03-20-2023, 05:59 PM | #1 |
Rep 19
Apple CarPlay Issues
Hi everyone, so new car only about 3500 miles on it. CarPlay was setup and working and now it doesn’t. When I go into the settings and change it to I drive it works for just phone and music but when I change to CarPlay it doesn’t connect and gives me a warning to retry connection. I’ve tried to reset I drive and reset phone as well as re setup from beginning. Thanks in advance for any ideas as I am out of them!
03-20-2023, 06:53 PM | #2 | |
Rep 8,694
Drives: eVeRyOnE mAD!
I’ve had my 45e for 2+ years and use CarPlay daily with >99% connection rate. my routine consists of turning on bluetooth every morning after I turn off my alarm (wifi is always on). only once did I have to set up CarPlay again (it was after the 03/2021 OTA update.) |
03-20-2023, 06:59 PM | #3 | |
Rep 19
03-20-2023, 07:07 PM | #4 | |
Rep 8,694
did you check your iPhone settings such as the CarPlay section and ensure it is turned on for your BMW ID? |
JKM13.50 |
03-20-2023, 07:51 PM | #5 |
Rep 19
Yeah that setting is correct, it is makes no sense because it was working and now it doesn’t yet I’ve changed “0”
03-20-2023, 08:05 PM | #7 |
Rep 1,003
I can't recall if IOS had a recent update but I recall I did a update about a 10 days ago.
Anyhow, FWIW, I am experiencing some random issues @ times where ID won't connect to phone. I suspect it was due to the software update and it will just -sort- itself out on the next IOS update. |
JKM13.50 |
03-20-2023, 08:30 PM | #8 | |
Rep 19
El_zorro20.00 |
03-21-2023, 08:02 AM | #10 | |
Rep 8,694
I seem to recall the format of the name on the iPhone was the issue for some. this is mine (no connection issues) |
03-21-2023, 08:46 AM | #11 |
Rep 19
03-21-2023, 08:47 AM | #12 |
Rep 19
03-22-2023, 10:08 AM | #15 |
Rep 432
when you go to connected devices in your car, did you remove everything? also did you delete from phone CarPlay/bluetooth under BMWxxxx. I noticed on the last update it accepts one phone CarPlay and rest BMW iDrive
03-22-2023, 10:12 AM | #16 |
Rep 19
Yeah I got rid of everything and just started fresh and no dice.
03-22-2023, 10:40 PM | #18 |
Night Sh1ft
458
Rep 3,079
Drives: F95 X5MC LCI
This sounds ridiculous but I’ve noticed in my 2020 X3M, if the key battery is low (or near dead), I get CarPlay connect issues
They are definitely linked somehow because if the key isn’t in the car I notice CarPlay sometimes disconnects as well. Sounds insane, but have you tried replacing the battery in your key and then reconnecting? (It worked for me, after a similar sounding debacle to yours)
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
03-23-2023, 12:36 AM | #19 | |
Rep 19
03-23-2023, 08:21 AM | #20 | |
Rep 8,694
03-23-2023, 03:39 PM | #21 |
Rep 8,694
03-26-2023, 05:24 PM | #22 | |
Rep 19
