      02-23-2023, 03:26 PM   #45
Info@mad-us.com
Info@mad-us.com's Avatar
1922
Drives: bmw
Originally Posted by An2610 View Post
Will CEL pop up with this DP?
Yes without a tune or a spacer
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
      03-09-2023, 10:58 AM   #46
yoandry
yoandry's Avatar
693
Drives: G80 M3CX & X5 M50i
Getting my AA today. Does anyone heat wrap them? 50' Titanium wrap isn't expensive at all, like $20. Will do mine.
      03-10-2023, 10:24 AM   #47
PNWM50I
PNWM50I's Avatar
469
Drives: 21' x5 M50i
Looking to also order. Local
Shop is quoting me $1200 install ( Seattle) . How about you?
      03-10-2023, 11:02 AM   #48
yoandry
yoandry's Avatar
693
I normally do all these modifications myself. I'm also waiting on the KW v3 coilovers and I'm doing it also. lol. I did the H&R springs like 2 month ago. Hell I even did the welding quad tips, been first timer welder. lol Only special tool needed for DP is the o2 sensor for like $10.
      03-10-2023, 01:26 PM   #49
Auelox
Auelox's Avatar
Drives: 2022 X5 M50i
2006 BMW Z4MR  [0.00]
2022 BMW X5 M50i  [0.00]
Did you not like the H&R springs?
      03-10-2023, 09:48 PM   #50
yoandry
yoandry's Avatar
693
They're fine and better than oem, but not happy with the drop so, only other option to lower it more was KW and it will be stiffer which I prefer in my Non DHP. Will go up for sales as soon as I take them off.
      04-09-2023, 07:45 AM   #51
97supratt
97supratt's Avatar
Drives: porsche and mercedes
I just installed a racing dynamics HFC on my g05 40. The CEL turned on same day. I have the spacer. I also have race chip black. Can I reset with race chip or is the spacer not doing anything?
      04-09-2023, 09:00 AM   #52
PNWM50I
PNWM50I's Avatar
469
Drives: 21' x5 M50i
I nearly bought racing dynamics but guy told me it would throw a CEL.
      04-10-2023, 08:07 AM   #53
AlpineG05
hi
AlpineG05's Avatar
129
Drives: Alpine White G05
You should be able to reset error message, however, it will pop up again.
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit
      04-11-2023, 01:37 PM   #54
2SwiFt29
2GR-FSE
2SwiFt29's Avatar
Drives: 2020 BMW X5 M Sport
Which catted downpipe would not throw a CEL for 40?
2014 Lexus GS350 F-Sport Ultra White w/ Cabernet Interior - Vinyl Wrapped Front and Roof
      04-11-2023, 02:01 PM   #55
gx5_027
Driver
gx5_027's Avatar
200
Drives: BMW
2SwiFt29 Typically any GESI cat.
Active Autowerke has one with great reviews. I have an SHS Autosport GESI catted downpipe that I will be installing soon and will make a before/after video, and be able to comment on no CEL. https://www.shsautosport.com/product...ipe-p541415346
Service has been absolutely stellar through chats with them so far.
You can use any b58 catted downpipe, hence it saying Supra above - but not all catted downpipes are created equal. Some will throw a CEL after some time, and are not a "high flow 49-state legal EPA approved GESI G-Sport Ultra High Output catalytic converter" like the one above.
      04-14-2023, 09:08 AM   #56
rossfl
Drives: Toyota Tundraa
Originally Posted by VasilisV View Post
I'm running a high flow catted down pipe and it sounds and performs great. No CEL and no exhaust fumes. I always think that the differences between catless and high flow catted are so minimal when all the rest are stock. I'm actually selling mine if you're interested because I'm trading in my car. Active autowerke with 4-6k miles.
Still available? If so, please DM me.
      04-14-2023, 10:24 AM   #57
yoandry
yoandry's Avatar
693
FYI, After 200 miles I got the CEL on the AA Catted DP. No bueno. Now, I'm not sure if these code are the regular one you get when installing DP as these AA DP shouldn't throw the CEL or it is actually something else rerated with the O2 sensors.
      04-20-2023, 08:43 PM   #58
NYCX5M50i
Drives: 2021 X5 M50i executive/DHP
check out the LEIB MIL delete. Just ordered mine and installing ARM catless dp in a few weeks.
      04-21-2023, 08:43 PM   #59
Ruinedx5m
Ruinedx5m's Avatar
14
Drives: 2021 X5M Comp.
Originally Posted by NYCX5M50i View Post
check out the LEIB MIL delete. Just ordered mine and installing ARM hatless dp in a few weeks.
Got a link for the LEIB MIL delete?
      04-22-2023, 08:24 PM   #60
NYCX5M50i
This is for M50i
A member on here has been running catless and this for a while with no issues.
https://www.leib-engineering.de/LEIB...odell-G-Modell
      05-05-2023, 11:35 AM   #61
racinghart03
racinghart03's Avatar
76
Drives: 21X6MC, 24M4C, 22M8CConv.
CEL randomly with Catless here. A little annoying. Easy reset with JB4. Only reason I need it off is because the remote start wont work with the light on. . I tried spacers and it only changed the code that shows up. I may work on a better system. In theory the correct amount of voltage drop from the AF sensor to the DME should trick it into thinking the before and after sensors are reading enough of a difference, making it think the cats are doing their job. Trick will be finding out what that correct deviance is. I am sure I could get readings for a catted car and compare data. A little math and a potentiometer, and some trial and error, I think I could pull it off. Is it worth it, I dunno.
