      03-27-2024, 08:30 AM   #1
starlights
Drives: G05 50i
Any issues if add-on exhaust tips touch on M50i?
Thinking of removing the surround trim on my 50i and replacing it with X5M type dual tips on each side. Is there any issue if the tips touch each other since the original exhaust tips are closer together?
I am thinking apart from noise there shouldn't be any issue because the original dual tips originate from single pipe on each side. Advice welcome.
      03-27-2024, 12:20 PM   #2
mmm50i
mmm50i's Avatar
405
Drives: '22 X5 M50i & '23 Model Y
You may hear a rattling sound if the tips touch each other. I suggest leaving a slight gap between the tips unless the tips you plan to purchase are designed to be side-by-side and are welded together.
My aftermarket tips on my M50i are about 1.5-2mm apart from each other. Prior to my current setup, I had them 0.5mm apart from each other, literally paper thin spacing, and they were rattling against each other, even at idle.
      03-27-2024, 12:52 PM   #3
starlights
Drives: G05 50i
Awesome! Thanks for responding and I suspected that may be the case. I plan to use this between the tips to cushion and hopefully not have noise else welding may be an option.
https://www.amazon.com/gp/product/B00ID8IUJY
What's the OD of those tips in your picture?
      03-27-2024, 02:35 PM   #4
mmm50i
mmm50i's Avatar
405
They are 2.75" but they are slanted, which makes them look a bit larger
      03-27-2024, 03:58 PM   #5
starlights
Drives: G05 50i
Thanks! I have 2.75 right now. Thinking of going 3.5 after removing the outer baffle. We will see how that turns out - the tips will likely be in contact but that cannot be helped
mmm50i405.00
