10-07-2020, 02:26 PM | #23 | |
ghey
484
Rep 2,041
Original reference I made is to this post: https://g05.bimmerpost.com/forums/sh...9&postcount=11 "The Bowers and Wilkins subwoofers are unfortunately glued into the enclosures in a manner that makes removal without enclosure damage nearly impossible. Due to this we aren't offering subwoofers for an 2020 X5 audio system at the moment, and haven't done extensive testing." However, there is a later post, which I cannot find, where they said yeah it works, but the risk of damaging the very expensive frame/housing is much higher than in a 3er, so for that reason it's not advertised on their site.
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
10-07-2020, 02:32 PM | #24 | |
Rep 223
10-07-2020, 02:33 PM | #25 | |
Rep 223
10-07-2020, 04:05 PM | #26 | |
Rep 159
So, you need to convert that signal to something you can feed into your amplifier. That is why I use the LC2i to generate a low level signal. For both my amplifiers, but that doesn't matter, even if you install only one amplifier, you still need it. (Unless you find an amplifier which can take the powerful speaker signal from the HK amp, but if such an amplifier exists, I am unaware of it.) P.s. I did not install new speakers, I am just powering the underseat subs from the second amp instead of the factory HK amp. |
10-07-2020, 08:27 PM | #27 | |
Rep 223
For the front subs did you run new wire back or were you able to use the existing wiring after connecting the harness?
10-08-2020, 01:46 AM | #28 | |
Rep 159
The technic harness has a plug for the factory subs. If you leave it plugged in, they remain connected to the factory amp. If you unplug it, the harness includes an adapter so you can hook them up to a new amp. All very convenient. |
10-08-2020, 02:33 AM | #29 | |
Rep 804
We were replacing the speakers of a non-BMW car once and then discovered that the audio system had a high-pass filter which filtered out the lowest frequencies, so installing better speakers didn't improve the bass response at all. |
10-08-2020, 03:22 AM | #30 | |
Rep 159
I must say it did significantly improve mid-level bass response and crispyness. However, I did read somewhere (no longer remember where) that the stock HK subwoofers were measured to have response down to 30Hz, so that would suggest no high-pass filtering. |
10-08-2020, 05:04 PM | #31 |
ghey
484
Rep 2,041
Put in a 2020 X5 and see what you get.. If I choose an X6, I see the subs and an amp. X5, just the speakers.
10-08-2020, 05:08 PM | #32 |
Rep 223
It's the same for both cars. You can use the x6 for it as well.
10-08-2020, 05:10 PM | #33 |
ghey
484
Rep 2,041
I know; point is the site is incorrect and that originally they did not list it because of the concerns I mentioned previously.
10-08-2020, 05:11 PM | #34 |
Rep 223
Ahhh gotcha!
10-15-2020, 01:05 AM | #35 | |
Rep 223
I've ordered the following items: HK 688 Harness LC2i JL XD3001 Mono Amp JL Audio 10TW3D4 I'll be attempting the install this weekend or as soon as the equipment comes in. Just wanted to ask if you bolted down the amp in the trunk or have it stuck to the paint using 3M adhesive. Also, would you be able to show pictures of the second amp you've installed for the front seat subs and the wiring harness points going into the LC2i for those. It would really help me get an understanding of how to do it.
10-15-2020, 05:24 PM | #36 | |
Rep 159
I bolted the amp to some soft plywood to keep it from scratching anything and used zipties to secure the whole thing.to an available hole in the trunk, but 3M tape should also work if it's the thick kind. the LC2I has two low level cinch outputs, one for bass with a lowpass at 1Khz and one for full range. I used the bass output for my subwoofer amp, and the full range for the second amp.Connecting it all to the harness will become clear when you see it, it's all well marked. The harness has a 12V output which you can use to power the LC2I, grounds are available all over the trunk. One last tip: Don't use the ignition wire in the harness as a remote for the LC2I and amp, it did not switch off at all for the 30+ minutes I watched it after turning off the car. I ended up using the LC2I signal sensing feature (GTO it is called) to genate the remote signal for the amps. |
10-22-2020, 03:39 PM | #37 | |
Rep 223
I got the harness in today. I'm a bit confused about the wiring. This will be the setup: A new single mono amp for the new sub and will leave the factory under-seat subs to work from the factory amp. I've put some copy onto the attached image in which I have also numbered the parts so it's easier for you to reference the part! Would be super helpful if you could shed some light in how I should move forward on this. Last question: Say I did want to power the front two subs from a new 2 channel amp in the future. What would I need to change say a year from now?
10-23-2020, 02:07 AM | #38 | |
Rep 159
Number 2 and number 4 are the underseat subs, where number 4 comes from the factory amplifier and number 2 is the wiring to the speakers. If you use the factory amplifier for the underseat subs, number 4 connects to number 2 and you don't use number 1 (store it safely as you might need it in the future) If you use an aftermarket amp for the underseat subs, number 1 connects to the speaker output of your aftermarket amplifier and goes into number 2. You leave numer 4 disconnected in that case. Number 3 has the high level speaker outputs that go into your LC2i, and you can use the 12v power from this one for the LC2i (and also the ground if you so choose). The amplifier required thicker power and ground cables and should be connected directly to the battery with a properly fused cable, and one of the ground points you find all over the trunk area. In this case, you can use either of the LC2i low level outputs to connect to your new subwoofer amp. The "main output" provides full range, while the "bass" one already has a low pass filter at 1Khz. Don't use the "Ignition" cable from the LC2i to switch everything on and off, rather use the LC2i GPO feature which senses a signal in the high level speaker input, and provides a remote out to connect to the amplifier remote in. If you add a second aftermarket amplifier later for the underseat subs:
It also helps a lot if you use an aftermarket amp for the underseat subs that has the ability to combine low and high pass filter, so you can isolate a range. For example:
LexxM31701.50 |
10-23-2020, 09:53 AM | #39 | ||||
Rep 223
10-23-2020, 03:08 PM | #40 |
Rep 159
SmartSaves462.00 |
10-25-2020, 01:42 AM | #41 |
Rep 272
10-29-2020, 01:54 PM | #42 | |
Rep 223
Link: https://www.kenwood.com/usa/car/amplifiers/kac-m1814/ It's a Class D with 90 watts RMS x 2 bridged at 4 ohms. It's small and might be the perfect fit for those. It's cheap at $150 as well. Hopefully, it doesn't overpower the subs. It's got a high and low pass filter as well. I'd bridge it to get 90 RMS then connect it. Should be fine????? What do you think about this unit? Also, last question. What's the advatnege of going with 2 separate amps (2 channel + mono) VS going with a 4channel (2+1bridged) and run the same rig? This is the amp: https://www.visions.ca/product-detai...=52&sku=XD4004 I guess I have one last question: What's the advantage of going with 2 separate amps VS going with something like this: https://www.visions.ca/product-detai...=52&sku=XD4004 - Which can be used for 2 fronts subs (70 RMS) and rear bridged (200RMS) and use that to power the 3 woofers? Second option is to go for this unit which has less power but might be a better amp overall. And only run it on 2 channels 50 RMS non bridged. https://www.crutchfield.ca/p_575R220...-R2-200X2.html The kenwood is $150 and the Rockford is $300
11-09-2020, 02:09 PM | #43 | |
Rep 223
Lc2i - LOC JL XD300 - amp JLtw3d4 - subwoofer I need some help setting up the input sensitivity on the amp and the levels on the Lc2i. All youtube videos have confused me. Also, wanted to know whether I should go for that Kenwood amp for the floor woofers so I can isolate high and low frequencies on it?
Sirksael102.50 |
11-09-2020, 09:57 PM | #44 |
Rep 602
I was texting with a BavSound Rep today and he said if we can get 3 orders, we can save $150 on each set! That’s 18% off! Anyone else interested?
