04-23-2021, 12:10 PM | #1 |
Rep 542
Struggling to Keep X5 in Straight Line - Steering Advice Needed
Looking for advice from automotive experts on this thread. I recently purchased an X5 40i with M Sport package. I currently have a little over 1100 miles on the vehicle. An to provide some context, I have been driving for over 35 years, across vehicles of all types.
I am having trouble keeping the X5 in a straight line. It feels like no matter how stable I keep the steering wheel, there is a 1 - 2 degree gap in either direction where the wheels continue to shift and the vehicle is constantly floating between the outer edges of the lane. It is like driving in windy conditions where you have to course correct, except the wind is constant. I had a similar experience with a Subaru Outback after it went in for a steering recall and they messed up the alignment. When I had the lane keep assist on it would jerk the car every time it approached the outer edges of the lane. I turned off the lane keep assist thinking maybe that was overly sensitive, and the problem is still present. Also, I have had multiple vehicles with lane keep assist and none of them have ever behaved like this. It is more noticeable at higher speeds. Has anyone else experienced anything like this? Any idea what this could be? |
04-23-2021, 12:14 PM | #2 |
Rep 185
Take it into the dealer for repair and don't let up on the issue. Would also look into NJ's Lemon Laws to see what your rights are if it cannot be properly fixed/keeps happening.
04-23-2021, 12:27 PM | #3 |
13275
Rep 19,800
As mentioned, have your dealer look at it since it is not normal.
04-23-2021, 12:53 PM | #4 |
Rep 4,246
Would be helpful to have more details on suspension option - Adaptive M, air – and wheel size. But as other suggested with lane assist deactivated you shouldn't have any steering corrections.
Do you mean 1-2 degree play in the steering wheel? Or 1-2 degree off centered?
04-23-2021, 12:54 PM | #5 | |
Rep 4,335
04-23-2021, 01:12 PM | #7 |
Rep 1,292
What tires are you running? The wider tires tend to "pull" somewhat side to side if there is a kerf in the road. More noticeable with the Pirelli than Michelin summer performance. Just a thought.
akin67450.50 |
04-23-2021, 01:17 PM | #8 | |
Rep 542
vinibabs35.50 |
04-23-2021, 01:19 PM | #9 |
Rep 542
I have the Pirelli Scorpion Run Flat 20" tires. When I checked last week the fronts were 43 and the rears were 48 psi. But that could have been after I had been driving for a while so may not be cold pressure.
04-23-2021, 01:22 PM | #10 |
Rep 542
No. It feels more like when I have the steering wheel straight, as if if the wheels are not locked but have a little play in either direction. If I did not correct the vehicle will continue drifting from one side to the other. It does not appear to favor one direction.
04-23-2021, 02:16 PM | #11 | |
Rep 744
04-23-2021, 02:18 PM | #12 | |
Rep 4,246
Factory temps for comfort driving and below 100mph are: 33F / 41R and above 100mph are 36F / 44R. I'd advise adjusting pressures first and see if that eliminates some squirrelly-ness.
04-23-2021, 02:21 PM | #13 | |
Rep 4,335
akin67450.50 rmorin1249816.50 |
04-23-2021, 04:33 PM | #14 |
Rep 6,805
Once you have the air pressure correct, if that doesn't fix things, it's time to talk to the dealer. A defective tire can cause things to pull, as can suspension issues, and tire pressure settings. Some vehicles are more subject to the crown of the road than others...I've not noticed that on my X5, but I have a different model and tires.
akin67450.50 |
04-24-2021, 06:57 AM | #16 |
Rep 542
After I properly inflated the tires, the vehicle started driving much better. I'm not sure the issue is completely resolved, but it is much better. I can't believe tires over inflated by 4 - 5 psi can have such a major impact on how the vehicle drives. I have had instances where the tires were over inflated by a comparable amount in my other cars, but never did I experience anything like what happened with the X5.
I have an appointment with BMW service. I still want them to check the alignment and steering to make sure nothing else is wrong. I want to thank everyone again for all your help and suggestions. |
04-24-2021, 07:47 AM | #17 | |
Rep 4,335
Auricom4361.50 |
04-24-2021, 07:50 AM | #18 | |
Rep 4,246
Surprisingly tire pressures on X5s, with or without run-flat tires, can have significant on impact the handling and ride quality - in addition to tire tread, tire/wheel size, and tire manufacturer. For troubleshooting especially on vehicles with a lot of technology stuffed into them - suspension options, hardware, drive modes, and then assistive drive features, it's great to check off the basics you have control or adjust before heading to the dealer.
akin67450.50 |
04-25-2021, 01:54 PM | #19 |
Rep 3,341
Tramlining. Depending on road surfaces, my previous X5 and current X6 tramline with their wide RFT's. Running lower tire pressure can help. Non-RFT's shouldn't tramline as much either.
04-25-2021, 03:11 PM | #20 |
Rep 6,805
It all depends on the tire design...RFT, being stiffer can be a factor, but it's only one of many. The tread design, the rubber compound, and the air pressure all play much bigger parts to how a tire behaves. Road chamber can be an issue, too.
04-25-2021, 10:25 PM | #21 |
Rep 569
I read this yesterday and paid close attention while doing a longer mixed freeway/surface street drive today.
Something isn’t right with your car; mine stays pretty dead on. I hope the tire pressure adjustment sorts it out! |
06-25-2021, 12:21 PM | #22 | |
Rep 1
I have the same problem with my brand new G05 (40d). It's like you wrote exactly how I feel, with my own words, except that my tire pressure is ok, and I checked also the alignment of the wheels and seems to be perfect. You said you were going to visit the dealer. Did you solve anything? Thank you and any suggestion is much appreciated. I am from Romania, btw . |
