      07-23-2020, 05:34 PM   #67
zmm12345
Drives: x7 and 330i
Originally Posted by hkleyman View Post
Originally Posted by TurtleBoy View Post
Originally Posted by FreddyBMW View Post
Yeah....or unless I see that 03/2020.xx has already been rolled out OTA in the US at least.
My car will be out tomorrow done with the 07/2020.xx update. I am a fan of CarPlay and can't wait to see its Nav in the HUD. Also a big fan of Lane Keep Assistant. Some said here that its improved. I would give that a try first thing tomorrow when she is out.
Excellent, then you should be set. For my test the CarPlay directions seem to work just like iDrive, it even shows the various lanes and which one to be in in the HUD.
I almost always have the cruise with steering/lane control enabled so haven't noticed any changes to lane keeping in the little I used it.
And you mentioned it only works with Apple Maps not Google Maps (both via CarPlay)?
It only works with Apple Maps currently, not google or Waze
This would seem to indicate that it's now in Apple control, so it could support down the line
      07-23-2020, 06:28 PM   #68
TurtleBoy
TurtleBoy's Avatar
13266
Drives: 2019 X5 40i,2021 M340i
That is correct from my testing. The directions from Apple Maps (not the map itself) showed in the HUD but nothing from Google Maps although iDrove knew that CarPlay was handling navigation since the iDrive map disappeared from the IC and control display.
hkleyman135.00
      07-23-2020, 08:00 PM   #69
jokinawa
293
Drives: 2019 X7 40i
My guess is that Google and Waze have not updated their apps to support the new Carplay HUD APIs.
If my post was informative or helpful, please click the appreciate button. Thank you.
volodp196.50
      07-24-2020, 09:12 AM   #70
zmm12345
Drives: x7 and 330i
Seems to be the case
FYI, I get the beta versions of Waze through TestFlight, and they also don't work in the HUD, so it's probably not around the corner
      07-24-2020, 04:37 PM   #71
ddelX52019G05
ddelX52019G05's Avatar
Drives: BMW 2019 X5 40i, Audi A7 2017
Originally Posted by ifr View Post
Thanks. Those options won't be there then.
Does Google Maps appear in the HUD?
Yes, just got updated to 2020/07.25 and Google Maps does appear in the HUD when using Android Auto
      07-25-2020, 02:51 PM   #72
yamron9
Drives: 2019 X5
Just got mine back today and software version is 07.2020.30 - android auto is not showing up - anyone know how to get that working?
      07-25-2020, 03:10 PM   #73
TurtleBoy
TurtleBoy's Avatar
13266
You shouldn't need to but did you try updating Apps and Services?
      07-25-2020, 04:10 PM   #74
yamron9
Drives: 2019 X5
Yes I tried that. No luck. Also I don't see Spotify either.
      07-25-2020, 04:35 PM   #75
TurtleBoy
TurtleBoy's Avatar
13266
Are you have problems with any other App or connected drive service?
      07-25-2020, 04:47 PM   #76
yamron9
Drives: 2019 X5
Rest of the apps are good. I cannot subscribe to drive recorder as it shows unavailable.
      07-25-2020, 05:15 PM   #77
TurtleBoy
TurtleBoy's Avatar
13266
Let it sit overnight so it does a sleep reset and hopefully things will be there in the morning. If they still aren’t you may want to call connected drive.
      07-25-2020, 10:45 PM   #78
yamron9
Drives: 2019 X5
Thank you! So I went ahead and did a hard reset to revert everything back to factory settings. This in turn fixed all the issues. Finally got Android Auto, Spotify and the drive recorder all working.
TurtleBoy13266.00
      07-28-2020, 03:34 PM   #79
zmm12345
Drives: x7 and 330i
Has anyone had an issue with remote start no longer appearing as an option in the connected app after this update?
Since the update it only gives me an option to "ventilate now", as before it had a "start engine now" option
I am not sure if this is related to the update, or some coding that I did afterwords (though I have no idea how it could be related to the coding)
lufan5.50
      07-28-2020, 04:54 PM   #80
saintsinc
saintsinc's Avatar
Drives: BMW X5 M50i
Ventilate now is the same function as remote start engine ! Once you are in 7/2020 update this function description in IOS connected app charges to this new description
      07-28-2020, 06:13 PM   #81
zmm12345
Drives: x7 and 330i
I'm going to test it now, but I see that pressing the lock button twice on the remote now does nothing.
      07-28-2020, 06:19 PM   #82
zmm12345
Drives: x7 and 330i
Confirmed that it's not the same
It ventilated but did not turn on engine and blow cold air at all
      07-28-2020, 06:25 PM   #83
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
You might work toward a solution by posting a screenshot of what you are seeing.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      07-28-2020, 06:29 PM   #84
TurtleBoy
TurtleBoy's Avatar
13266
Did you check the box to allow the engine to be started? That gets cleared out during the update process so you need to do that in order for the engine to be started. Check it in the Climate menu.
tenzor9.00
      07-28-2020, 06:30 PM   #85
saintsinc
saintsinc's Avatar
Drives: BMW X5 M50i
Sorry you have a Click a setting in your idrive then the description in your connected app will change to start engine now
      07-28-2020, 06:31 PM   #86
saintsinc
saintsinc's Avatar
Drives: BMW X5 M50i
It should after you have change this setting in your i drive
      07-28-2020, 08:16 PM   #87
zmm12345
Drives: x7 and 330i
You got it!
I rechecked the option and it's back on
Thanks so much!
      07-29-2020, 11:02 PM   #88
G050i
Drives: BMW X5 (G05) 50i w/ M-Sport
I'm on 3/2020 version but it sounds like I should have a few more apps available to me but can't seem to get them to appear. I tried "updating services" a couple times and was only able to get the automatic windows app to appear after 2 times. Should I be doing something else?
