11-11-2020, 04:31 PM | #67 |
Rep 6,806
The automatic OEM one is kind of slick. I had the predecessor of the Stealth Hitch on one vehicle, and it was kind of a pain. Unless you ensure you take it off when not needing it all of the time, it can get stuck in the socket, so removing it can be a pain. It appears that the newest version may be using SS, so that MIGHT be better. You still want to use a little grease on it, but then that makes storing it a little messier, too. Given that, I opted for the NA OEM one. WIthout the motorized retract function, it's a lot less expensive, too. But, it's always there, staring you in the face (well, if you're looking at it from the back - I could care less!).
FOr those that may not live here, it is a square receiver. Most of our things like bike racks just slide in, you insert a locking pin, and it's done. To tow a trailer (caravan for those outside the US!?), you insert a bar with a ball on it, then hook up your device to the ball (aka gooseneck). Getting all of the OEM trailer functionality (lights, are easy) requires an OEM compatible box, of which, there aren't any for the G05 now except the OEM one. That functionality gives you additional camera views, trailer stability logic, trailer lamp failure detection, and automatic integration of the PDC in the rear so it's not yelling at you that there's something back there. |
11-11-2020, 05:56 PM | #68 | |
Rep 1,292
11-11-2020, 09:24 PM | #69 |
Rep 83
Drives: G05 45e, Porsche Macan GTS
I was just on the phone today with Robert at Stealth Hitches discussing their hitch for my '21 X5 45e. I have actually been talking to them for the past 6 weeks to see if they were going to get the chance to do an install on the 45e model to ensure it fits the same as the other G05 models. They have not (and I'm too far away from their location in Georgia to let them do the install on my X5), so I went ahead and ordered anyway.
They are going to assist if I run into any design or fitment issued and promised to do whatever is needed to make it work. It's in their best interest to figure it out too, so it makes sense that they are willing to help out. My Stealth Hitch should arrive on Saturday, but I'm not sure when I will have the block of time necessary to try installing.
'21 X5 45e
'18 Macan GTS '15 Ram 1500 EcoDiesel |
11-11-2020, 10:38 PM | #70 | |
Rep 19
Drives: 2021 X5 45e
11-17-2020, 11:41 PM | #71 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Step-by-step Stealth hitch installation video - 2020 BMW X5. Your DIY project, enjoy
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
Shawzy44158.00 |
11-18-2020, 06:31 PM | #72 |
Rep 6,806
I had the predecessor to the stealth hitch on my previous vehicle. It worked. I chose the factory OEM one for the X5. It's a lot less expensive, fully integrated functionality, factory warranty, and, I don't think it looks bad. I care much more about what it looks like from the inside and how it functions than some aesthetic I'll never view while using the thing. And, it's another set of keys to keep track of, and parts to get lost when not attached. If you leave it in all of the time, how's that help the looks? Once locked, you'll probably have to lay on the ground to remove it to find the keyhole, then turn the knob to release it. And, the thing is heavy and you have to cut the protection panel underneath the bumper to fit it in, exposing the interior to kicked up crud. The receiver is lower, which may be either good or bad, depending on your rack, or trailer. I'm not a fan of having the plug pointing down, either. More chance of salt, water, crud getting to the contacts when in use, and the cover isn't perfect, either.
Given the constraints, it's not a bad design. |
11-18-2020, 06:59 PM | #73 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Hi jad03060, thanks for sharing your experience. Due to different circumstances many of us cannot or won't order the factory hitch. I was unable to order it with my DHP package; it's a hard restriction from the factory. Factory option is priced well, but it is what it is. One good thing with this setup is that we get to keep the hands-free tailgate opening.
12-05-2020, 10:03 PM | #74 | |
Rep 83
The install took me about 5 hours and was not easy, but I was working alone which definitely made it a little more difficult. Removing the rear bumper by myself took a little more time than it would have if I had an assistant. But overall it wasn't too bad and I didn't run into any major issues. A broken clip on a plastic panel behind the bumper (fixed with a screw to hold the panels together) and a screw that fell down by the battery and disappeared, but no other problems. I was able to get the bumper removed without removing the passenger side tail lamp, which saved quite a bit of time in not removing the interior cargo space panel. Everything else went pretty much as described in the directions. The only thing I have left to finish is to cut the center rock panel underneath. I figured out how much space is needed to reach inside and unlatch or unlock the hitch, so I am only going to cut the bare amount of the panel necessary. I'll cut this panel tomorrow and then install it with the six screws that hold it in place. Should only take a few minutes. I love the fact that the hitch is completely invisible when the receiver is not in place and I retained my kick to open feature.
'21 X5 45e
12-06-2020, 06:56 PM | #75 |
Rep 83
I cut and installed the gravel guard today. It turned out pretty good, except I actually wish I had cut even less of the gravel guard than I did, which was substantially less than what they suggest in the installation instructions.
Here is what they show in the instructions: And here is my cut gravel guard: After cutting the section out with a dremel, I switched to a grinding wheel to remove any sharp edges. I could have cleaned it up a bit better, but you cannot really see it when it is mounted so I didn't waste time on this. From behind: If I could do it again, I would cut here (green line): The horizontal cut in this location would retain the section of plastic that is more vertical and blocks behind that section. I had no problem reaching inside to unlatch the receiver or to access the key lock for the receiver. Access is actually more blocked by the bumper and kick-to-open sensor on the front edge than by this gravel guard.
'21 X5 45e
SmartSaves462.00 Noneya251.50 |
12-08-2020, 10:52 AM | #76 | |
Rep 1,292
12-14-2020, 12:19 PM | #77 | |
Rep 2
I asked my dealer to confirm the manufacturer installed tow hitch can tow up to 7200 lbs, and the dealer insisted that it only tows 5940 lbs: "The max towing for any 2021 BMW X5 is 7,200 lbs. The X5 hybrid is rated for 5,940 lbs." After I sent him the following links that said specifically that x5 45e could tow 7200 lbs with a factory installed hitch: https://insideevs.com/news/428079/bm...s-range-price/ https://www.motorweek.org/auto_news/...xdrive45e-phev Can any body explain this with authority and provide some kind of BMW official documentation? Thanks! |
12-14-2020, 12:42 PM | #78 | |
Rep 1,292
12-14-2020, 01:14 PM | #79 | |
Rep 2
Thanks! I thought there might be a more knowledgeable BMW sales person here to explain...
12-14-2020, 04:14 PM | #80 |
Rep 6,806
From the US owner's manual for the X5 45e:
Trailer towing X5 xDrive45e Trailer load without brakes lbs/kg 1,653/750 Trailer load with brakes on uphill grades of up to 12 % lbs/kg 5,952/2,700 Maximum drawbar nose weight lbs/kg 551/250 Approved rear axle load, towing vehicle lbs/kg 3,968/1,800 Approved gross vehicle weight, towing vehicle lbs/kg 6,967/3,160 The OEM trailer hitch differs by country, so what might be true for the US style receiver may not be true for the gooseneck hitch used in many other countries. |
12-14-2020, 05:44 PM | #81 | |
Rep 83
I actually painted the heat shield black to reduce visibility. This helped, but it's really the fact that the plastic gravel guard is cut differently on one side versus the other, and not so much what is behind it.
'21 X5 45e
12-14-2020, 06:45 PM | #82 | |
19
Rep 46
Is there separate news of a retrofit hitch coming? Need for X5M. I have done the Invisihitch/stealth in the past but would be interested in something OEM. |
12-14-2020, 07:11 PM | #83 | |
Rep 1,292
12-14-2020, 07:17 PM | #84 |
Rep 6,806
He painted the area that you could see once the panels are replaced...you could paint more of it, but there's no need.
I don't know if the materials are different, but on an older BMW, I was able to cut the panel with a sharp utility knife. |
12-15-2020, 09:47 AM | #85 | |
Driver
163
Rep 447
12-15-2020, 09:12 PM | #86 | |
Rep 83
I did also spray the heat shields behind the tail pipes, since they looked terrible before. The round tailpipe only blocked about a third of the shroud area, and you could see that bright silver heat shield behind it, really highlighting the small single pipe. The black heat shield helps reduce this eyesore. For cutting the gravel guard, I used a dremel type of tool with a standard cutting blade. Cutting through the part that is already scored can be done easily with a utility knife, but cutting through the other parts take a little more effort. I'm sure you could do it with a sharp utility knife, but the dremel tool made very short work of it. And once the cut was made, I used one of the rotary sanding tips to smooth out the edges. There is now no sharp edges of the plastic to get cut on reaching up to unlatch the receiver or lock/unlock it.
'21 X5 45e
10-04-2021, 06:25 PM | #87 |
Rep 51
This is my dilemma now. I haven't removed mine for years and now it seems impossible to get out. Any tips?
10-04-2021, 06:32 PM | #88 |
Rep 8,700
Drives: eVeRyOnE mAD!
