired, all incorrectly detect motion and do nothing but cause false alerts? Someone call the Pentagon and sell them a Nest or Arlo solution!
Again: wired or wireless has absolutely nothing to do with false alerts.
spencers199.00
      07-04-2020, 12:38 AM   #351
AlpineWhite_SJ
Drives: 2018 F80 M3 ZCP, 2020 F97 X3MC
Originally Posted by hl0m4n View Post
Arlo
Connection: WiFi
Camera: 8 MP
Video: 4K
FOV: 130 Degrees
Benefits:
4K
Negatives:
No IP rating
Arlo Ultra is IP65-certified just like prior models, but the Pro2s are cheaper and plenty good. 5 Cameras with rolling 7 day recordings are free and base can do USB storage. I haven't paid a dollar for a subscription in the several years of owning them. Ultra's had a bunch of bugs when they launched, just FYI.
      07-04-2020, 08:00 AM   #352
BMW F22
BMW F22's Avatar
Drives: ///M235i
This 100% absolutely false. You are saying that the world's most sophisticated video monitoring solutions, which are all hard wired, all incorrectly detect motion and do nothing but cause false alerts? Someone call the Pentagon and sell them a Nest or Arlo solution!
All the reviews I watched said that. I'm not an expert so only went by what the testers said. Based on what I see, a spider web string dangling in front of the camera would cause the motion detection to turn on (a string is not human).
